OB_Browser Class Reference
Object browser widget which can be used to handle tree-like data model. More...
#include <OB_Browser.h>
Inheritance diagram for OB_Browser:
typedef QMap< QString, bool > MapOfOpenStates
Signals
void selectionChanged ()
 Emitted when selection is changed in the Object Browser. More...
 OB_Browser (QWidget *=0, QAbstractItemModel *=0)
virtual ~OB_Browser ()
QAbstractItemModel * model () const
 Get data model. More...
void setModel (QAbstractItemModel *)
 Set data model. More...
QAbstractItemDelegate * itemDelegate () const
 Get current item delegate (items renderer). More...
void setItemDelegate (QAbstractItemDelegate *)
 Set item delegate (items renderer). More...
bool rootIsDecorated () const
 Check if controls for expanding and collapsing top-level items are shown. More...
void setRootIsDecorated (const bool)
 Show/hide controls for expanding and collapsing top-level items. More...
bool sortMenuEnabled () const
void setSortMenuEnabled (const bool)
QtxSearchTool * searchTool () const
 Get search tool widget. More...
bool isSearchToolEnabled () const
 Check if search tool is enabled. More...
void setSearchToolEnabled (const bool)
 Enable/disable search tool. More...
int autoOpenLevel () const
 Get number of levels which should be automatically expanded when updating the data tree. More...
void setAutoOpenLevel (const int)
 Set number of levels which should be automatically expanded when updating the data tree. More...
void openLevels (const int=-1)
 Expand all branches to the specified number of levels. More...
int numberOfSelected () const
 Get number of selected items. More...
QModelIndexList selectedIndexes () const
 Get all selected items. More...
const QItemSelection selection () const
 Get selection containing information about selected ranges. More...
virtual void select (const QModelIndex &, const bool, const bool=true)
 Select/deselect specified model index. More...
virtual void select (const QModelIndexList &, const bool, const bool=true)
 Select/deselect specified model indices. More...
bool isOpen (const QModelIndex &) const
 Check if specified model index is expanded or collapsed. More...
virtual void setOpen (const QModelIndex &theObject, const bool theOpen=true)
 Expand/collapse the specified model index. More...
void adjustWidth ()
 Adjust first column width to its contents. More...
void adjustFirstColumnWidth ()
void adjustColumnsWidth ()
 Adjust all columns width to its contents except the first column. More...
unsigned long getModifiedTime () const
 Get the time of the latest updating. More...
void setModified ()
 Update the time of the latest updating. More...
QtxTreeView * treeView () const
 Get tree view widget. More...
QByteArray getOpenStates (int theColumn) const
void setOpenStates (const QByteArray &, int theColumn)
void openStates (bool isGet, MapOfOpenStates &, const QModelIndex &theIndex, int theColumn)
virtual void contextMenuEvent (QContextMenuEvent *)
 Process context menu request event. More...
virtual void createPopupMenu (QMenu *)
 Add custom actions to the popup menu. More...
Private Slots
void onExpandAll ()
 Called when "Expand all" popup menu command is activated. More...
void onCollapseAll ()
 Called when "Collapse all" popup menu command is activated. More...
virtual void onExpanded (const QModelIndex &)
bool hasCollased (const QModelIndex &) const
 Check if model index is collapsed or has collapsed children. More...
bool hasExpanded (const QModelIndex &) const
 Check if model index is expanded or has expanded children. More...
QtxTreeView * myView
QtxSearchTool * mySearchTool
int myAutoOpenLevel
unsigned long myModifiedTime
Constructor
Destructor
It is called when there is a possibility that a tool tip should be shown and must decide whether there is a tool tip for the point in the widget that this QToolTip object relates to.
pos- point co-ordinates
The class OB_Browser implements public API of an object browser widget that can be used to display arbitrary application data in a hierarchical form. It is based on Qt4 model/view architecture.
Object browser can be used with conjuction of any custom item model inherited from QAbstractItemModel class (see Qt 4 reference manual).
The class provides a functionality get/modify selection, drag-n-drop of the objects, etc.
