SUIT_CameraProperties Class Reference
Base class for Camera Properties. More...
#include <SUIT_CameraProperties.h>
enum  Dimension { DimNone , Dim2D , Dim3D }
enum  ViewSide { ViewNone , ViewXY , ViewXZ , ViewYZ }
enum  Projection { PrjOrthogonal , PrjPerspective }
 SUIT_CameraProperties ()
 Default constructor. More...
virtual ~SUIT_CameraProperties ()
bool isValid () const
 Check if camera properties are valid. More...
bool isCompatible (const SUIT_CameraProperties &other)
 Check if this camera properties data is compatible with other camera properties. More...
Dimension getDimension () const
 get dimension supported by camera. More...
void setDimension (const Dimension theDimension)
 set dimension supported by camera. More...
ViewSide getViewSide () const
 get side view supported by camera (for 2d viewer). More...
void setViewSide (const ViewSide theViewSide)
 set side view supported by camera (for 2d viewer). More...
Projection getProjection () const
 get projection mode supported by camera (for 3d viewer). More...
void setProjection (const Projection theProjection)
 set projection mode supported by camera (for 3d viewer). More...
void getViewUp (double &theX, double &theY, double &theZ) const
 get camera up direction vector. More...
void setViewUp (const double theX, const double theY, const double theZ)
 set camera up direction vector. More...
void getPosition (double &theX, double &theY, double &theZ) const
 get camera's position (eye). More...
void setPosition (const double theX, const double theY, const double theZ)
void getFocalPoint (double &theX, double &theY, double &theZ) const
 get camera's focal point (look point). More...
void setFocalPoint (const double theX, const double theY, const double theZ)
 set camera's focal point (look point). More...
double getMappingScale () const
 get window mapping scale (parallel scale). More...
void setMappingScale (const double theScale)
 set window mapping scale (parallel scale). More...
void getAxialScale (double &theScaleX, double &theScaleY, double &theScaleZ)
 get scaling factors for world-coordinate space axes. More...
void setAxialScale (const double theScaleX, const double theScaleY, const double theScaleZ)
 set scaling factors for world-coordinate space axes. More...
double getViewAngle () const
 get angle (typically in degrees) of view for perpective projection mode. More...
void setViewAngle (const double theViewAngle)
 set angle (typically in degrees) of view for perpective projection mode. More...
Dimension myDimension
 dimension More...
ViewSide myViewSide
 side view (for 2d viewer) More...
Projection myProjection
 projection mode (for 3d viewer): orthogonal / perspective More...
double myUpDir [3]
 camera up vector More...
double myPosition [3]
 camera position (eye). More...
double myFocalPoint [3]
 focal point position in world-space coordinates More...
double myMappingScale
 window mapping scale (parallel projection scale) More...
double myAxialScale [3]
 scaling factors for world axes More...
double myViewAngle
 perspective view angle in degrees More...
This class provides common properties that can be used for any arbitrary camera. This properties are employed by camera synchronization algorithms.
◆ Dimension
DimNone
Dim2D
Dim3D
◆ Projection
PrjOrthogonal
PrjPerspective
◆ ViewSide
ViewNone
ViewXY
ViewXZ
ViewYZ
◆ SUIT_CameraProperties()
SUIT_CameraProperties::SUIT_CameraProperties ( )
Creates invalid camera properties data, i.e. IsValid() returns false.
References DimNone, myAxialScale, myDimension, myFocalPoint, myMappingScale, myPosition, myProjection, myUpDir, myViewAngle, myViewSide, PrjOrthogonal, and ViewNone.
◆ ~SUIT_CameraProperties()
SUIT_CameraProperties::~SUIT_CameraProperties ( )
◆ getAxialScale()
void SUIT_CameraProperties::getAxialScale ( double &  theScaleX,
double &  theScaleY,
double &  theScaleZ
theScaleX[out] scale by x coordinate.
theScaleY[out] scale by y coordinate.
theScaleZ[out] scale by z coordinate.
See also
setAxialScale()
References myAxialScale.
◆ getDimension()
SUIT_CameraProperties::Dimension SUIT_CameraProperties::getDimension ( ) const
dimension mode.
See also
setDimension()
References myDimension.
◆ getFocalPoint()
void SUIT_CameraProperties::getFocalPoint ( double &  theX,
double &  theY,
double &  theZ
theX[out] x coordinate in world-coordinates space.
theY[out] y coordinate in world-coordinates space.
theZ[out] z coordinate in world-coordinates space.
See also
setFocalPoint()
References myFocalPoint.
