GEOM_Swig Class Reference
#include <libGEOM_Swig.h>
GEOMGUI_EXPORT GEOM_Swig (bool updateOB=true)
GEOMGUI_EXPORT ~GEOM_Swig ()
GEOMGUI_EXPORT void createAndDisplayGO (const char *theEntry, bool theUpdateViewer=true)
 Display the presenation in the currently active view. More...
GEOMGUI_EXPORT void createAndDisplayFitAllGO (const char *theEntry)
 Same as createAndDisplayGO, but also fits the active view to the contents. More...
GEOMGUI_EXPORT void eraseGO (const char *theEntry, bool theUpdateViewer=true)
 Erase presentation in the currently active viewer. More...
GEOMGUI_EXPORT void UpdateViewer ()
 Update active viewer contents. More...
GEOMGUI_EXPORT void setDisplayMode (const char *theEntry, int theMode, bool theUpdateViewer=true)
 Set display mode to the presentation. More...
GEOMGUI_EXPORT void setVectorsMode (const char *theEntry, bool theOn, bool theUpdateViewer=true)
 Show / hide edges direction vectors for the presentation. More...
GEOMGUI_EXPORT void setVerticesMode (const char *theEntry, bool theOn, bool theUpdateViewer=true)
 Show / hide vertices for the presentation. More...
GEOMGUI_EXPORT void setNameMode (const char *theEntry, bool theOn, bool theUpdateViewer=true)
 Show / hide name of shape for the presentation. More...
GEOMGUI_EXPORT void setColor (const char *theEntry, int theRed, int theGreen, int theBlue, bool theUpdateViewer=true)
 Change color of the presentation. More...
GEOMGUI_EXPORT void setTransparency (const char *theEntry, float theTransparency, bool theUpdateViewer=true)
 Set transparency of the presentation. More...
GEOMGUI_EXPORT void setIsos (const char *theEntry, int theNbU, int theNbV, bool theUpdateViewer=true)
 Set number of iso-lines to the presentation. More...
GEOMGUI_EXPORT void setDeflection (const char *theEntry, float theDeflection, bool theUpdateViewer=true)
 Set deflection coefficient of the presentation. More...
GEOMGUI_EXPORT void setMaterial (const char *theEntry, const char *theMaterial, bool theUpdateViewer=true)
 Set material to the presentation. More...
GEOMGUI_EXPORT void setMaterialProperty (const char *theEntry, const char *theMaterial, bool theUpdateViewer=true)
 Set material property to the presentation. More...
GEOMGUI_EXPORT void initLocalSelection (const char *theEntry, int theMode)
 initialize local subShapes selection on a given shape More...
GEOMGUI_EXPORT std::vector< int > getLocalSelection ()
 get local subShapes selection on a given shape More...
GEOMGUI_EXPORT void setLocalSelection (const std::vector< int > ids)
 Set local subShapes selection on a given shape. More...
GEOMGUI_EXPORT void closeLocalSelection ()
 close local subShapes selection on a given shape More...
GEOMGUI_EXPORT int getIndexTopology (const char *theSubIOR, const char *theMainIOR)
 Get sub-shape index inside main shape. More...
GEOMGUI_EXPORT const char * getShapeTypeString (const char *theIOR)
 Get shape type name. More...
GEOMGUI_EXPORT const char * getShapeTypeIcon (const char *theIOR)
 Get shape's icon ID (specified by its type) More...
GEOMGUI_EXPORT bool initGeomGen ()
 Initialize GEOM module's engine. More...
Static Public Attributes
static GEOM_Swig_LocalSelector * myLocalSelector = 0
static GEOMGUI_OCCSelector * myOCCSelector =0
void init (bool updateOB)
 Internal initialization. More...
◆ GEOM_Swig()
GEOM_Swig::GEOM_Swig ( bool  updateOB = true)
References init().
◆ ~GEOM_Swig()
GEOM_Swig::~GEOM_Swig ( )
References myOCCSelector.
◆ closeLocalSelection()
void GEOM_Swig::closeLocalSelection ( )
References myLocalSelector.
◆ createAndDisplayFitAllGO()
void GEOM_Swig::createAndDisplayFitAllGO ( const char *  theEntry)
theEntrygeometry object's entry
theUpdateViewertrue to update active view's contents
References createAndDisplayGO().
◆ createAndDisplayGO()
void GEOM_Swig::createAndDisplayGO ( const char *  theEntry,
bool  theUpdateViewer = true
References GEOM_Displayer::Display(), and Handle().
