CAM_DataModel Class Reference
Base class for all data models used in CAM-based applications. More...
#include <CAM_DataModel.h>
Inheritance diagram for CAM_DataModel:
Signals
void rootChanged (const CAM_DataModel *)
 Emitted when the root data object is changed. More...
 CAM_DataModel (CAM_Module *)
virtual ~CAM_DataModel ()
virtual void initialize ()
 Initialize data model. More...
CAM_DataObject * root () const
 Get data model root object. More...
CAM_Module * module () const
 Get module. More...
virtual bool open (const QString &, CAM_Study *, QStringList)
 Load data model. More...
virtual bool save (QStringList &)
 Save data model. More...
virtual bool saveAs (const QString &, CAM_Study *, QStringList &)
 Save data to the new file. More...
virtual bool close ()
 Close data model. More...
virtual bool create (CAM_Study *)
 Create empty data model. More...
void setIsAutoSaving (const bool on=true)
bool isAutoSaving () const
virtual void setRoot (const CAM_DataObject *)
 Set data model root object. More...
Private Slots
void onDestroyed (SUIT_DataObject *)
 Called when data object is destroyed. More...
CAM_DataObject * myRoot
 root data object More...
CAM_Module * myModule
 module More...
bool myIsAutoSaving
 whether the data model is being saved automatically More...
Represents data model of the CAM module. Provides necessary interface (default implementation is empty).
◆ CAM_DataModel()
CAM_DataModel::CAM_DataModel ( CAM_Module *  module)
Initialise data module by specified module.
◆ ~CAM_DataModel()
CAM_DataModel::~CAM_DataModel ( )
Does nothing.
◆ close()
bool CAM_DataModel::close ( )
Close data model.
This method should be re-implemented in the successor classes. Default implementation returns true.
true if data model is closed successfully
Reimplemented in LightApp_DataModel, and SALOME_PYQT_DataModelLight.
◆ create()
bool CAM_DataModel::create ( CAM_Study *  )
true if data model is created successfully
Reimplemented in SALOME_PYQT_DataModelLight, and SalomeApp_DataModel.
◆ initialize()
void CAM_DataModel::initialize ( )
This method should be re-implemented in the successor classes and can be used for creation of root data object. Default implementation does nothing.
◆ isAutoSaving()
bool CAM_DataModel::isAutoSaving ( ) const
c true - if data model is auto saving, else false.
References myIsAutoSaving.
◆ module()
CAM_Module * CAM_DataModel::module ( ) const
Get module.
module owning this data model
References myModule.
◆ onDestroyed
void CAM_DataModel::onDestroyed ( SUIT_DataObject *  obj)
privateslot
Nullifies the root object if it is detroyed to avoid crashes.
objobject being destroyed
References myRoot.
◆ open()
bool CAM_DataModel::open ( const QString &  ,
CAM_Study *  ,
QStringList
Load data model.
namestudy name
studystudy
fileslist of file names from which data should be loaded
true if data model is loaded successfully
Reimplemented in LightApp_DataModel, SALOME_PYQT_DataModelLight, and SalomeApp_DataModel.
◆ root()
CAM_DataObject * CAM_DataModel::root ( ) const
root object
See also
setRoot()
References myRoot.
◆ rootChanged
void CAM_DataModel::rootChanged ( const CAM_DataModel *  root)
signal
rootnew root data object
◆ save()
bool CAM_DataModel::save ( QStringList &  )
Save data model.
fileslist of file names to which data should be saved
true if data model is saved successfully
◆ saveAs()
bool CAM_DataModel::saveAs ( const QString &  ,
CAM_Study *  ,
QStringList &
namestudy name
studystudy
filesresulting list of file names to which data is saved
◆ setIsAutoSaving()
void CAM_DataModel::setIsAutoSaving ( const bool  on = true)
Set data model auto saving to on.
◆ setRoot()
void CAM_DataModel::setRoot ( const CAM_DataObject *  newRoot)
This method should be used to specify custom root object instance.
Root object can be created in several ways, depending on application or module needs:
  • in initialize() method
  • while the data model is being loaded
  • when the data model is updated and becomes non-empty
If root object is changed, this method emits rootChanged() signal.
newRootnew root object
References SUIT_DataObject::connect(), SUIT_DataObject::disconnect(), myRoot, onDestroyed(), and rootChanged().
◆ myIsAutoSaving
bool CAM_DataModel::myIsAutoSaving
◆ myModule
CAM_Module* CAM_DataModel::myModule
module
◆ myRoot
CAM_DataObject* CAM_DataModel::myRoot
root data object
