VTKViewer_ExtractUnstructuredGrid Class Reference
#include <VTKViewer_ExtractUnstructuredGrid.h>
Inheritance diagram for VTKViewer_ExtractUnstructuredGrid:
enum  EExtraction { eCells , ePoints }
enum  EChanging { ePassAll , eAdding , eRemoving }
typedef std::vector< vtkIdType > TVectorId
 Gets the output id by input id. More...
typedef std::map< vtkIdType, vtkIdType > TMapId
typedef std::set< vtkIdType > TSetId
 vtkTypeMacro (VTKViewer_ExtractUnstructuredGrid, vtkUnstructuredGridAlgorithm) static VTKViewer_ExtractUnstructuredGrid *New()
 VTK type macros. More...
void SetModeOfExtraction (EExtraction theExtractionMode)
 Sets mode of extraction to theExtractionMode. More...
EExtraction GetModeOfExtraction ()
 Get Extraction mode (Return: myExtractionMode field) More...
void SetModeOfChanging (EChanging theChangeMode)
 Sets mode of changing to theChangeMode. More...
EChanging GetModeOfChanging ()
 Return myChangeMode field. More...
void RegisterCell (vtkIdType theCellId)
 Add cell id to myCellIds std::set. More...
int IsCellsRegistered ()
 Check if myCellIds is empty. More...
void ClearRegisteredCells ()
 Remove the cell from the output. More...
void RegisterCellsWithType (vtkIdType theCellType)
 Add cell type to myCellTypes std::set. More...
int IsCellsWithTypeRegistered ()
 Check if myCellTypes is empty. More...
void ClearRegisteredCellsWithType ()
 Remove every cells with the type from the output. More...
int IsChanging ()
 Do the filter do some real work. More...
void SetStoreMapping (int theStoreMapping)
 Do it keep the mapping between input's and output's UnstructuredGrid. More...
int GetStoreMapping ()
 Get myStoreMapping. More...
void BuildOut2InMap ()
 Computes a map out IDs to in IDs. Call it before GetInputId()!!! More...
vtkIdType GetInputId (vtkIdType theOutId) const
 Gets the input id by output id. Call BuildOut2InMap() before. More...
 VTKViewer_ExtractUnstructuredGrid ()
 ~VTKViewer_ExtractUnstructuredGrid ()
virtual int RequestData (vtkInformation *, vtkInformationVector **, vtkInformationVector *)
EExtraction myExtractionMode
EChanging myChangeMode
TSetId myCellIds
TSetId myCellTypes
bool myStoreMapping
bool myPassAll
TVectorId myOut2InId
 VTKViewer_ExtractUnstructuredGrid (const VTKViewer_ExtractUnstructuredGrid &)
 Not implemented. More...
void operator= (const VTKViewer_ExtractUnstructuredGrid &)
◆ TMapId
typedef std::map<vtkIdType,vtkIdType> VTKViewer_ExtractUnstructuredGrid::TMapId
◆ TSetId
typedef std::set<vtkIdType> VTKViewer_ExtractUnstructuredGrid::TSetId
◆ TVectorId
typedef std::vector<vtkIdType> VTKViewer_ExtractUnstructuredGrid::TVectorId
◆ EChanging
ePassAll
eAdding
eRemoving
◆ EExtraction
eCells
ePoints
◆ VTKViewer_ExtractUnstructuredGrid() [1/2]
VTKViewer_ExtractUnstructuredGrid::VTKViewer_ExtractUnstructuredGrid ( )
◆ ~VTKViewer_ExtractUnstructuredGrid()
VTKViewer_ExtractUnstructuredGrid::~VTKViewer_ExtractUnstructuredGrid ( )
◆ VTKViewer_ExtractUnstructuredGrid() [2/2]
VTKViewer_ExtractUnstructuredGrid::VTKViewer_ExtractUnstructuredGrid ( const VTKViewer_ExtractUnstructuredGrid &  )
Not implemented.
◆ BuildOut2InMap()
void VTKViewer_ExtractUnstructuredGrid::BuildOut2InMap ( )
References eAdding, eCells, ePassAll, eRemoving, myCellIds, myCellTypes, myChangeMode, myExtractionMode, myOut2InId, and myPassAll.
◆ ClearRegisteredCells()
void VTKViewer_ExtractUnstructuredGrid::ClearRegisteredCells ( )
◆ ClearRegisteredCellsWithType()
void VTKViewer_ExtractUnstructuredGrid::ClearRegisteredCellsWithType ( )
◆ GetInputId()
vtkIdType VTKViewer_ExtractUnstructuredGrid::GetInputId ( vtkIdType  theOutId) const
References myCellIds, myCellTypes, myOut2InId, and myPassAll.
◆ GetModeOfChanging()
EChanging VTKViewer_ExtractUnstructuredGrid::GetModeOfChanging ( )
◆ GetModeOfExtraction()
EExtraction VTKViewer_ExtractUnstructuredGrid::GetModeOfExtraction ( )
◆ GetStoreMapping()
int VTKViewer_ExtractUnstructuredGrid::GetStoreMapping ( )
Get myStoreMapping.
◆ IsCellsRegistered()
int VTKViewer_ExtractUnstructuredGrid::IsCellsRegistered ( )
◆ IsCellsWithTypeRegistered()
int VTKViewer_ExtractUnstructuredGrid::IsCellsWithTypeRegistered ( )
◆ IsChanging()
int VTKViewer_ExtractUnstructuredGrid::IsChanging ( )
◆ operator=()
void VTKViewer_ExtractUnstructuredGrid::operator= ( const VTKViewer_ExtractUnstructuredGrid &  )
Not implemented.
◆ RegisterCell()
void VTKViewer_ExtractUnstructuredGrid::RegisterCell ( vtkIdType  theCellId)
References myCellIds.
◆ RegisterCellsWithType()
void VTKViewer_ExtractUnstructuredGrid::RegisterCellsWithType ( vtkIdType  theCellType)
References myCellTypes.
◆ RequestData()
int VTKViewer_ExtractUnstructuredGrid::RequestData ( vtkInformation *  ,
vtkInformationVector **  ,
◆ SetModeOfChanging()
void VTKViewer_ExtractUnstructuredGrid::SetModeOfChanging ( EChanging  theChangeMode)
◆ SetModeOfExtraction()
void VTKViewer_ExtractUnstructuredGrid::SetModeOfExtraction ( EExtraction  theExtractionMode)
◆ SetStoreMapping()
void VTKViewer_ExtractUnstructuredGrid::SetStoreMapping ( int  theStoreMapping)
References myStoreMapping.
◆ vtkTypeMacro()
VTKViewer_ExtractUnstructuredGrid::vtkTypeMacro ( VTKViewer_ExtractUnstructuredGrid  ,
VTK type macros.
Construct with all types of clipping turned off.
◆ myCellIds
TSetId VTKViewer_ExtractUnstructuredGrid::myCellIds
◆ myCellTypes
TSetId VTKViewer_ExtractUnstructuredGrid::myCellTypes
◆ myChangeMode
EChanging VTKViewer_ExtractUnstructuredGrid::myChangeMode
◆ myExtractionMode
EExtraction VTKViewer_ExtractUnstructuredGrid::myExtractionMode
◆ myOut2InId
TVectorId VTKViewer_ExtractUnstructuredGrid::myOut2InId
◆ myPassAll
bool VTKViewer_ExtractUnstructuredGrid::myPassAll
◆ myStoreMapping
bool VTKViewer_ExtractUnstructuredGrid::myStoreMapping
