SalomeApp_DataObject.h
23// File : SalomeApp_DataObject.h
24// Author : Vadim SANDLER, Open CASCADE S.A.S. (vadim.sandler@opencascade.com)
26#ifndef SALOMEAPP_DATAOBJECT_H
27#define SALOMEAPP_DATAOBJECT_H
28
29#include "SalomeApp.h"
30#include <LightApp_DataObject.h>
31#include <SALOMEDSClient.hxx>
32
33class SalomeApp_Study;
34
36{
37
38public:
40 enum {
41 ValueId = RefEntryId + 1,
43 LastId
44 };
45
46public:
48 SalomeApp_DataObject( const _PTR(SObject)&, SUIT_DataObject* = 0 );
49 virtual ~SalomeApp_DataObject();
50
51 virtual QString name() const;
52 virtual QString entry() const;
53
54 virtual QString text( const int = NameId ) const;
55 virtual QPixmap icon( const int = NameId ) const;
56 virtual QColor color( const ColorRole, const int = NameId ) const;
57 virtual QString toolTip( const int = NameId ) const;
58 virtual QFont font( const int = NameId ) const;
59
60 virtual _PTR(SObject) object() const;
61
62 virtual QString refEntry() const;
63 virtual bool isReference() const;
64 _PTR(SObject) referencedObject() const;
65
66 bool hasChildren() const;
67 bool expandable() const;
68
69 virtual bool isVisible() const;
70
71 virtual QString componentDataType() const;
72
73 virtual bool customSorting( const int = NameId ) const;
74 virtual bool compare( const QVariant&, const QVariant&, const int = NameId ) const;
75
77 virtual void updateItem();
78
79private:
80 QString ior( const _PTR(SObject)& ) const;
81 QString entry( const _PTR(SObject)& ) const;
82 QString value( const _PTR(SObject)& ) const;
83
84private:
85 _PTR(SObject) myObject;
86};
87
89 public CAM_ModuleObject
90{
91public:
93 SalomeApp_ModuleObject( const _PTR(SObject)&, SUIT_DataObject* = 0 );
96
97 virtual QString name() const;
98 QPixmap icon( const int = NameId ) const;
99 QString toolTip( const int = NameId ) const;
100};
101
104{
105public:
107 virtual ~SalomeApp_RootObject();
108
109 QString name() const;
110 QString entry() const;
111 QString text( const int = NameId ) const;
112 QPixmap icon( const int = NameId ) const;
113 QColor color( const ColorRole, const int = NameId ) const;
114 QString toolTip( const int = NameId ) const;
115 void setToSynchronize(bool value){_toSynchronize=value;};
116 bool toSynchronize() const {return _toSynchronize;};
117protected:
119};
120
122{
123public:
126
127 virtual QString name() const;
128 virtual QString entry() const;
129
130 virtual QPixmap icon( const int = NameId ) const;
131 virtual QString toolTip( const int = NameId ) const;
132
133 int getId() const;
134
135private:
136 int myId;
138};
139
141{
142public:
144
145 virtual QString name() const;
146 virtual QString toolTip( const int = NameId ) const;
147};
148
149#endif
#define SALOMEAPPIMPL_EXPORT
Definition: SalomeApp.h:55
_PTR(Study) SalomeApp_Application
Definition: SalomeApp_Application.cxx:1356
Base class for all data models used in CAM-based applications.
Definition: CAM_DataModel.h:37
CAM data model root object.
Definition: CAM_DataObject.h:44
Base data object class to build the data model for all the SALOME modules.
Definition: LightApp_DataObject.h:36
virtual QString text(const int=NameId) const
Get object text data for the specified column.
Definition: LightApp_DataObject.cxx:296
virtual QColor color(const ColorRole, const int=NameId) const
Get data object color for the specified column.
Definition: LightApp_DataObject.cxx:330
Get component type.
Definition: LightApp_DataObject.cxx:392
Get object string identifier.
Definition: LightApp_DataObject.cxx:243
Root data object for the light (without CORBA) SALOME application.
Definition: LightApp_DataObject.h:95
Definition: LightApp_Study.h:67
Data object representing the data instance in the tree-like hierarchy.
Definition: SUIT_DataObject.h:49
virtual QPixmap icon(const int=NameId) const
Get data object icon for the specified column.
Definition: SUIT_DataObject.cxx:487
Get data object name.
Definition: SUIT_DataObject.cxx:454
virtual QString toolTip(const int=NameId) const
Get data object tooltip for the specified column.
Definition: SUIT_DataObject.cxx:521
ColorRole
Color role.
Definition: SUIT_DataObject.h:54
virtual QFont font(const int=NameId) const
Get data object font for the specified column.
Definition: SUIT_DataObject.cxx:570
Implementation of the data object for use in CORBA-based SALOME modules.
Definition: SalomeApp_DataObject.h:36
QString value(const _PTR(SObject)&) const
@ IORId
IOR column.
Definition: SalomeApp_DataObject.h:42
virtual bool compare(const QVariant &, const QVariant &, const int=NameId) const
Compares data from two items for sorting purposes.
Returns the string identifier of the data objects referenced by this one.
Tells if this data objects is a reference to some other or not.
QString ior(const _PTR(SObject)&) const
virtual void insertChildAtTag(SalomeApp_DataObject *, int)
QString entry(const _PTR(SObject)&) const
Check if the object is visible.
virtual bool customSorting(const int=NameId) const
Check if the specified column supports custom sorting.
This class is used for optimized access to the SALOMEDS-based data model from SalomeApp_DataObject cl...
Definition: SalomeApp_DataObject.h:90
Root data object for the CORBA-based SALOME application.
Definition: SalomeApp_DataObject.h:104
Definition: SalomeApp_DataObject.h:115
Definition: SalomeApp_DataObject.h:116
bool _toSynchronize
Definition: SalomeApp_DataObject.h:118
Represents persistent visual_state object.
Definition: SalomeApp_DataObject.h:122
SalomeApp_Study * myStudy
Definition: SalomeApp_DataObject.h:137
int myId
Definition: SalomeApp_DataObject.h:136
Represents parent object for visual_state objects.
Definition: SalomeApp_DataObject.h:141
Definition: SalomeApp_Study.h:37
