CAF_Study Class Reference
Represents study for using in CAF module. More...
#include <CAF_Study.h>
Inheritance diagram for CAF_Study:
 CAF_Study (SUIT_Application *theApp)
 CAF_Study (SUIT_Application *theApp, Handle(TDocStd_Document)&aStdDoc)
virtual ~CAF_Study ()
virtual bool createDocument (const QString &)
 Customize document initialization. More...
virtual void closeDocument (bool=true)
 Close document. More...
virtual bool openDocument (const QString &)
 Open document. More...
virtual bool saveDocumentAs (const QString &)
 Save document with other name. More...
bool isSaved () const
 Check if the study is saved. More...
bool isModified () const
 Check if the study is modified. More...
void doModified (bool=true)
 Increment modifications count. More...
void undoModified ()
 Decrement modifications count. More...
void clearModified ()
 Clear modifications count. More...
bool undo ()
 Undo the last command. More...
bool redo ()
 Redo the last undo. More...
bool canUndo () const
 Check if it is possible to undo last command. More...
bool canRedo () const
 Check if it is possible to redo last undo. More...
QStringList undoNames () const
 Get names of available undo commands. More...
QStringList redoNames () const
 Get names of available redo commands. More...
 Handle (TDocStd_Document) stdDoc() const
- Public Member Functions inherited from SUIT_Study
 SUIT_Study (SUIT_Application *)
virtual ~SUIT_Study ()
virtual int id () const
virtual QString studyName () const
SUIT_Application * application () const
virtual bool isSaved () const
virtual void Modified ()
bool saveDocument ()
virtual void update ()
virtual void sendChangesNotification ()
void setIsAutoSaving (const bool on=true)
bool isAutoSaving () const
SUIT_Operation * activeOperation () const
virtual void abortAllOperations ()
const QList< SUIT_Operation * > & operations () const
 Get all started operations. More...
virtual SUIT_Operation * blockingOperation (SUIT_Operation *) const
 Verifies whether operation can be activated above already started ones. More...
bool start (SUIT_Operation *, const bool check=true)
 Starts operation. More...
bool abort (SUIT_Operation *)
 Aborts operation. More...
bool commit (SUIT_Operation *)
 Commits operation. More...
bool suspend (SUIT_Operation *)
bool resume (SUIT_Operation *)
 Resumes operation. More...
virtual void restoreState (int savePoint)
 Restores the study state. More...
 Handle (TDocStd_Application) stdApp() const
CAF_Application * cafApplication () const
virtual bool openTransaction ()
 Open OCAF transaction. More...
virtual bool abortTransaction ()
 Abort OCAF transaction. More...
virtual bool hasTransaction () const
 Check if there is any transaction opened. More...
virtual bool commitTransaction (const QString &=QString())
 Commit OCAF transaction. More...
virtual void setStdDoc (Handle(TDocStd_Document)&)
- Protected Member Functions inherited from SUIT_Study
virtual void setIsSaved (const bool)
virtual void setIsModified (const bool)
virtual void setRoot (SUIT_DataObject *)
virtual void setStudyName (const QString &)
virtual void operationStarted (SUIT_Operation *)
 Perform some actions when operation starting. More...
virtual void operationAborted (SUIT_Operation *)
 Perform some actions when operation aborted. More...
virtual void operationStopped (SUIT_Operation *)
 Perform some actions when operation stopped. More...
virtual void operationCommited (SUIT_Operation *)
 Perform some actions when operation commited. More...
 Opens transaction for data modifications. More...
 Aborts transaction and all performed data modifications. More...
 Returns true if transaction is opened. More...
 Commits transaction and all performed data modifications. More...
 Handle (TDocStd_Document) myStdDoc
int myModifiedCnt
Friends
class CAF_Operation
- Signals inherited from SUIT_Study
void studyModified (SUIT_Study *)
A study contains reference to OCAF std document and allows using OCAF services. Provides necessary functionality for OCC transactions management.
