VTKViewer_ExtractUnstructuredGrid.h
23#ifndef VTKVIEWER_EXTRACTUNSTRUCTUREDGRID_H
24#define VTKVIEWER_EXTRACTUNSTRUCTUREDGRID_H
26#include "VTKViewer.h"
27
28#include <vtkUnstructuredGridAlgorithm.h>
30#include <set>
31#include <map>
32#include <vector>
33
34#ifdef WIN32
35#pragma warning ( disable:4251 )
36#endif
37
45{
46public:
49
50
52
53 enum EExtraction{ eCells, ePoints};
55 void SetModeOfExtraction(EExtraction theExtractionMode){
56 if ( myExtractionMode != theExtractionMode ) { myExtractionMode = theExtractionMode; Modified(); }
57 }
59 EExtraction GetModeOfExtraction(){ return myExtractionMode;}
60
61 enum EChanging{ ePassAll, eAdding, eRemoving};
63 void SetModeOfChanging(EChanging theChangeMode){
64 if ( myChangeMode != theChangeMode ) { myChangeMode = theChangeMode; Modified(); }
65 }
67 EChanging GetModeOfChanging(){ return myChangeMode; }
68
70 void RegisterCell(vtkIdType theCellId);
72 int IsCellsRegistered() { return !myCellIds.empty(); }
75 if ( !myCellIds.empty() ) { myCellIds.clear(); Modified(); }
76 }
77
79 void RegisterCellsWithType(vtkIdType theCellType);
81 int IsCellsWithTypeRegistered() { return !myCellTypes.empty(); }
84 if ( !myCellTypes.empty() ) { myCellTypes.clear(); Modified(); }
85 }
86
88 int IsChanging() { return IsCellsRegistered() || IsCellsWithTypeRegistered(); }
89
91 void SetStoreMapping(int theStoreMapping);
93 int GetStoreMapping(){ return myStoreMapping; }
94
96 void BuildOut2InMap();
98 vtkIdType GetInputId(vtkIdType theOutId) const;
100 //vtkIdType GetOutputId(int theInId) const;
101
102 typedef std::vector<vtkIdType> TVectorId;
103 typedef std::map<vtkIdType,vtkIdType> TMapId;
104 typedef std::set<vtkIdType> TSetId;
105
106protected:
109
110 virtual int RequestData(vtkInformation *, vtkInformationVector **, vtkInformationVector *);
111
113
117
118 bool myStoreMapping, myPassAll;
120 //TMapId myIn2OutId;
121
122private:
127};
128
129#ifdef WIN32
130#pragma warning ( default:4251 )
131#endif
132
133#endif
#define VTKVIEWER_EXPORT
Definition: VTKViewer.h:33
Definition: VTKViewer_ExtractUnstructuredGrid.h:45
Sets mode of extraction to theExtractionMode.
Definition: VTKViewer_ExtractUnstructuredGrid.h:55
void operator=(const VTKViewer_ExtractUnstructuredGrid &)
Not implemented.
Sets mode of changing to theChangeMode.
Definition: VTKViewer_ExtractUnstructuredGrid.h:63
Get myStoreMapping.
Definition: VTKViewer_ExtractUnstructuredGrid.h:93
std::vector< vtkIdType > TVectorId
Gets the output id by input id.
Definition: VTKViewer_ExtractUnstructuredGrid.h:102
bool myPassAll
Definition: VTKViewer_ExtractUnstructuredGrid.h:118
EChanging myChangeMode
Definition: VTKViewer_ExtractUnstructuredGrid.h:114
EExtraction
Definition: VTKViewer_ExtractUnstructuredGrid.h:53
@ eCells
Check if myCellTypes is empty.
Definition: VTKViewer_ExtractUnstructuredGrid.h:81
std::map< vtkIdType, vtkIdType > TMapId
Definition: VTKViewer_ExtractUnstructuredGrid.h:103
Get Extraction mode (Return: myExtractionMode field)
Definition: VTKViewer_ExtractUnstructuredGrid.h:59
vtkTypeMacro(VTKViewer_ExtractUnstructuredGrid, vtkUnstructuredGridAlgorithm) static VTKViewer_ExtractUnstructuredGrid *New()
VTK type macros.
EChanging
Definition: VTKViewer_ExtractUnstructuredGrid.h:61
@ eAdding
void ClearRegisteredCellsWithType()
Remove every cells with the type from the output.
Definition: VTKViewer_ExtractUnstructuredGrid.h:83
int IsChanging()
Do the filter do some real work.
Definition: VTKViewer_ExtractUnstructuredGrid.h:88
Check if myCellIds is empty.
Definition: VTKViewer_ExtractUnstructuredGrid.h:72
std::set< vtkIdType > TSetId
Definition: VTKViewer_ExtractUnstructuredGrid.h:104
Return myChangeMode field.
Definition: VTKViewer_ExtractUnstructuredGrid.h:67
TSetId myCellTypes
Definition: VTKViewer_ExtractUnstructuredGrid.h:116
TVectorId myOut2InId
Definition: VTKViewer_ExtractUnstructuredGrid.h:119
EExtraction myExtractionMode
Definition: VTKViewer_ExtractUnstructuredGrid.h:112
void ClearRegisteredCells()
Remove the cell from the output.
Definition: VTKViewer_ExtractUnstructuredGrid.h:74
TSetId myCellIds
Definition: VTKViewer_ExtractUnstructuredGrid.h:115
VTKViewer_ExtractUnstructuredGrid(const VTKViewer_ExtractUnstructuredGrid &)
Not implemented.
For more information see VTK documentation
