MeasureGUI_DimensionInteractor Class Reference
#include <MeasureGUI_DimensionInteractor.h>
Inheritance diagram for MeasureGUI_DimensionInteractor:
enum  Operation { Operation_MoveFlyoutFree , Operation_MoveFlyoutInPlane , Operation_MoveText , Operation_None }
Signals
void InteractionStarted (Handle_AIS_InteractiveObject theIO)
void InteractionFinished (Handle_AIS_InteractiveObject theIO)
 MeasureGUI_DimensionInteractor (GeometryGUI *, QObject *)
 ~MeasureGUI_DimensionInteractor ()
void Enable ()
void Disable ()
Protected Slots
void OnViewCreated (SUIT_ViewWindow *)
void OnViewRemoved (SUIT_ViewWindow *)
Operation GetOperation (const Handle(SelectMgr_EntityOwner)&theEntity, const Qt::MouseButtons theButtons, const Qt::KeyboardModifiers theKeys)
 Identify interactive operation by picked entity and pressed buttons with modifiers. More...
bool StartOperation (const Operation theOperation, const Handle(V3d_View)&theView, const int theX, const int theY)
 Prepare for interactive operation. More...
void MoveFlyoutFree (const Handle(V3d_View)&theView, const int theX, const int theY)
 Perform "Operation_MoveFlyoutFree". Modify flyout of interactive dimension so as the flyout follows the mouse by its length and orientation. More...
void MoveFlyoutInPlane (const Handle(V3d_View)&theView, const int theX, const int theY)
 Perform "Operation_MoveFlyoutInPlane". Modify flyout of interactive dimension so as the flyout is extended to the mouse point location in the presentation plane. More...
void MoveText (const Handle(V3d_View)&theView, const int theX, const int theY)
 Perform "Operation_MoveText". Modify text of interactive dimension so as the text is moved to its fixed positions. More...
void ConnectView (SUIT_ViewWindow *)
void DisconnectView (SUIT_ViewWindow *)
gp_Lin Projection (const Handle(V3d_View)&, const int, const int)
gp_Pnt ProjectPlane (const Handle(V3d_View)&, const int, const int, const gp_Pln &, bool &)
Standard_Real SensitivityTolerance (const Handle(V3d_View)&)
 Process events from OCC viewer prior to their coming into the base viewer class. More...
Private Types
typedef NCollection_Sequence< Handle(SelectMgr_EntityOwner)> SeqOfOwners
 Handle (AIS_Dimension) myInteractedIO
GeometryGUI * myGeomGUI
bool myIsEnabled
QPointer< OCCViewer_ViewManager > myVM
OCCViewer_Viewer * myViewer
Operation myOperation
bool myOperationStarted
gp_Pln myFreeMovePlane
SeqOfOwners mySelection
◆ SeqOfOwners
◆ Operation
Operation_MoveText
Operation_None
◆ MeasureGUI_DimensionInteractor()
MeasureGUI_DimensionInteractor::MeasureGUI_DimensionInteractor ( GeometryGUI *  theGUI,
QObject *  theParent
◆ ~MeasureGUI_DimensionInteractor()
MeasureGUI_DimensionInteractor::~MeasureGUI_DimensionInteractor ( )
References Disable().
◆ ConnectView()
void MeasureGUI_DimensionInteractor::ConnectView ( SUIT_ViewWindow *  theView)
◆ Disable()
void MeasureGUI_DimensionInteractor::Disable ( )
References DisconnectView(), myIsEnabled, and myVM.
◆ DisconnectView()
void MeasureGUI_DimensionInteractor::DisconnectView ( SUIT_ViewWindow *  theView)
◆ Enable()
void MeasureGUI_DimensionInteractor::Enable ( )
◆ eventFilter()
bool MeasureGUI_DimensionInteractor::eventFilter ( QObject *  theObject,
QEvent *  theEvent
It handles the events coming to viewport and identifies whether the events correspond to interactive operation on dimension. If yes, the operation is performed within the interactor class and events are "accepted". Otherwise, the events are passed to viewer subroutines.
The method manages internal workflow related to starting and stopping interactive operations to modify the presentations which were passed for this interactor class.
