SUIT_Study Class Reference
#include <SUIT_Study.h>
Inheritance diagram for SUIT_Study:
Signals
void studyModified (SUIT_Study *)
 SUIT_Study (SUIT_Application *)
virtual ~SUIT_Study ()
virtual int id () const
virtual QString studyName () const
SUIT_Application * application () const
virtual bool isSaved () const
virtual void Modified ()
virtual void closeDocument (bool=true)
virtual bool openDocument (const QString &)
virtual bool createDocument (const QString &)
bool saveDocument ()
virtual bool saveDocumentAs (const QString &)
virtual void update ()
virtual void sendChangesNotification ()
void setIsAutoSaving (const bool on=true)
bool isAutoSaving () const
SUIT_Operation * activeOperation () const
virtual void abortAllOperations ()
const QList< SUIT_Operation * > & operations () const
 Get all started operations. More...
virtual SUIT_Operation * blockingOperation (SUIT_Operation *) const
 Verifies whether operation can be activated above already started ones. More...
bool start (SUIT_Operation *, const bool check=true)
 Starts operation. More...
bool abort (SUIT_Operation *)
 Aborts operation. More...
bool commit (SUIT_Operation *)
 Commits operation. More...
bool suspend (SUIT_Operation *)
bool resume (SUIT_Operation *)
 Resumes operation. More...
virtual void restoreState (int savePoint)
 Restores the study state. More...
virtual void setIsSaved (const bool)
virtual void setIsModified (const bool)
virtual void setRoot (SUIT_DataObject *)
virtual void setStudyName (const QString &)
virtual void operationStarted (SUIT_Operation *)
 Perform some actions when operation starting. More...
virtual void operationAborted (SUIT_Operation *)
 Perform some actions when operation aborted. More...
virtual void operationStopped (SUIT_Operation *)
 Perform some actions when operation stopped. More...
virtual void operationCommited (SUIT_Operation *)
 Perform some actions when operation commited. More...
virtual bool openTransaction ()
 Opens transaction for data modifications. More...
virtual bool abortTransaction ()
 Aborts transaction and all performed data modifications. More...
virtual bool hasTransaction () const
 Returns true if transaction is opened. More...
virtual bool commitTransaction (const QString &=QString())
 Commits transaction and all performed data modifications. More...
Private Types
typedef QList< SUIT_Operation * > Operations
void stop (SUIT_Operation *)
 Stops operation. More...
int myId
SUIT_Application * myApp
SUIT_DataObject * myRoot
QString myName
bool myIsSaved
bool myIsModified
Operations myOperations
bool myBlockChangeState
bool myIsAutoSaving
Friends
class SUIT_Operation
Support study management. Object management. Operation management.
◆ Operations
◆ SUIT_Study()
SUIT_Study::SUIT_Study ( SUIT_Application *  app)
References myId, and myRoot.
◆ ~SUIT_Study()
SUIT_Study::~SUIT_Study ( )
References myRoot.
◆ abort()
bool SUIT_Study::abort ( SUIT_Operation *  theOp)
Aborts operation.
theOp- operation to be aborted
true if operation is aborted successfully
Verifies whether operation already started and aborts it in this case (sets execution status to Rejected and stops operation)
References SUIT_Operation::aborted(), SUIT_Operation::abortOperation(), myOperations, operationAborted(), SUIT_Operation::Rejected, SUIT_Operation::setExecStatus(), and stop().
◆ abortAllOperations()
void SUIT_Study::abortAllOperations ( )
Abort all operations.
References myBlockChangeState, and myOperations.
◆ abortTransaction()
bool SUIT_Study::abortTransaction ( )
Reimplemented in CAF_Study.
◆ activeOperation()
SUIT_Operation * SUIT_Study::activeOperation ( ) const
activeoperation.
References myOperations.
◆ application()
SUIT_Application * SUIT_Study::application ( ) const
Application.
References myApp.
◆ blockingOperation()
SUIT_Operation * SUIT_Study::blockingOperation ( SUIT_Operation *  theOp) const
theOp- operation to be checked
NULL if operation can be activated, pointer to operation which denies starting tested operation
Verifies whether operation can be activated above already started ones. This method is called from SUIT_Study::start() and SUIT_Study::resume() methods.
References SUIT_Operation::isGranted(), SUIT_Operation::isValid(), and myOperations.
◆ closeDocument()
void SUIT_Study::closeDocument ( bool  = true)
Close document. NOT IMPLEMENTED.
Reimplemented in CAM_Study, LightApp_Study, SalomeApp_Study, and CAF_Study.
◆ commit()
bool SUIT_Study::commit ( SUIT_Operation *  theOp)
Commits operation.
theOp- operation to be committed
true if operation is committed successfully
Verifies whether operation already started and commits it in this case (sets execution status to Accepted and stops operation)
References SUIT_Operation::Accepted, SUIT_Operation::commitOperation(), SUIT_Operation::committed(), myOperations, operationCommited(), SUIT_Operation::setExecStatus(), stop(), and studyModified().
◆ commitTransaction()
bool SUIT_Study::commitTransaction ( const QString &  = QString())
◆ createDocument()
bool SUIT_Study::createDocument ( const QString &  )
Custom document initialization to be performed
within onNewDoc() handler can be put here
Reimplemented in CAF_Study, LightApp_Study, and SalomeApp_Study.
◆ hasTransaction()
bool SUIT_Study::hasTransaction ( ) const
◆ id()
int SUIT_Study::id ( ) const
studyid.
References myId.
◆ isAutoSaving()
bool SUIT_Study::isAutoSaving ( ) const
c true - if study is auto saving, else false.
References myIsAutoSaving.
◆ isModified()
bool SUIT_Study::isModified ( ) const
c true - if study modified, else false.