◆ getMappingScale()
double SUIT_CameraProperties::getMappingScale ( ) const
Mapping scale defines a mapping scaling factor for the height of the viewport in world-coordinate distances.
scaling value.
See also
setMappingScale()
References myMappingScale.
◆ getPosition()
void SUIT_CameraProperties::getPosition ( double &  theX,
double &  theY,
double &  theZ
See also
setPosition()
References myPosition.
◆ getProjection()
SUIT_CameraProperties::Projection SUIT_CameraProperties::getProjection ( ) const
For 3d viewer, projection mode can be of following values:
projection mode.
See also
setProjection()
References myProjection.
◆ getViewAngle()
double SUIT_CameraProperties::getViewAngle ( ) const
the angle of view.
See also
setViewAngle()
References myViewAngle.
◆ getViewSide()
SUIT_CameraProperties::ViewSide SUIT_CameraProperties::getViewSide ( ) const
For 2d viewer, side view can be of following values:
side view.
See also
setViewSide()
References myViewSide.
◆ getViewUp()
void SUIT_CameraProperties::getViewUp ( double &  theX,
double &  theY,
double &  theZ
theX[out] vector's x coordinate in world-coordinates space.
theY[out] vector's y coordinate in world-coordinates space.
theZ[out] vector's z coordinate in world-coordinates space.
See also
setViewUp()
References myUpDir.
◆ isCompatible()
bool SUIT_CameraProperties::isCompatible ( const SUIT_CameraProperties &  other)
otherother properties data
true if both camera properties sets are compatible
References Dim2D, Dim3D, getDimension(), getProjection(), getViewSide(), and isValid().
◆ isValid()
bool SUIT_CameraProperties::isValid ( ) const
true if camera properties data is valid.
See also
setDimension()
References DimNone, and myDimension.
◆ setAxialScale()
void SUIT_CameraProperties::setAxialScale ( const double  theScaleX,
theScaleX[in] scale by x coordinate.
theScaleY[in] scale by y coordinate.
theScaleZ[in] scale by z coordinate.
See also
getAxialScale()
◆ setDimension()
void SUIT_CameraProperties::setDimension ( const Dimension  theDimension)
theDimension[in] dimension mode.
See also
getDimension()
◆ setFocalPoint()
void SUIT_CameraProperties::setFocalPoint ( const double  theX,
const double  theY,
const double  theZ
theX[in] x coordinate in world-coordinates space.
theY[in] y coordinate in world-coordinates space.
theZ[in] z coordinate in world-coordinates space.
See also
getFocalPoint()
◆ setMappingScale()
void SUIT_CameraProperties::setMappingScale ( const double  theScale)
theScale[in] the scaling.
See also
getMappingScale()
References myMappingScale, and theScale.
◆ setPosition()
void SUIT_CameraProperties::setPosition ( const double  theX,
const double  theY,
const double  theZ
See also
getPosition()
◆ setProjection()
void SUIT_CameraProperties::setProjection ( const Projection  theProjection)
theProjection[in] projection mode.
See also
getProjection()
◆ setViewAngle()
void SUIT_CameraProperties::setViewAngle ( const double  theViewAngle)
theViewAngle[in] the angle of view.
See also
getViewAngle()
◆ setViewSide()
void SUIT_CameraProperties::setViewSide ( const ViewSide  theViewSide)
theViewSide[in] view side.
See also
getViewSide()
◆ setViewUp()
void SUIT_CameraProperties::setViewUp ( const double  theX,
const double  theY,
const double  theZ
It is recommended to set normalized vector coordinates for synchronization compatibility.
theX[in] vector's x coordinate in world-coordinates space.
theY[in] vector's y coordinate in world-coordinates space.
theZ[in] vector's z coordinate in world-coordinates space.
See also
getViewUp()
References myUpDir.
◆ myAxialScale
double SUIT_CameraProperties::myAxialScale[3]
◆ myDimension
Dimension SUIT_CameraProperties::myDimension
dimension
◆ myFocalPoint
double SUIT_CameraProperties::myFocalPoint[3]
◆ myMappingScale
double SUIT_CameraProperties::myMappingScale
◆ myPosition
double SUIT_CameraProperties::myPosition[3]
◆ myProjection
Projection SUIT_CameraProperties::myProjection
◆ myUpDir
double SUIT_CameraProperties::myUpDir[3]
camera up vector
◆ myViewAngle
double SUIT_CameraProperties::myViewAngle
◆ myViewSide
ViewSide SUIT_CameraProperties::myViewSide
