SUIT_Operation Class Reference
Base class for all operations. More...
#include <SUIT_Operation.h>
Inheritance diagram for SUIT_Operation:
enum  OperationState { Waiting , Running , Suspended }
enum  ExecStatus { Rejected , Accepted }
enum  Flags { None = 0x00 , Transaction = 0x01 }
Public Slots
void start ()
 Starts operation. More...
void abort ()
 Aborts operation. More...
void commit ()
 Commits operation. More...
void resume ()
 Resumes operation. More...
void suspend ()
 Suspend operation. More...
Signals
void started (SUIT_Operation *)
void aborted (SUIT_Operation *)
void committed (SUIT_Operation *)
void stopped (SUIT_Operation *)
void resumed (SUIT_Operation *)
void suspended (SUIT_Operation *)
void callSlot ()
 SUIT_Operation (SUIT_Application *)
virtual ~SUIT_Operation ()
OperationState state () const
 Gets state of operation. More...
bool isActive () const
 Verifies whether operation is an active for study. More...
bool isRunning () const
 Verifies whether operation is an runned one (state()==Running) More...
SUIT_Study * study () const
 Returns operation study. More...
virtual void setStudy (SUIT_Study *theStudy)
 Sets operation study. More...
SUIT_Application * application () const
 Gets application. More...
virtual void setApplication (SUIT_Application *theApp)
 Sets application. More...
virtual bool isValid (SUIT_Operation *theOtherOp) const
virtual bool isGranted () const
 Verifies whether this operator can be always started above any already runnig one. More...
bool setSlot (const QObject *theReceiver, const char *theSlot)
 Sets slot which is called when operation is started. More...
void setFlags (const int)
 Sets the flags of operation. More...
void clearFlags (const int)
 Clears the flags of operation. More...
bool testFlags (const int) const
 Test the flags of operation. More...
virtual QString operationName () const
 Name of the operation. More...
int execStatus () const
 Gets execution status. More...
 Verifies whether operator is ready to start. More...
virtual void stopOperation ()
 Virtual method called when operation is started. More...
 Virtual method called when operation aborted. More...
 Virtual method called when operation committed. More...
virtual void resumeOperation ()
 Virtual method called when operation resumed. More...
virtual void suspendOperation ()
 Virtual method called when operation suspended. More...
virtual bool openTransaction ()
 Opens transaction for data modifications. More...
virtual bool abortTransaction ()
 Aborts transaction and all performed data modifications. More...
virtual bool hasTransaction () const
 Returns true if transaction is opened. More...
virtual bool commitTransaction (const QString &=QString())
 Commits transaction and all performed data modifications. More...
void setExecStatus (const int)
 Sets execution status. More...
void setState (const OperationState)
 Sets state of operation. More...
void start (SUIT_Operation *, const bool=false)
 Starts operator above this one. More...
Private Types
typedef QPointer< SUIT_Study > StudyPtr
SUIT_Application * myApp
 application for this operation More...
int myFlags
 operation flags More...
StudyPtr myStudy
 study for this operation More...
OperationState myState
 Operation state. More...
ExecStatus myExecStatus
 Execution status. More...
Friends
class SUIT_Study
Base class for all operations. If you perform an action it is reasonable to create operation intended for this. This is a base class for all operations which provides mechanism for correct starting operations, starting operations above already started ones, committing operations and so on. To create own operation it is reasonable to inherit it from this class and redefines virtual methods to provide own behavior Main virtual methods are
◆ StudyPtr
typedef QPointer<SUIT_Study> SUIT_Operation::StudyPtr
◆ ExecStatus
Enum describes execution status of operation. Execution status often used after ending work of operation which was started from this one. In this case this operation can ask previously started operation whether it finished successfully.
Rejected
Operation has not performed any action (modification of data model for example)
Accepted
Operation has performed an actions and must be stopped.
◆ Flags
Enum describes setting of the operation.
None
None options.
Transaction
Automatically open (commit/abort) transaction during start (commit/abort).
◆ OperationState
Enum describes state of operation
Waiting
Operation is not used (it is not run or suspended)
Running
Operation is started.