◆ CAF_Study() [1/2]
CAF_Study::CAF_Study ( SUIT_Application *  theApp)
theAppapplication
◆ CAF_Study() [2/2]
CAF_Study::CAF_Study ( SUIT_Application *  theApp,
Handle(TDocStd_Document)&  aStdDoc
theAppapplication
aStdDocOCAF document
◆ ~CAF_Study()
CAF_Study::~CAF_Study ( )
◆ abortTransaction()
bool CAF_Study::abortTransaction ( )
true if transaction is aborted successfully
Reimplemented from SUIT_Study.
References SUIT_Study::update().
◆ cafApplication()
CAF_Application * CAF_Study::cafApplication ( ) const
◆ canRedo()
bool CAF_Study::canRedo ( ) const
true if redo is avaiable
◆ canUndo()
bool CAF_Study::canUndo ( ) const
true if undo is avaiable
◆ clearModified()
void CAF_Study::clearModified ( )
See also
doModified(), undoModified()
References myModifiedCnt.
◆ closeDocument()
void CAF_Study::closeDocument ( bool  permanently = true)
Close document.
permanentlyif true, a document is closed permanently
References SUIT_Study::closeDocument(), and Handle().
◆ commitTransaction()
bool CAF_Study::commitTransaction ( const QString &  name = QString())
true if transaction is committed successfully
References canUndo(), Handle(), and CAF_Tools::toExtString().
◆ createDocument()
bool CAF_Study::createDocument ( const QString &  doc)
docstudy name
true on success and false on error
References cafApplication(), and SUIT_Study::createDocument().
◆ doModified()
void CAF_Study::doModified ( bool  undoable = true)
If undoable is true, this modification can be rolled back by undoModified(), otherwise the document will be marked as modified until it is saved.
undoableif true the operation is undoable
See also
undoModified(), clearModified()
◆ Handle() [1/3]
CAF_Study::Handle ( TDocStd_Application  ) const
◆ Handle() [2/3]
CAF_Study::Handle ( TDocStd_Document  )
◆ Handle() [3/3]
CAF_Study::Handle ( TDocStd_Document  ) const
◆ hasTransaction()
bool CAF_Study::hasTransaction ( ) const
true if there is opened OCAF transaction
◆ isModified()
bool CAF_Study::isModified ( ) const
true if the document has been modified
◆ isSaved()
bool CAF_Study::isSaved ( ) const
true if the document has been saved to file
◆ openDocument()
bool CAF_Study::openDocument ( const QString &  fname)
Open document.
fnamestudy file name
true on success and false if document cannot be opened
References Handle(), SUIT_Study::openDocument(), and CAF_Tools::toExtString().
◆ openTransaction()
bool CAF_Study::openTransaction ( )
true if transaction is opened successfully
◆ redo()
bool CAF_Study::redo ( )
Redo the last undo.
References SUIT_Study::application(), SUIT_MessageBox::critical(), and doModified().
◆ redoNames()
QStringList CAF_Study::redoNames ( ) const
list of commands names
References CAF_Tools::toQString().
◆ saveDocumentAs()
bool CAF_Study::saveDocumentAs ( const QString &  fname)
References Handle(), myModifiedCnt, SUIT_Study::saveDocumentAs(), CAF_Tools::toExtString(), and CAF_Tools::toQString().
◆ setStdDoc()
virtual void CAF_Study::setStdDoc ( Handle(TDocStd_Document)&  )
◆ undo()
bool CAF_Study::undo ( )
References SUIT_Study::application(), SUIT_MessageBox::critical(), and undoModified().
◆ undoModified()
void CAF_Study::undoModified ( )
See also
◆ undoNames()
QStringList CAF_Study::undoNames ( ) const
◆ CAF_Operation
friend class CAF_Operation
friend
◆ myModifiedCnt
int CAF_Study::myModifiedCnt