◆ MapOfOpenStates
typedef QMap<QString, bool> OB_Browser::MapOfOpenStates
◆ OB_Browser()
OB_Browser::OB_Browser ( QWidget *  parent = 0,
QAbstractItemModel *  model = 0
◆ ~OB_Browser()
OB_Browser::~OB_Browser ( )
◆ adjustColumnsWidth()
void OB_Browser::adjustColumnsWidth ( )
References myView, and QtxTreeView::resizeColumnToEncloseContents().
◆ adjustFirstColumnWidth()
void OB_Browser::adjustFirstColumnWidth ( )
◆ adjustWidth()
void OB_Browser::adjustWidth ( )
◆ autoOpenLevel()
int OB_Browser::autoOpenLevel ( ) const
number of levels to be auto-opened on tree updating
See also
setAutoOpenLevel()
References myAutoOpenLevel.
◆ contextMenuEvent()
void OB_Browser::contextMenuEvent ( QContextMenuEvent *  e)
econtext menu event
Reimplemented in SUIT_DataBrowser.
References createPopupMenu(), and Qtx::simplifySeparators().
◆ createPopupMenu()
void OB_Browser::createPopupMenu ( QMenu *  menu)
SLOT: called if SUIT object is destroyed
SLOT: called on finish of drag-n-drop operation
items- dragged items
item- destination (item on that they were dropped)
action- QDropEvent::Action
Updates texts of items
true if item must be updated
item- item to be checked
item- item to be updated
menupopup menu
References hasCollased(), hasExpanded(), isSearchToolEnabled(), onCollapseAll(), onExpandAll(), searchTool(), and selectedIndexes().
◆ getModifiedTime()
unsigned long OB_Browser::getModifiedTime ( ) const
latest updating time
References myModifiedTime.
◆ getOpenStates()
QByteArray OB_Browser::getOpenStates ( int  theColumn) const
References openStates().
◆ hasCollased()
bool OB_Browser::hasCollased ( const QModelIndex &  index) const
Expands item with all it's children
true if item or one of its children is collapsed
References hasCollased(), model(), and myView.
◆ hasExpanded()
bool OB_Browser::hasExpanded ( const QModelIndex &  index) const
true if item or one of its children is expanded
References hasExpanded(), model(), and myView.
◆ isOpen()
bool OB_Browser::isOpen ( const QModelIndex &  index) const
indexmodel index
true if model index is expanded
See also
setOpen()
References model(), and myView.
◆ isSearchToolEnabled()
bool OB_Browser::isSearchToolEnabled ( ) const
true if search tool is enabled
See also
setSearchToolEnabled(), searchTool()
References mySearchTool.
◆ itemDelegate()
QAbstractItemDelegate * OB_Browser::itemDelegate ( ) const
currently used item delegate
See also
setItemDelegate()
References myView.
◆ model()
QAbstractItemModel * OB_Browser::model ( ) const
Get data model.
data model
See also
setModel()
References myView.
◆ numberOfSelected()
int OB_Browser::numberOfSelected ( ) const
state "are tooltips shown"
Sets new value of state "are tooltips shown"
theDisplay- new value
References myView.
◆ onCollapseAll
void OB_Browser::onCollapseAll ( )
privateslot
Collapse all selected items recursively.
References QtxTreeView::collapseAll(), myView, and selectedIndexes().
◆ onExpandAll
void OB_Browser::onExpandAll ( )
privateslot
Expands all selected items recursively.
References QtxTreeView::expandAll(), myView, onExpanded(), selectedIndexes(), and treeView().
◆ onExpanded
virtual void OB_Browser::onExpanded ( const QModelIndex &  )
inlineprivatevirtualslot
◆ openLevels()
void OB_Browser::openLevels ( const int  levels = -1)
If levels value is negative, then autoOpenLevel() value is used instead.
levelsnumber of levels to be expanded
See also
autoOpenLevel()
References autoOpenLevel(), QtxTreeView::expandLevels(), and myView.
◆ openStates()
void OB_Browser::openStates ( bool  isGet,
MapOfOpenStates &  theMap,
const QModelIndex &  theIndex,
int  theColumn
◆ rootIsDecorated()
bool OB_Browser::rootIsDecorated ( ) const
true if top-level items are decorated
See also
setRootIsDecorated()
References myView.