◆ eraseGO()
void GEOM_Swig::eraseGO ( const char *  theEntry,
References GEOM_Displayer::Erase(), and Handle().
◆ getIndexTopology()
int GEOM_Swig::getIndexTopology ( const char *  theSubIOR,
const char *  theMainIOR
theSubIORsub-shape geometry object's IOR
theMainIORmain shape geometry object's IOR
sub-shape index (-1 in case of error)
References GeometryGUI::GetGeomGen().
◆ getLocalSelection()
std::vector< int > GEOM_Swig::getLocalSelection ( )
a list of selected subShapes indexes
References GEOM_Swig_LocalSelector::getSelection(), and myLocalSelector.
◆ getShapeTypeIcon()
const char * GEOM_Swig::getShapeTypeIcon ( const char *  theIOR)
theIORgeometry object's IOR
icon ID ("None" in case of error)
References GEOM::COMPOUND, and GEOM::SHAPE.
◆ getShapeTypeString()
const char * GEOM_Swig::getShapeTypeString ( const char *  theIOR)
shape type name ("Shape of unknown type" in case of error)
◆ init()
void GEOM_Swig::init ( bool  updateOB)
◆ initGeomGen()
bool GEOM_Swig::initGeomGen ( )
true if initialization succeeds or false otherwise
◆ initLocalSelection()
void GEOM_Swig::initLocalSelection ( const char *  theEntry,
int  theMode
theModefrom enum TopAbs_ShapeEnum
References myLocalSelector, and myOCCSelector.
◆ setColor()
void GEOM_Swig::setColor ( const char *  theEntry,
int  theRed,
int  theGreen,
int  theBlue,
theRedred component of the component (0-255)
theGreengreen component of the component (0-255)
theBlueblue component of the component (0-255)
References GEOM::Color, GEOMBase::GetObjectFromEntry(), and GEOM::propertyName().
◆ setDeflection()
void GEOM_Swig::setDeflection ( const char *  theEntry,
theDeflectiondeflection coefficient (floating point value)
References GEOM::Deflection, and GEOM::propertyName().
◆ setDisplayMode()
void GEOM_Swig::setDisplayMode ( const char *  theEntry,
int  theMode,
theModedisplay mode: 0 - wireframe, 1 - shading, 2 - shading+edges, 3-textured
References GEOM::DisplayMode, and GEOM::propertyName().
◆ setIsos()
void GEOM_Swig::setIsos ( const char *  theEntry,
int  theNbU,
int  theNbV,
theNbUnumber of iso-lines along U axis (integer value >= 0)
theNbVnumber of iso-lines along V axis (integer value >= 0)
References GEOM::NbIsos, GEOM::propertyName(), and GEOM::subSectionSeparator().
◆ setLocalSelection()
void GEOM_Swig::setLocalSelection ( const std::vector< int >  ids)
libGEOM_Swig
idssub-shapes ids
References myLocalSelector, and GEOM_Swig_LocalSelector::setSelection().
◆ setMaterial()
void GEOM_Swig::setMaterial ( const char *  theEntry,
const char *  theMaterial,
theMaterialmaterial name (string)
References Material_Model::fromResources(), GEOM::Material, GEOM::propertyName(), and Material_Model::toProperties().
◆ setMaterialProperty()
void GEOM_Swig::setMaterialProperty ( const char *  theEntry,
theMaterialmaterial property string
References GEOM::Material, and GEOM::propertyName().
◆ setNameMode()
void GEOM_Swig::setNameMode ( const char *  theEntry,
bool  theOn,
theOntrue to show name or false otherwise
References GEOM::propertyName(), and GEOM::ShowName.
◆ setTransparency()
void GEOM_Swig::setTransparency ( const char *  theEntry,
theTransparencytransparency (floating point value between 0 and 1)
References GEOM::propertyName(), and GEOM::Transparency.
◆ setVectorsMode()
void GEOM_Swig::setVectorsMode ( const char *  theEntry,
bool  theOn,
theOntrue to show edges direction vectors or false otherwise
References GEOM::EdgesDirection, and GEOM::propertyName().
◆ setVerticesMode()
void GEOM_Swig::setVerticesMode ( const char *  theEntry,
bool  theOn,
theOntrue to show vertices or false otherwise
References GEOM::propertyName(), and GEOM::Vertices.
◆ UpdateViewer()
void GEOM_Swig::UpdateViewer ( )
◆ myLocalSelector
GEOM_Swig_LocalSelector * GEOM_Swig::myLocalSelector = 0
◆ myOCCSelector
GEOMGUI_OCCSelector * GEOM_Swig::myOCCSelector =0
