LightApp_DataModel Class Reference
#include <LightApp_DataModel.h>
Inheritance diagram for LightApp_DataModel:
Signals
void opened ()
void saved ()
void closed ()
- Signals inherited from CAM_DataModel
void rootChanged (const CAM_DataModel *)
 Emitted when the root data object is changed. More...
 LightApp_DataModel (CAM_Module *theModule)
virtual ~LightApp_DataModel ()
virtual bool open (const QString &, CAM_Study *, QStringList)
virtual bool save (QStringList &)
virtual bool saveAs (const QString &, CAM_Study *, QStringList &)
virtual bool close ()
virtual bool dumpPython (const QString &, CAM_Study *, bool, QStringList &)
virtual void update (LightApp_DataObject *=0, LightApp_Study *=0)
virtual bool isSaved () const
LightApp_Module * getModule () const
int groupId () const
void registerColumn (SUIT_DataBrowser *, const QString &, const int)
void unregisterColumn (SUIT_DataBrowser *, const QString &)
virtual void initRootObject ()
 For initialization of the data model and registration of SComponent when study is created but module was not activated. More...
- Public Member Functions inherited from CAM_DataModel
 CAM_DataModel (CAM_Module *)
virtual ~CAM_DataModel ()
virtual void initialize ()
 Initialize data model. More...
CAM_DataObject * root () const
 Get data model root object. More...
CAM_Module * module () const
 Get module. More...
 Load data model. More...
 Save data model. More...
 Save data to the new file. More...
 Close data model. More...
virtual bool create (CAM_Study *)
 Create empty data model. More...
void setIsAutoSaving (const bool on=true)
bool isAutoSaving () const
LightApp_Study * getStudy () const
virtual void build ()
virtual void updateWidgets ()
virtual CAM_ModuleObject * createModuleObject (SUIT_DataObject *theRoot) const
- Protected Member Functions inherited from CAM_DataModel
virtual void setRoot (const CAM_DataObject *)
 Set data model root object. More...
int myGroupId
Description : Base class of data model
◆ LightApp_DataModel()
LightApp_DataModel::LightApp_DataModel ( CAM_Module *  theModule)
Constructor
References CAM_DataModel::module(), and myGroupId.
◆ ~LightApp_DataModel()
LightApp_DataModel::~LightApp_DataModel ( )
Destructor
◆ build()
void LightApp_DataModel::build ( )
Build whole data model tree
◆ close()
bool LightApp_DataModel::close ( )
Emit closed()
Reimplemented from CAM_DataModel.
Reimplemented in SALOME_PYQT_DataModelLight.
References closed().
◆ closed
void LightApp_DataModel::closed ( )
signal
◆ createModuleObject()
CAM_ModuleObject * LightApp_DataModel::createModuleObject ( SUIT_DataObject *  theRoot) const
Creates the data model's root (module object) using the study services. This is important because different study classes use different moduel object classes. Therefore creation of the module object cannot be done at the data model level where the type of the current study instance should not be known. The module object returned by this method should be then passed to the model's setRoot().
the module object instance corresponding to the study type
See also
CAM_DataModel class
References LightApp_Study::createModuleObject(), and LightApp_RootObject::study().
◆ dumpPython()
bool LightApp_DataModel::dumpPython ( const QString &  ,
CAM_Study *  ,
bool  ,
QStringList &
Does nothing by default. Should be redefined in light modules that want to participate in "Dump study" operation.
◆ getModule()
LightApp_Module * LightApp_DataModel::getModule ( ) const
corresponding module
References CAM_DataModel::module().
◆ getStudy()
LightApp_Study * LightApp_DataModel::getStudy ( ) const
corresponding study
References CAM_DataModel::root(), SUIT_DataObject::root(), and LightApp_RootObject::study().
◆ groupId()
int LightApp_DataModel::groupId ( ) const
data model group id used for custom columns creation
References myGroupId.
◆ initRootObject()
virtual void LightApp_DataModel::initRootObject ( )
◆ isModified()
bool LightApp_DataModel::isModified ( ) const
default implementation, always returns false so as not to mask study's isModified()
◆ isSaved()
bool LightApp_DataModel::isSaved ( ) const
default implementation, always returns true so as not to mask study's isSaved()
◆ open()
bool LightApp_DataModel::open ( const QString &  ,
CAM_Study *  ,
QStringList
Emit opened()
Reimplemented in SALOME_PYQT_DataModelLight, and SalomeApp_DataModel.
References opened().
◆ opened
void LightApp_DataModel::opened ( )
signal
◆ registerColumn()
void LightApp_DataModel::registerColumn ( SUIT_DataBrowser *  browser,
const QString &  name,
const int  custom_id
Register custom column in the object browser
browser- object browser where new column should be created
name- translated column name
custom_id- custom column identificator passed into data object's methods text(), icon() etc
References groupId(), OB_Browser::model(), and SUIT_AbstractModel::registerColumn().
◆ save()
bool LightApp_DataModel::save ( QStringList &  )
Emit saved()
References saved().
◆ saveAs()
bool LightApp_DataModel::saveAs ( const QString &  ,
CAM_Study *  ,
QStringList &
Emit saved()
References CAM_DataModel::isAutoSaving(), and saved().
◆ saved
void LightApp_DataModel::saved ( )
signal
◆ unregisterColumn()
void LightApp_DataModel::unregisterColumn ( SUIT_DataBrowser *  browser,
Remove registered custom column from the object browser
References groupId(), OB_Browser::model(), and SUIT_AbstractModel::unregisterColumn().
◆ update()
void LightApp_DataModel::update ( LightApp_DataObject *  = 0,
LightApp_Study *  = 0
Default behaviour of data model update for light modules
References build(), SUIT_DataObject::children(), CAM_DataModel::root(), and updateWidgets().
◆ updateWidgets()
void LightApp_DataModel::updateWidgets ( )
Updates data model presentation in some widgets (for example, in object browser
References CAM_Module::application(), CAM_DataModel::module(), LightApp_Application::objectBrowser(), and SUIT_DataBrowser::updateTree().
◆ myGroupId
int LightApp_DataModel::myGroupId
