SALOME_GuiServices.hxx
20// Author: Guillaume Boulant (EDF/R&D)
21
22#ifndef __GUI_SERVICES_H__
23#define __GUI_SERVICES_H__
24
26#include <SalomeApp_Study.h>
28#include <SUIT_ResourceMgr.h>
30#include "SALOMEconfig.h"
31#include CORBA_SERVER_HEADER(SALOMEDS)
33#include <SALOME_KernelServices.hxx>
34#include "SalomeGuiHelpers.hxx"
35namespace GUI {
36
37 // SALOME GUI main services
41
42 // Helper functions to deal with the study in a GUI context.
43 //
44 // First of all, in a GUI context, there is one of the opened
45 // studies that is considered as active. Please note that the active
46 // study is a GUI concept and it can be obtained only in the
47 // SALOME_SessionServer process, i.e. the process that embeds the
48 // SalomeApp_Application. The concept of active study doesn't make
49 // sense outside of the GUI context.
50 //
51 // The active study is associated with an GUI Objects Browser that
52 // displays a graphical representation of the study. The items that
53 // can be selected in the Objects Browser are name Interactive
54 // Objects (instance of class SALOME_InteractiveObject). To work
55 // with data, we have to retrieve from this Interactive Object (IO)
56 // the underlying Study Object (instance of class SALOMEDS::SObject)
57 // and from this last the data object that can be anything (that
58 // depends of the SALOME module technical choices). In general, on
59 // of the attribute of a SObject is a CORBA servant that handles the
60 // data to work with
61 SALOMEGUIHELPERS_EXPORT SALOMEDS::Study_ptr getStudyServant();
62
63 // Another way to get the active study (to be converted in
64 // SALOMEDS::Study):
66
67 SALOMEGUIHELPERS_EXPORT SALOMEDS::SObject_ptr IObjectToSObject(const Handle(SALOME_InteractiveObject)& iobject);
68
69 template<class TInterface> typename TInterface::_var_type
71 SALOMEDS::SObject_ptr sobject = IObjectToSObject(iobject);
72 return KERNEL::SObjectToInterface<TInterface>(sobject);
73 }
74 // _MEM_: note that template functions have to be declared AND
75 // implemented in the header because they are not compiled in this
76 // library but in every client library that includes this header
77 // file. The effective compilation depends on the particular class
78 // used for TInterface.
79
80
81}
82
83#endif // GUI_SERVICES
Handle(TDocStd_Application) CAF_Application
Get OCAF application.
Definition: CAF_Application.cxx:97
#define SALOMEGUIHELPERS_EXPORT
Definition: SalomeGuiHelpers.hxx:33
Definition: LightApp_SelectionMgr.h:53
Definition: SUIT_ResourceMgr.h:31
Application containing SalomeApp module or LightApp module.
Definition: SalomeApp_Application.h:68
Definition: SalomeApp_Study.h:37
Definition: SALOME_GuiServices.cxx:25
LightApp_SelectionMgr * getSelectionManager()
Definition: SALOME_GuiServices.cxx:57
This returns the current active study if an active study is defined in the SALOME session,...
Definition: SALOME_GuiServices.cxx:75
SalomeApp_Application * getSalomeApplication()
Definition: SALOME_GuiServices.cxx:42
SUIT_ResourceMgr * getResourcesManager()
Definition: SALOME_GuiServices.cxx:64
SALOMEDS::SObject_ptr IObjectToSObject(const Handle(SALOME_InteractiveObject)&iobject)
Definition: SALOME_GuiServices.cxx:90
SalomeApp_Study * getSalomeAppActiveStudy()
Definition: SALOME_GuiServices.cxx:81
TInterface::_var_type IObjectToInterface(const Handle(SALOME_InteractiveObject)&iobject)
Definition: SALOME_GuiServices.hxx:70
