CAM_Study Class Reference
Represents document object in the CAM application architecture. More...
#include <CAM_Study.h>
Inheritance diagram for CAM_Study:
typedef QList< CAM_DataModel * > ModelList
 CAM_Study (SUIT_Application *)
virtual ~CAM_Study ()
virtual void closeDocument (bool permanently=true)
 Called when study is closed. More...
bool appendDataModel (const CAM_DataModel *)
 Append data model to the study. More...
virtual bool insertDataModel (const CAM_DataModel *, const int=-1)
 Insert data model dm with index idx. More...
bool insertDataModel (const CAM_DataModel *, const CAM_DataModel *)
 Insert data model dm after data model other. More...
virtual bool removeDataModel (const CAM_DataModel *)
 Remove data model from the study. More...
bool containsDataModel (const CAM_DataModel *) const
 Check if data model is contained in the list. More...
void dataModels (ModelList &) const
 Get all data models. More...
- Public Member Functions inherited from SUIT_Study
 SUIT_Study (SUIT_Application *)
virtual ~SUIT_Study ()
virtual int id () const
virtual QString studyName () const
SUIT_Application * application () const
virtual bool isSaved () const
virtual void Modified ()
virtual void closeDocument (bool=true)
virtual bool openDocument (const QString &)
virtual bool createDocument (const QString &)
bool saveDocument ()
virtual bool saveDocumentAs (const QString &)
virtual void update ()
virtual void sendChangesNotification ()
void setIsAutoSaving (const bool on=true)
bool isAutoSaving () const
SUIT_Operation * activeOperation () const
virtual void abortAllOperations ()
const QList< SUIT_Operation * > & operations () const
 Get all started operations. More...
virtual SUIT_Operation * blockingOperation (SUIT_Operation *) const
 Verifies whether operation can be activated above already started ones. More...
bool start (SUIT_Operation *, const bool check=true)
 Starts operation. More...
bool abort (SUIT_Operation *)
 Aborts operation. More...
bool commit (SUIT_Operation *)
 Commits operation. More...
bool suspend (SUIT_Operation *)
bool resume (SUIT_Operation *)
 Resumes operation. More...
virtual void restoreState (int savePoint)
 Restores the study state. More...
Protected Slots
virtual void updateModelRoot (const CAM_DataModel *)
 Update data model root object. More...
virtual void dataModelInserted (const CAM_DataModel *)
 Called when data model is inserted in the study. More...
virtual bool openDataModel (const QString &, CAM_DataModel *)
 Called when data model is opened. More...
virtual bool saveDataModel (const QString &, CAM_DataModel *)
 Called when data model is saved. More...
- Protected Member Functions inherited from SUIT_Study
virtual void setIsSaved (const bool)
virtual void setIsModified (const bool)
virtual void setRoot (SUIT_DataObject *)
virtual void setStudyName (const QString &)
virtual void operationStarted (SUIT_Operation *)
 Perform some actions when operation starting. More...
virtual void operationAborted (SUIT_Operation *)
 Perform some actions when operation aborted. More...
virtual void operationStopped (SUIT_Operation *)
 Perform some actions when operation stopped. More...
virtual void operationCommited (SUIT_Operation *)
 Perform some actions when operation commited. More...
virtual bool openTransaction ()
 Opens transaction for data modifications. More...
virtual bool abortTransaction ()
 Aborts transaction and all performed data modifications. More...
virtual bool hasTransaction () const
 Returns true if transaction is opened. More...
virtual bool commitTransaction (const QString &=QString())
 Commits transaction and all performed data modifications. More...
ModelList myDataModels
 data models list More...
- Signals inherited from SUIT_Study
void studyModified (SUIT_Study *)
For each loaded module study contains the data model instance reference. Provides all necessary functionality for data models management.
◆ ModelList
◆ CAM_Study()
CAM_Study::CAM_Study ( SUIT_Application *  app)
appparent application
◆ ~CAM_Study()
CAM_Study::~CAM_Study ( )
◆ appendDataModel()
bool CAM_Study::appendDataModel ( const CAM_DataModel *  dm)
dmdata model being added
true on success and false on error
References insertDataModel(), and myDataModels.
◆ closeDocument()
void CAM_Study::closeDocument ( bool  permanently = true)
Closes all data models.
permanentlyif true close study permanently (not used in the base implemetation)
Reimplemented from SUIT_Study.
Reimplemented in LightApp_Study, and SalomeApp_Study.
References SUIT_Study::closeDocument(), and myDataModels.
◆ containsDataModel()
bool CAM_Study::containsDataModel ( const CAM_DataModel *  dm) const
dmdata model
true if data model is in the list and false otherwise.
References myDataModels.
◆ dataModelInserted()
void CAM_Study::dataModelInserted ( const CAM_DataModel *  dModel)
Open data model dModel, if it is saved and update data tree.
dModeldata model
Reimplemented in SalomeApp_Study.
References CAM_DataModel::create(), SUIT_Study::isSaved(), openDataModel(), SUIT_Study::studyName(), and updateModelRoot().
◆ dataModels()
void CAM_Study::dataModels ( ModelList &  lst) const
lstreturning list of data model.
◆ insertDataModel() [1/2]
bool CAM_Study::insertDataModel ( const CAM_DataModel *  dm,
const CAM_DataModel *  other
If other is 0, the data model is added to the end of list.
otherdata model to be previous in the list
◆ insertDataModel() [2/2]
const int  idx = -1
idxdata model required index
References dataModelInserted(), myDataModels, and updateModelRoot().
◆ openDataModel()
bool CAM_Study::openDataModel ( const QString &  ,
CAM_DataModel *
Base implementation does nothing and returns false.
◆ removeDataModel()
bool CAM_Study::removeDataModel ( const CAM_DataModel *  dm)
dmdata model being removed
References myDataModels, CAM_DataModel::root(), and CAM_ModuleObject::setDataModel().
◆ saveDataModel()
bool CAM_Study::saveDataModel ( const QString &  ,
CAM_DataModel *
◆ updateModelRoot
void CAM_Study::updateModelRoot ( const CAM_DataModel *  dm)
protectedvirtualslot
◆ myDataModels
ModelList CAM_Study::myDataModels
data models list