References GetOperation(), Handle(), InteractionFinished(), InteractionStarted(), MoveFlyoutFree(), MoveFlyoutInPlane(), MoveText(), myOperation, mySelection, myViewer, Operation_MoveFlyoutFree, Operation_MoveFlyoutInPlane, Operation_MoveText, Operation_None, and StartOperation().
◆ GetOperation()
MeasureGUI_DimensionInteractor::Operation MeasureGUI_DimensionInteractor::GetOperation ( const Handle(SelectMgr_EntityOwner)&  theEntity,
theEntity[in] the picked entity.
theButtons[in] the mouse buttons.
theKeys[in] the keyboard modifiers.
References Handle(), Operation_MoveFlyoutFree, Operation_MoveFlyoutInPlane, Operation_MoveText, and Operation_None.
◆ Handle()
MeasureGUI_DimensionInteractor::Handle ( AIS_Dimension  )
◆ InteractionFinished
void MeasureGUI_DimensionInteractor::InteractionFinished ( Handle_AIS_InteractiveObject  theIO)
signal
◆ InteractionStarted
void MeasureGUI_DimensionInteractor::InteractionStarted ( Handle_AIS_InteractiveObject  theIO)
signal
◆ MoveFlyoutFree()
void MeasureGUI_DimensionInteractor::MoveFlyoutFree ( const Handle(V3d_View)&  theView,
const int  theX,
const int  theY
theView[in] the interacted view.
theX[in] the mouse position x.
theY[in] the mouse position y.
References Handle(), myFreeMovePlane, myViewer, and ProjectPlane().
◆ MoveFlyoutInPlane()
void MeasureGUI_DimensionInteractor::MoveFlyoutInPlane ( const Handle(V3d_View)&  theView,
const int  theX,
const int  theY
References Handle(), myViewer, and ProjectPlane().
◆ MoveText()
void MeasureGUI_DimensionInteractor::MoveText ( const Handle(V3d_View)&  theView,
const int  theX,
const int  theY
◆ OnViewCreated
void MeasureGUI_DimensionInteractor::OnViewCreated ( SUIT_ViewWindow *  theView)
protectedslot
References ConnectView().
◆ OnViewRemoved
void MeasureGUI_DimensionInteractor::OnViewRemoved ( SUIT_ViewWindow *  theView)
protectedslot
References DisconnectView().
◆ Projection()
gp_Lin MeasureGUI_DimensionInteractor::Projection ( const Handle(V3d_View)&  theView,
const int  theMouseX,
const int  theMouseY
◆ ProjectPlane()
gp_Pnt MeasureGUI_DimensionInteractor::ProjectPlane ( const Handle(V3d_View)&  theView,
const int  theMouseY,
const gp_Pln &  thePlane,
bool &  theIsDone
References Handle(), and Projection().
◆ SensitivityTolerance()
Standard_Real MeasureGUI_DimensionInteractor::SensitivityTolerance ( const Handle(V3d_View)&  theView)
◆ StartOperation()
bool MeasureGUI_DimensionInteractor::StartOperation ( const Operation  theOperation,
const int  theX,
const int  theY
theOp[in] the operation.
TRUE if operation can be started.
References Handle(), myFreeMovePlane, Operation_MoveFlyoutFree, Operation_MoveFlyoutInPlane, Operation_MoveText, Projection(), and ProjectPlane().
◆ myFreeMovePlane
gp_Pln MeasureGUI_DimensionInteractor::myFreeMovePlane
◆ myGeomGUI
GeometryGUI* MeasureGUI_DimensionInteractor::myGeomGUI
◆ myIsEnabled
bool MeasureGUI_DimensionInteractor::myIsEnabled
◆ myOperation
Operation MeasureGUI_DimensionInteractor::myOperation
◆ myOperationStarted
bool MeasureGUI_DimensionInteractor::myOperationStarted
◆ mySelection
SeqOfOwners MeasureGUI_DimensionInteractor::mySelection
◆ myViewer
OCCViewer_Viewer* MeasureGUI_DimensionInteractor::myViewer
◆ myVM
QPointer<OCCViewer_ViewManager> MeasureGUI_DimensionInteractor::myVM
