XAO::GeometricElementList Class Reference
Generic class to manipulate a list of topologic element.
#include <XAO_GeometricElement.hxx>
typedef std::map< int, GeometricElement >::iterator iterator
 Iterator on the element of the list. More...
 GeometricElementList ()
 Default constructor. More...
 GeometricElementList (int nb)
 Constructor with size. More...
virtual ~GeometricElementList ()
int getSize () const
 Gets the size of the list. More...
void setSize (int nb)
 Sets the size of the list. More...
void setElement (int index, const std::string &name, const std::string &reference)
 Sets the name and the reference of an element. More...
const std::string getName (int index)
 Gets the name of an element. More...
void setName (int index, const std::string &name)
 Sets the name of an element. More...
bool hasName (int index)
 Checks if an element has a name. More...
const std::string getReference (int index)
 Gets the reference of an element. More...
void setReference (int index, const std::string &reference)
 Sets the reference of an element. More...
int getIndexByReference (const std::string &reference)
 Gets the index of an element using its reference. More...
iterator begin ()
 Gets an iterator on the first element. More...
iterator end ()
 Gets an iterator on the last element. More...
void checkElementIndex (int index) const
int m_count
std::map< int, GeometricElement > m_elements
◆ iterator
typedef std::map<int,GeometricElement>::iterator XAO::GeometricElementList::iterator
◆ GeometricElementList() [1/2]
GeometricElementList::GeometricElementList ( )
References setSize().
◆ GeometricElementList() [2/2]
GeometricElementList::GeometricElementList ( int  nb)
nbthe size to set.
◆ ~GeometricElementList()
virtual XAO::GeometricElementList::~GeometricElementList ( )
◆ begin()
iterator XAO::GeometricElementList::begin ( )
◆ checkElementIndex()
void GeometricElementList::checkElementIndex ( int  index) const
References m_count.
◆ end()
iterator XAO::GeometricElementList::end ( )
◆ getIndexByReference()
int GeometricElementList::getIndexByReference ( const std::string &  reference)
referencethe searched reference.
the index of the element or -1 if no element found.
References getReference(), m_count, and m_elements.
◆ getName()
const std::string GeometricElementList::getName ( int  index)
indexthe index of the element to set.
the name of the element with the given index.
Exceptions
XAO_Exceptionif index is bigger than the size of the list.
References checkElementIndex(), and m_elements.
◆ getReference()
const std::string GeometricElementList::getReference ( int  index)
indexthe index of the element.
the reference of the element.
Exceptions
◆ getSize()
int XAO::GeometricElementList::getSize ( ) const
◆ hasName()
bool GeometricElementList::hasName ( int  index)
true if the element has a name, false otherwise.
◆ setElement()
void GeometricElementList::setElement ( int  index,
const std::string &  name,
namethe name to set.
referencethe reference to set.
Exceptions
◆ setName()
void GeometricElementList::setName ( int  index,
Exceptions
◆ setReference()
void GeometricElementList::setReference ( int  index,
Exceptions
◆ setSize()
void GeometricElementList::setSize ( int  nb)
nbthe size to set.
Warning
the list will be cleared.
References m_count, and m_elements.
◆ m_count
int XAO::GeometricElementList::m_count
◆ m_elements
std::map<int, GeometricElement> XAO::GeometricElementList::m_elements
