SUIT_CameraProperties.h
23#ifndef SUIT_CAMERAPROPERITES_H
24#define SUIT_CAMERAPROPERITES_H
26#include "SUIT.h"
27
29{
30public:
31 enum Dimension { DimNone, Dim2D, Dim3D };
32 enum ViewSide { ViewNone, ViewXY, ViewXZ, ViewYZ };
33 enum Projection { PrjOrthogonal, PrjPerspective };
34
36 virtual ~SUIT_CameraProperties();
37
38 bool isValid() const;
39 bool isCompatible( const SUIT_CameraProperties& other );
40
41 Dimension getDimension() const;
42 void setDimension( const Dimension theDimension );
43
44 ViewSide getViewSide() const;
45 void setViewSide( const ViewSide theViewSide );
46
47 Projection getProjection() const;
48 void setProjection( const Projection theProjection );
49
50 void getViewUp(double& theX, double& theY, double& theZ) const;
51 void setViewUp(const double theX, const double theY, const double theZ);
52
53 void getPosition(double& theX, double& theY, double& theZ) const;
54 void setPosition(const double theX, const double theY, const double theZ);
55
56 void getFocalPoint(double& theX, double& theY, double& theZ) const;
57 void setFocalPoint(const double theX, const double theY, const double theZ);
58
59 double getMappingScale() const;
60 void setMappingScale(const double theScale);
61
62 void getAxialScale(double& theScaleX, double& theScaleY, double& theScaleZ);
63 void setAxialScale(const double theScaleX, const double theScaleY, const double theScaleZ);
64
65 double getViewAngle() const;
66 void setViewAngle(const double theViewAngle);
67
68// common properties for all viewers
69private:
73 double myUpDir[3];
74 double myPosition[3];
75 double myFocalPoint[3];
77 double myAxialScale[3];
78 double myViewAngle;
79};
80
81#endif // SUIT_CAMERAPROPERITES_H
const QString const bool const double theScale
Definition: OCCViewer_ViewModel.cxx:975
#define SUIT_EXPORT
Definition: SUIT.h:36
bool isValid(const QPolygon *thePoints, const QPoint &theCurrent)
Definition: SVTK_InteractorStyle.cxx:1762
Base class for Camera Properties.
Definition: SUIT_CameraProperties.h:29
double myMappingScale
window mapping scale (parallel projection scale)
Definition: SUIT_CameraProperties.h:76
Projection myProjection
projection mode (for 3d viewer): orthogonal / perspective
Definition: SUIT_CameraProperties.h:72
double myViewAngle
perspective view angle in degrees
Definition: SUIT_CameraProperties.h:78
ViewSide
Definition: SUIT_CameraProperties.h:32
@ ViewNone
Dimension myDimension
dimension
Definition: SUIT_CameraProperties.h:70
Dimension
Definition: SUIT_CameraProperties.h:31
@ Dim2D
ViewSide myViewSide
side view (for 2d viewer)
Definition: SUIT_CameraProperties.h:71
Projection
Definition: SUIT_CameraProperties.h:33
@ PrjOrthogonal