References myIsModified.
◆ isSaved()
bool SUIT_Study::isSaved ( ) const
c true - if study saved, else false.
References myIsSaved.
◆ Modified()
void SUIT_Study::Modified ( )
Set study modified to on.
Reimplemented in SalomeApp_Study.
References sendChangesNotification(), and setIsModified().
◆ openDocument()
bool SUIT_Study::openDocument ( const QString &  fileName)
Open document. Sets file name. return true.
References myIsModified, myIsSaved, and myName.
◆ openTransaction()
bool SUIT_Study::openTransaction ( )
◆ operationAborted()
void SUIT_Study::operationAborted ( SUIT_Operation *  op)
References SUIT_Operation::abortTransaction(), SUIT_Operation::testFlags(), and SUIT_Operation::Transaction.
◆ operationCommited()
void SUIT_Study::operationCommited ( SUIT_Operation *  op)
◆ operations()
const QList< SUIT_Operation * > & SUIT_Study::operations ( ) const
List of all started operations
◆ operationStarted()
void SUIT_Study::operationStarted ( SUIT_Operation *  op)
References SUIT_Operation::openTransaction(), SUIT_Operation::testFlags(), and SUIT_Operation::Transaction.
◆ operationStopped()
void SUIT_Study::operationStopped ( SUIT_Operation *  )
◆ restoreState()
void SUIT_Study::restoreState ( int  savePoint)
◆ resume()
bool SUIT_Study::resume ( SUIT_Operation *  theOp)
Resumes operation.
theOp- operation to be resumed
Verifies whether operation already started but suspended and resumesit in this case.
References blockingOperation(), myOperations, SUIT_Operation::resumed(), SUIT_Operation::resumeOperation(), SUIT_Operation::Running, SUIT_Operation::setState(), SUIT_Operation::state(), and suspend().
◆ root()
SUIT_DataObject * SUIT_Study::root ( ) const
rootdata object.
References myRoot.
◆ saveDocument()
bool SUIT_Study::saveDocument ( )
c true - if document saved successful, else false.
References myName, and saveDocumentAs().
◆ saveDocumentAs()
bool SUIT_Study::saveDocumentAs ( const QString &  fileName)
Save document as fileName. Set file name.
References isAutoSaving(), myIsModified, myIsSaved, and myName.
◆ sendChangesNotification()
void SUIT_Study::sendChangesNotification ( )
Emit study modified.
References studyModified().
◆ setIsAutoSaving()
void SUIT_Study::setIsAutoSaving ( const bool  on = true)
Set study auto saving to on.
◆ setIsModified()
void SUIT_Study::setIsModified ( const bool  on)
◆ setIsSaved()
void SUIT_Study::setIsSaved ( const bool  on)
Set study saved to on.
◆ setRoot()
void SUIT_Study::setRoot ( SUIT_DataObject *  obj)
Set root object.
References myRoot, and SUIT_DataObject::reparentChildren().
◆ setStudyName()
void SUIT_Study::setStudyName ( const QString &  name)
Set study name.
References myName.
◆ start()
bool SUIT_Study::start ( SUIT_Operation *  theOp,
const bool  toCheck = true
Starts operation.
theOp- operation to be started
toCheck- if parameters is equal true then checking performed whether all already started operations allow to start this operation above them (default value is true
true if operation is started, false otherwise
Verifies whether theOp operation can be started above already started ones (if toCheck parameter is equal true) and starts it
References activeOperation(), application(), blockingOperation(), SUIT_Operation::isReadyToStart(), myOperations, operationStarted(), SUIT_MessageBox::question(), SUIT_Operation::Rejected, SUIT_Operation::Running, SUIT_Operation::setExecStatus(), SUIT_Operation::setState(), SUIT_Operation::setStudy(), SUIT_Operation::started(), SUIT_Operation::startOperation(), SUIT_Operation::Suspended, and SUIT_Operation::suspendOperation().
◆ stop()
void SUIT_Study::stop ( SUIT_Operation *  theOp)
Stops operation.
theOp- operation to be stopped
Stops operation. This private method is called from abort() and commit() ones to perform common actions when operation is stopped
References blockingOperation(), myOperations, operationStopped(), resume(), SUIT_Operation::setState(), SUIT_Operation::stopOperation(), SUIT_Operation::stopped(), and SUIT_Operation::Waiting.
◆ studyModified
void SUIT_Study::studyModified ( SUIT_Study *  )
signal
◆ studyName()
QString SUIT_Study::studyName ( ) const
studyname
References myName.
◆ suspend()
bool SUIT_Study::suspend ( SUIT_Operation *  theOp)
Commits operation.
true if operation is suspended successfully
Verifies whether operation already started and suspends it in this case. Operations ususlly are suspended to start other one above them.
References myOperations, SUIT_Operation::setState(), SUIT_Operation::state(), SUIT_Operation::Suspended, SUIT_Operation::suspended(), and SUIT_Operation::suspendOperation().
◆ update()
void SUIT_Study::update ( )
Update study. NOT IMPLEMENTED HERE.
◆ SUIT_Operation
friend class SUIT_Operation
friend
◆ myApp
SUIT_Application* SUIT_Study::myApp
◆ myBlockChangeState
bool SUIT_Study::myBlockChangeState
◆ myId
int SUIT_Study::myId
◆ myIsAutoSaving
bool SUIT_Study::myIsAutoSaving
◆ myIsModified
bool SUIT_Study::myIsModified
◆ myIsSaved
bool SUIT_Study::myIsSaved
◆ myName
QString SUIT_Study::myName
◆ myOperations
Operations SUIT_Study::myOperations
◆ myRoot
SUIT_DataObject* SUIT_Study::myRoot