Suspended
Operation is started but suspended (other operation is performed above it)
◆ SUIT_Operation()
SUIT_Operation::SUIT_Operation ( SUIT_Application *  app)
SUIT_Application- application for this operation
Constructs an empty operation. Constructor should work very fast because many operators may be created after starting application but only several from them may be used. As result this constructor stores given application in myApp field and set Waiting status.
◆ ~SUIT_Operation()
SUIT_Operation::~SUIT_Operation ( )
◆ abort
void SUIT_Operation::abort ( )
slot
Aborts operation.
Public slot. Aborts operation. This slot is not virtual and cannot be redefined. Redefine abortOperation method to change behavior of operation instead
References SUIT_Study::abort(), aborted(), abortOperation(), myState, stopOperation(), stopped(), study(), and Waiting.
◆ aborted
void SUIT_Operation::aborted ( SUIT_Operation *  )
signal
◆ abortOperation()
void SUIT_Operation::abortOperation ( )
Virtual method called when operation aborted (see abort() method for more description)
Reimplemented in LightApp_Operation.
◆ abortTransaction()
bool SUIT_Operation::abortTransaction ( )
References SUIT_Study::abortTransaction(), and study().
◆ application()
SUIT_Application * SUIT_Operation::application ( ) const
Gets application.
Pointer to application
Gets application for this operation
References myApp.
◆ callSlot
void SUIT_Operation::callSlot ( )
signal
◆ clearFlags()
void SUIT_Operation::clearFlags ( const int  f)
f- flags of operation to be cleared
Clears flags of operation (see Flags enumeration)
References myFlags.
◆ commit
void SUIT_Operation::commit ( )
slot
Commits operation.
Public slot. Commits operation. This slot is not virtual and cannot be redefined. Redefine commitOperation method to change behavior of operation instead
References SUIT_Study::commit(), commitOperation(), committed(), myState, stopOperation(), stopped(), study(), and Waiting.
◆ commitOperation()
void SUIT_Operation::commitOperation ( )
Virtual method called when operation committed (see commit() method for more description)
◆ committed
void SUIT_Operation::committed ( SUIT_Operation *  )
signal
◆ commitTransaction()
bool SUIT_Operation::commitTransaction ( const QString &  name = QString())
References SUIT_Study::commitTransaction(), and study().
◆ execStatus()
int SUIT_Operation::execStatus ( ) const
Execution status
References myExecStatus.
◆ hasTransaction()
bool SUIT_Operation::hasTransaction ( ) const
References SUIT_Study::hasTransaction(), and study().
◆ isActive()
bool SUIT_Operation::isActive ( ) const
true if operation is active, false otherwise
Verifies whether operation is an active on. Returns true if this operator is active for study
References SUIT_Study::activeOperation(), and study().
◆ isGranted()
bool SUIT_Operation::isGranted ( ) const
Returns true if current operation must not be checked for ActiveOperation->IsValid( this )
This method must be redefined in derived operation if operation of derived class must be always can start above any launched one. Default implementation returns false, so it is being checked for IsValid, but some operations may overload IsGranted() In this case they will always start, no matter what operation is running.
◆ isReadyToStart()
bool SUIT_Operation::isReadyToStart ( ) const
true if operation is ready to start
Default implementation returns true. Redefine this method to add own verifications
◆ isRunning()
bool SUIT_Operation::isRunning ( ) const
Verifies whether operation is an running. Returns true if state of operator is Running
References Running, and state().
◆ isValid()
bool SUIT_Operation::isValid ( SUIT_Operation *  theOtherOp) const
theOtherOp- other operation
Returns true if the given operator is valid for this one
Verifies whether given operator is valid for this one (i.e. can be started "above" this operator)
◆ openTransaction()
bool SUIT_Operation::openTransaction ( )
References SUIT_Study::openTransaction(), and study().
◆ operationName()
QString SUIT_Operation::operationName ( ) const
Returns string name of the operation. This name will be used for automatically commited transaction.
◆ resume
void SUIT_Operation::resume ( )
slot
Resumes operation.
Public slot. Resumes operation. This slot is called when operation is resumed after previous suspending. This slot is not virtual and cannot be redefined. Redefine resumeOperation method to change behavior of operation instead
References myState, SUIT_Study::resume(), resumed(), resumeOperation(), Running, and study().
