ShapeRec_FeatureDetector Class Reference
#include <ShapeRec_FeatureDetector.hxx>
typedef std::vector< cv::Point > CvContour
typedef std::vector< std::vector< cv::Point > > CvContoursArray
 ShapeRec_FeatureDetector ()
void SetPath (const std::string &)
void SetROI (const QRect &)
CvPoint2D32f * GetCorners ()
CvContoursArray GetContours ()
std::vector< cv::Vec4i > GetLines ()
std::vector< cv::Vec4i > GetContoursHierarchy ()
int GetCornerCount ()
int GetImgHeight ()
int GetImgWidth ()
std::string CroppImage ()
void ComputeCorners (bool useROI=false, ShapeRec_Parameters *parameters=0)
bool ComputeLines ()
bool ComputeContours (bool useROI=false, ShapeRec_Parameters *parameters=0)
std::string imagePath
CvPoint2D32f * corners
int cornerCount
CvContoursArray contours
std::vector< cv::Vec4i > hierarchy
std::vector< cv::Vec4i > lines
int imgHeight
int imgWidth
CvRect rect
◆ CvContour
typedef std::vector<cv::Point> ShapeRec_FeatureDetector::CvContour
◆ CvContoursArray
typedef std::vector<std::vector<cv::Point> > ShapeRec_FeatureDetector::CvContoursArray
◆ ShapeRec_FeatureDetector()
ShapeRec_FeatureDetector::ShapeRec_FeatureDetector ( )
Constructor
theFilename- image to process
References cornerCount, imagePath, imgHeight, imgWidth, and rect.
◆ ComputeContours()
◆ ComputeCorners()
◆ ComputeLines()
bool ShapeRec_FeatureDetector::ComputeLines ( )
Computes the lines in the image located at imagePath
References imagePath, and lines.
◆ CroppImage()
std::string ShapeRec_FeatureDetector::CroppImage ( )
Crops the image located at imagePath to the region of interest given by the user via SetROI and stores the result in /tmp
theRect- Region Of Interest of the image located at imagePath
References imagePath, and rect.
◆ GetContours()
CvContoursArray ShapeRec_FeatureDetector::GetContours ( )
◆ GetContoursHierarchy()
std::vector< cv::Vec4i > ShapeRec_FeatureDetector::GetContoursHierarchy ( )
◆ GetCornerCount()
int ShapeRec_FeatureDetector::GetCornerCount ( )
◆ GetCorners()
CvPoint2D32f * ShapeRec_FeatureDetector::GetCorners ( )
◆ GetImgHeight()
int ShapeRec_FeatureDetector::GetImgHeight ( )
◆ GetImgWidth()
int ShapeRec_FeatureDetector::GetImgWidth ( )
◆ GetLines()
std::vector< cv::Vec4i > ShapeRec_FeatureDetector::GetLines ( )
◆ SetPath()
void ShapeRec_FeatureDetector::SetPath ( const std::string &  thePath)
Sets the path of the image file to be processed
thePath- Location of the image file
References imagePath, imgHeight, and imgWidth.
◆ SetROI()
void ShapeRec_FeatureDetector::SetROI ( const QRect &  theRect)
Stores a region of interest given by user in rect
References rect.
◆ contours
CvContoursArray ShapeRec_FeatureDetector::contours
◆ cornerCount
int ShapeRec_FeatureDetector::cornerCount
◆ corners
CvPoint2D32f* ShapeRec_FeatureDetector::corners
◆ hierarchy
std::vector<cv::Vec4i> ShapeRec_FeatureDetector::hierarchy
◆ imagePath
std::string ShapeRec_FeatureDetector::imagePath
◆ imgHeight
int ShapeRec_FeatureDetector::imgHeight
◆ imgWidth
int ShapeRec_FeatureDetector::imgWidth
◆ lines
std::vector<cv::Vec4i> ShapeRec_FeatureDetector::lines
◆ rect
CvRect ShapeRec_FeatureDetector::rect