◆ searchTool()
QtxSearchTool * OB_Browser::searchTool ( ) const
search tool widget
See also
isSearchToolEnabled(), setSearchToolEnabled()
◆ select() [1/2]
void OB_Browser::select ( const QModelIndex &  index,
const bool  on,
const bool  keepSelection = true
indexmodel index to be selected/deselected
onif true, the index will be selected, otherwise - deselected
keepSelectionif true (default) the previous selection is kept, otherwise it is first cleared
References myView.
◆ select() [2/2]
void OB_Browser::select ( const QModelIndexList &  indexes,
const bool  on,
indexesmodel indices to be selected/deselected
onif true, the indices will be selected, otherwise - deselected
References myView, and selectionChanged().
◆ selectedIndexes()
QModelIndexList OB_Browser::selectedIndexes ( ) const
unsorted list of selected indexes with no duplicates
References myView.
◆ selection()
const QItemSelection OB_Browser::selection ( ) const
QItemSelection instance
References myView.
◆ selectionChanged
void OB_Browser::selectionChanged ( )
signal
Removes SUIT object
obj- SUIT object to be removed
autoUpd- auto tree updating
Opens branches from 1 to autoOpenLevel()
See also
autoOpenLevel()
Opens branch
item
level
SLOT: called on double click on item, emits signal
◆ setAutoOpenLevel()
void OB_Browser::setAutoOpenLevel ( const int  levels)
levelsnumber of levels to be auto-opened on tree updating
See also
autoOpenLevel()
◆ setItemDelegate()
void OB_Browser::setItemDelegate ( QAbstractItemDelegate *  d)
dcustom item delegate
See also
itemDelegate()
References myView.
◆ setModel()
void OB_Browser::setModel ( QAbstractItemModel *  model)
Set data model.
modeldata model
See also
model()
References model(), myView, QtxTreeView::setModel(), and setModified().
◆ setModified()
void OB_Browser::setModified ( )
◆ setOpen()
void OB_Browser::setOpen ( const QModelIndex &  index,
const bool  open = true
indexmodel index
openif true, the index will be expanded, otherwse - collapsed
See also
isOpen()
References myView.
◆ setOpenStates()
void OB_Browser::setOpenStates ( const QByteArray &  theData,
int  theColumn
References isOpen(), and openStates().
◆ setRootIsDecorated()
void OB_Browser::setRootIsDecorated ( const bool  decor)
decorif true, top-level items are decorated
See also
rootIsDecorated()
References myView, and rootIsDecorated().
◆ setSearchToolEnabled()
void OB_Browser::setSearchToolEnabled ( const bool  enable)
enablepass true to enable search tool
See also
isSearchToolEnabled(), searchTool()
◆ setSortMenuEnabled()
void OB_Browser::setSortMenuEnabled ( const bool  enabled)
◆ sortMenuEnabled()
bool OB_Browser::sortMenuEnabled ( ) const
◆ treeView()
QtxTreeView * OB_Browser::treeView ( ) const
SUIT object correspondint to item at position 'pos'
pos- position
filter of list view
Changes filter of list view
f- new filter
Sets global width mode
mode- new width mode
Updates tree
obj- start object
autoOpen- to open automatically branches of autoOpenLevel()
See also
autoOpenLevel()
Replaces part of tree starting at object 'src' by tree starting at object 'trg'
Adjusts width by item
item
\remove all items referencing current (through data objects)
Connects all children to SLOT onDestroyed
Disconnects all children from SLOT onDestroyed
Stores states (opened, selected) of current tree items
current item
selObjs,selKeys- maps of selected objects
openObjs,openKeys- maps of opened objects
curKey- map of current objects
Restores states (opened, selected) of current tree items
Creates object key by tree item
Creates object key by SUIT object
tree view widget of the object browser
References myView.
◆ myAutoOpenLevel
int OB_Browser::myAutoOpenLevel
◆ myModifiedTime
unsigned long OB_Browser::myModifiedTime
◆ mySearchTool
QtxSearchTool* OB_Browser::mySearchTool
◆ myView
QtxTreeView* OB_Browser::myView