◆ resumed
void SUIT_Operation::resumed ( SUIT_Operation *  )
signal
◆ resumeOperation()
void SUIT_Operation::resumeOperation ( )
Virtual method called when operation resumed (see resume() method for more description)
◆ setApplication()
void SUIT_Operation::setApplication ( SUIT_Application *  theApp)
Sets application.
theApp- application for this operation
References myApp.
◆ setExecStatus()
void SUIT_Operation::setExecStatus ( const int  theVal)
theStatus- execution status
Sets myExecStatus to the given value
◆ setFlags()
void SUIT_Operation::setFlags ( const int  f)
f- flags of operation to be set
Sets flags of operation (see Flags enumeration)
References myFlags.
◆ setSlot()
bool SUIT_Operation::setSlot ( const QObject *  theReceiver,
const char *  theSlot
theReceiver- object containing slot
theSlot- slot of theReceiver object
true if slot was connected successfully, false otherwise
Sets slot which is called when operation is started. There is no point in using this method. It would be better to inherit own operator from base one and redefine startOperation method
References callSlot().
◆ setState()
void SUIT_Operation::setState ( const  OperationState)
theState- state of operation to be set
Sets state of operation (see OperationState enumeration)
References myState.
◆ setStudy()
void SUIT_Operation::setStudy ( SUIT_Study *  theStudy)
theStudy- study corresponding to this operation
Sets study corresponding to this operation i.e. study which starts this operation.
References myStudy.
◆ start [1/2]
void SUIT_Operation::start ( )
slot
Starts operation.
Public slot. Verifies whether operation can be started and starts operation. This slot is not virtual and cannot be redefined. Redefine startOperation method to change behavior of operation. There is no point in using this method. It would be better to inherit own operator from base one and redefine startOperation method instead.
References SUIT_Study::start(), started(), startOperation(), and study().
◆ start() [2/2]
void SUIT_Operation::start ( SUIT_Operation *  op,
const bool  check = false
theOp- operation to be started
Start operator above this one. Use this method if you want to call other operator from this one
References abort(), start(), SUIT_Study::start(), stopped(), and study().
◆ started
void SUIT_Operation::started ( SUIT_Operation *  )
signal
◆ startOperation()
void SUIT_Operation::startOperation ( )
Virtual method called when operation started (see start() method for more description)
Reimplemented in LightApp_Operation, and LightApp_ShowHideOp.
References callSlot(), and commit().
◆ state()
SUIT_Operation::OperationState SUIT_Operation::state ( ) const
Value from OperationState enumeration
Gets state of operation (see OperationState enumeration)
References myState.
◆ stopOperation()
void SUIT_Operation::stopOperation ( )
Virtual method called when operation stopped - comitted or aborted.
◆ stopped
void SUIT_Operation::stopped ( SUIT_Operation *  )
signal
◆ study()
SUIT_Study * SUIT_Operation::study ( ) const
Pointer to study
Get study corresponding to this operation i.e. study which starts this operation.
References myStudy.
◆ suspend
void SUIT_Operation::suspend ( )
slot
Suspend operation.
Public slot. Suspend operation. This slot is called when operation is suspended (for starting other one, for example) This slot is not virtual and cannot be redefined. Redefine suspendOperation method to change behavior of operation instead
References myState, study(), SUIT_Study::suspend(), Suspended, suspended(), and suspendOperation().
◆ suspended
void SUIT_Operation::suspended ( SUIT_Operation *  )
signal
◆ suspendOperation()
void SUIT_Operation::suspendOperation ( )
Virtual method called when operation suspended (see suspend() method for more description)
◆ testFlags()
bool SUIT_Operation::testFlags ( const int  f) const
f- flags of operation to be tested
Returns true if the specified flags setted in the operation (see Flags enumeration)
References myFlags.
◆ SUIT_Study
friend class SUIT_Study
friend
◆ myApp
SUIT_Application* SUIT_Operation::myApp
◆ myExecStatus
ExecStatus SUIT_Operation::myExecStatus
Execution status.
◆ myFlags
int SUIT_Operation::myFlags
operation flags
◆ myState
OperationState SUIT_Operation::myState
Operation state.
◆ myStudy
StudyPtr SUIT_Operation::myStudy
