MeasureGUI_AnnotationInteractor Class Reference
Class implementing logical layer for interactive dragging of annotation labels. It includes two components: listener for GUI events occurring inside of OCCT 3D viewer and processor for hooked events to perform interactive modification of the selected annotation within current AIS context.
#include <MeasureGUI_AnnotationInteractor.h>
Inheritance diagram for MeasureGUI_AnnotationInteractor:
Signals
void SignalInteractionStarted (Handle_GEOM_Annotation theIO)
 Emitted when interactor begins modification of the interactive object. More...
void SignalInteractionFinished (Handle_GEOM_Annotation theIO)
 Emitted when interactor finished modification of the interactive object. More...
 MeasureGUI_AnnotationInteractor (GeometryGUI *theGUI, QObject *theOwner)
virtual ~MeasureGUI_AnnotationInteractor ()
void Enable ()
 Enables event processing and interaction handlers. More...
void Disable ()
 Disables event processing and interaction handlers. More...
void SetEditEntry (const QString &theEntry)
 Set entry of allowed annotation presentations. More...
Protected Slots
void OnViewCreated (SUIT_ViewWindow *)
 Handler for signal coming from GUI layer. More...
void OnViewRemoved (SUIT_ViewWindow *)
void ConnectView (SUIT_ViewWindow *theWindow)
 Connect interactor's event handler to the view window given. More...
void DisconnectView (SUIT_ViewWindow *theWindow)
 Disconnect interactor's event handler from the view window given. More...
 Hooks and process events from OCCT viewer prior to their coming into the base viewer class. More...
 Handle (GEOM_Annotation) myActiveIO
GeometryGUI * myGeomGUI
bool myIsEnabled
OCCViewer_ViewManager * myVM
OCCViewer_Viewer * myViewer
OCCViewer_ViewPort3d * myActiveViewPort
SelectMgr_SequenceOfOwner mySelection
QPoint myStartPoint
QString myEditEntry
◆ MeasureGUI_AnnotationInteractor()
MeasureGUI_AnnotationInteractor::MeasureGUI_AnnotationInteractor ( GeometryGUI *  theGUI,
QObject *  theOwner
Connects to existing viewer/view windows to process events.
theGUI[in] the geometry module's GUI interface.
theOwner[in] the owner of the instance.
◆ ~MeasureGUI_AnnotationInteractor()
MeasureGUI_AnnotationInteractor::~MeasureGUI_AnnotationInteractor ( )
References Disable(), and myActiveViewPort.
◆ ConnectView()
void MeasureGUI_AnnotationInteractor::ConnectView ( SUIT_ViewWindow *  theWindow)
◆ Disable()
void MeasureGUI_AnnotationInteractor::Disable ( )
◆ DisconnectView()
void MeasureGUI_AnnotationInteractor::DisconnectView ( SUIT_ViewWindow *  theWindow)
◆ Enable()
void MeasureGUI_AnnotationInteractor::Enable ( )
◆ eventFilter()
bool MeasureGUI_AnnotationInteractor::eventFilter ( QObject *  theObject,
QEvent *  theEvent
It handles the events coming to viewport and identifies whether the events can invoke an interaction operation or not. If yes, the operation is performed within the interactor class and events are "accepted". Otherwise, the events are passed to viewer's subroutines.
References Handle(), myActiveViewPort, myEditEntry, mySelection, myStartPoint, myViewer, SignalInteractionFinished(), and SignalInteractionStarted().
◆ Handle()
MeasureGUI_AnnotationInteractor::Handle ( GEOM_Annotation  )
◆ OnViewCreated
void MeasureGUI_AnnotationInteractor::OnViewCreated ( SUIT_ViewWindow *  theView)
protectedslot
References ConnectView().
◆ OnViewRemoved
void MeasureGUI_AnnotationInteractor::OnViewRemoved ( SUIT_ViewWindow *  theView)
protectedslot
References DisconnectView().
◆ SetEditEntry()
void MeasureGUI_AnnotationInteractor::SetEditEntry ( const QString &  theEntry)
References myEditEntry.
◆ SignalInteractionFinished
void MeasureGUI_AnnotationInteractor::SignalInteractionFinished ( Handle_GEOM_Annotation  theIO)
signal
◆ SignalInteractionStarted
void MeasureGUI_AnnotationInteractor::SignalInteractionStarted ( Handle_GEOM_Annotation  theIO)
signal
◆ myActiveViewPort
OCCViewer_ViewPort3d* MeasureGUI_AnnotationInteractor::myActiveViewPort
◆ myEditEntry
QString MeasureGUI_AnnotationInteractor::myEditEntry
◆ myGeomGUI
GeometryGUI* MeasureGUI_AnnotationInteractor::myGeomGUI
◆ myIsEnabled
bool MeasureGUI_AnnotationInteractor::myIsEnabled
◆ mySelection
SelectMgr_SequenceOfOwner MeasureGUI_AnnotationInteractor::mySelection
◆ myStartPoint
QPoint MeasureGUI_AnnotationInteractor::myStartPoint
◆ myViewer
OCCViewer_Viewer* MeasureGUI_AnnotationInteractor::myViewer
◆ myVM
OCCViewer_ViewManager* MeasureGUI_AnnotationInteractor::myVM
