50 GEOMGUI_EXPORT void setColor(
const char* theEntry,
int theRed,
int theGreen,
int theBlue,
bool theUpdateViewer =
true );
52 GEOMGUI_EXPORT void setIsos(
int theNbU,
int theNbV,
true );
72 void init(
bool updateOB );
#define GEOMGUI_EXPORT
Definition: GEOM_GEOMGUI.hxx:36
Definition: GEOMGUI_OCCSelector.h:35
Definition: GEOM_Swig_LocalSelector.h:34
Definition: libGEOM_Swig.h:35
GEOMGUI_EXPORT const char * getShapeTypeIcon(const char *theIOR)
Get shape's icon ID (specified by its type)
Definition: libGEOM_Swig.cxx:297
GEOMGUI_EXPORT void createAndDisplayFitAllGO(const char *theEntry)
Same as createAndDisplayGO, but also fits the active view to the contents.
Definition: libGEOM_Swig.cxx:163
GEOMGUI_EXPORT void UpdateViewer()
Update active viewer contents.
Definition: libGEOM_Swig.cxx:218
GEOMGUI_EXPORT void setColor(const char *theEntry, int theRed, int theGreen, int theBlue, bool theUpdateViewer=true)
Change color of the presentation.
Definition: libGEOM_Swig.cxx:432
GEOMGUI_EXPORT void setNameMode(const char *theEntry, bool theOn, bool theUpdateViewer=true)
Show / hide name of shape for the presentation.
Definition: libGEOM_Swig.cxx:418
GEOMGUI_EXPORT void setIsos(const char *theEntry, int theNbU, int theNbV, bool theUpdateViewer=true)
Set number of iso-lines to the presentation.
Definition: libGEOM_Swig.cxx:458
GEOMGUI_EXPORT bool initGeomGen()
Initialize GEOM module's engine.
Definition: libGEOM_Swig.cxx:672
GEOMGUI_EXPORT void createAndDisplayGO(const char *theEntry, bool theUpdateViewer=true)
Display the presenation in the currently active view.
Definition: libGEOM_Swig.cxx:137
GEOMGUI_EXPORT GEOM_Swig(bool updateOB=true)
Definition: libGEOM_Swig.cxx:60
GEOMGUI_EXPORT const char * getShapeTypeString(const char *theIOR)
Get shape type name.
Definition: libGEOM_Swig.cxx:270
GEOMGUI_EXPORT std::vector< int > getLocalSelection()
get local subShapes selection on a given shape
Definition: libGEOM_Swig.cxx:582
GEOMGUI_EXPORT void setVectorsMode(const char *theEntry, bool theOn, bool theUpdateViewer=true)
Show / hide edges direction vectors for the presentation.
Definition: libGEOM_Swig.cxx:394
GEOMGUI_EXPORT void setTransparency(const char *theEntry, float theTransparency, bool theUpdateViewer=true)
Set transparency of the presentation.
Definition: libGEOM_Swig.cxx:471
GEOMGUI_EXPORT void setMaterial(const char *theEntry, const char *theMaterial, bool theUpdateViewer=true)
Set material to the presentation.
Definition: libGEOM_Swig.cxx:495
GEOMGUI_EXPORT void initLocalSelection(const char *theEntry, int theMode)
initialize local subShapes selection on a given shape
Definition: libGEOM_Swig.cxx:520
GEOMGUI_EXPORT void closeLocalSelection()
close local subShapes selection on a given shape
Definition: libGEOM_Swig.cxx:634
GEOMGUI_EXPORT void setMaterialProperty(const char *theEntry, const char *theMaterial, bool theUpdateViewer=true)
Set material property to the presentation.
Definition: libGEOM_Swig.cxx:509
GEOMGUI_EXPORT ~GEOM_Swig()
Definition: libGEOM_Swig.cxx:68
GEOMGUI_EXPORT void eraseGO(const char *theEntry, bool theUpdateViewer=true)
Erase presentation in the currently active viewer.
Definition: libGEOM_Swig.cxx:194
static GEOMGUI_OCCSelector * myOCCSelector
Definition: libGEOM_Swig.h:69
void init(bool updateOB)
Internal initialization.
Definition: libGEOM_Swig.cxx:83
GEOMGUI_EXPORT void setDisplayMode(const char *theEntry, int theMode, bool theUpdateViewer=true)
Set display mode to the presentation.
Definition: libGEOM_Swig.cxx:382
GEOMGUI_EXPORT void setVerticesMode(const char *theEntry, bool theOn, bool theUpdateViewer=true)
Show / hide vertices for the presentation.
Definition: libGEOM_Swig.cxx:406
GEOMGUI_EXPORT int getIndexTopology(const char *theSubIOR, const char *theMainIOR)
Get sub-shape index inside main shape.
Definition: libGEOM_Swig.cxx:240
static GEOM_Swig_LocalSelector * myLocalSelector
Definition: libGEOM_Swig.h:68
GEOMGUI_EXPORT void setLocalSelection(const std::vector< int > ids)
Set local subShapes selection on a given shape.
Definition: libGEOM_Swig.cxx:609
GEOMGUI_EXPORT void setDeflection(const char *theEntry, float theDeflection, bool theUpdateViewer=true)
Set deflection coefficient of the presentation.
Definition: libGEOM_Swig.cxx:483
