DDS_DicItem Class Reference
This class provides an information about datum (phisical characteristic parameter). More...
#include <DDS_DicItem.h>
Inheritance diagram for DDS_DicItem:
struct  UnitData
enum  Type {
  String , Float , Integer , List ,
  Unknown
enum  Data { MinValue = 0x01 , MaxValue = 0x02 , DefaultValue = 0x04 }
typedef TCollection_AsciiString UnitSystem
Standard_EXPORT DDS_DicItem ()
Standard_EXPORT TCollection_AsciiString GetId () const
 Get the identifier of parameter. More...
Standard_EXPORT DDS_DicItem::Type GetType () const
 Get the type of parameter. More...
Standard_EXPORT TCollection_ExtendedString GetLabel () const
 Get the label of the parameter. More...
Standard_EXPORT TCollection_ExtendedString GetFilter () const
 Get the filter (regular expression) for the parameter values. More...
Standard_EXPORT TCollection_ExtendedString GetRequired () const
 Get the Required attribute of the parameter. More...
Standard_EXPORT DDS_MsgType GetWarningLevel () const
 Get the wrong value warning level of the parameter. More...
Standard_EXPORT TCollection_ExtendedString GetLongDescription () const
 Get the long description of the parameter. More...
Standard_EXPORT TCollection_ExtendedString GetShortDescription () const
 Get the short description of the parameter. More...
Standard_EXPORT TCollection_AsciiString GetComponent () const
 Get the name of the component (parameter owner). More...
virtual Standard_EXPORT TCollection_AsciiString GetUnits () const
 Get the parameter measure units for active units system. More...
virtual Standard_EXPORT TCollection_AsciiString GetUnits (const UnitSystem &) const
 Get the parameter measure units for specified units system theSystem. More...
Standard_EXPORT TCollection_ExtendedString GetDefaultValue () const
 Get the default value of the parameter for active units system. More...
Standard_EXPORT TCollection_ExtendedString GetDefaultValue (const UnitSystem &) const
 Get the default value of the parameter for specified units system theSystem. More...
Standard_EXPORT Standard_Real GetMinValue () const
 Get the minimum value of the parameter for active units system. More...
Standard_EXPORT Standard_Real GetMinValue (const UnitSystem &) const
 Get the minimum value of the parameter for the specified units system theSystem. More...
Standard_EXPORT Standard_Real GetMaxValue () const
 Get the maximum value of the parameter for active units system. More...
Standard_EXPORT Standard_Real GetMaxValue (const UnitSystem &) const
 Get the maximum value of the parameter for specified units system theSystem. More...
virtual Standard_EXPORT Standard_Integer GetPrecision () const
 Get the precision (number of digits after decimal point) of the parameter for active units system. More...
virtual Standard_EXPORT Standard_Integer GetPrecision (const UnitSystem &) const
 Get the precision (number of digits after decimal point) of the parameter for specified units system theSystem. More...
virtual Standard_EXPORT TCollection_AsciiString GetFormat (const Standard_Boolean=Standard_True) const
 Get the format string of the parameter for active units system. More...
virtual Standard_EXPORT TCollection_AsciiString GetFormat (const UnitSystem &, const Standard_Boolean=Standard_True) const
 Get the format string of the parameter for specified units system theSystem. More...
Standard_EXPORT TCollection_ExtendedString GetNameOfValues () const
 Get the name of a list referenced by the parameter. More...
Standard_EXPORT Standard_Boolean GetListOfValues (Handle(TColStd_HArray1OfExtendedString)&, Handle(TColStd_HArray1OfInteger)&) const
 Get item names and item identifiers of a list referenced by the parameter. More...
Standard_EXPORT Standard_Boolean GetListOfValues (Handle(TColStd_HArray1OfExtendedString)&, Handle(TColStd_HArray1OfInteger)&, Handle(TColStd_HArray1OfExtendedString)&) const
 Get item names, item identifiers and item icons of a list referenced by the parameter. More...
Standard_EXPORT Standard_Boolean GetSpecialValues (TColStd_MapOfReal &) const
 Get special values of the parameter. More...
Standard_EXPORT Standard_Real GetMinZoom () const
 Get minimum value of lateral zooming. More...
Standard_EXPORT Standard_Real GetMaxZoom () const
 Get maximum value of lateral zooming. More...
Standard_EXPORT Standard_Real GetZoomOrder () const
 Get order of lateral zooming. More...
virtual Standard_EXPORT Standard_Real ToSI (const Standard_Real) const
 Convert value theVal to the default SI units according to the active units system. More...
virtual Standard_EXPORT Standard_Real FromSI (const Standard_Real) const
 Convert value theVal from the default SI units according to the active units system. More...
virtual Standard_EXPORT Standard_Real ToSI (const Standard_Real, const UnitSystem &) const
 Convert value to the default SI units according to the units system theUnitsSystem. More...
virtual Standard_EXPORT Standard_Real FromSI (const Standard_Real, const UnitSystem &) const
 Convert value from the default SI units according to the units system theUnitsSystem. More...
Standard_EXPORT Standard_Boolean HasData (const Standard_Integer) const
 Check data existence. More...
Standard_EXPORT TCollection_ExtendedString GetOption (const TCollection_AsciiString &) const
 Get option for specified name name. More...
Standard_EXPORT Standard_Boolean GetOptionNames (TColStd_SequenceOfAsciiString &) const
 Get names of all existing options. More...
Standard_EXPORT void SetId (const TCollection_AsciiString &)
 Set item's identify string. More...
Standard_EXPORT void SetComponent (const Handle(Standard_Transient)&)
 Set item's component pointer. More...
Standard_EXPORT void SetLabel (const TCollection_AsciiString &)
 Set item's label string. More...
Standard_EXPORT void SetFilter (const TCollection_AsciiString &)
 Set item's filter string. More...
Standard_EXPORT void SetRequired (const TCollection_AsciiString &)
 Set item's required value. More...
Standard_EXPORT void SetWarningLevel (const Standard_Integer &)
 Set item's warning level value. More...
Standard_EXPORT void SetMinZoom (const Standard_Real &)
 Set item's minimum zoom value. More...
Standard_EXPORT void SetMaxZoom (const Standard_Real &)
 Set item's maximum zoom value. More...
Standard_EXPORT void SetZoomOrder (const Standard_Real &)
 Set item's zoom order value. More...
Standard_EXPORT void SetShortDescription (const TCollection_ExtendedString &)
 Set item's short description. More...
Standard_EXPORT void SetLongDescription (const TCollection_ExtendedString &)
 Set item's long description. More...
Standard_EXPORT bool SetOption (const TCollection_AsciiString &, const TCollection_AsciiString &)
 Add item's option. More...
Standard_EXPORT void SetType (const DDS_DicItem::Type &)
 Set item's type value. More...
Standard_EXPORT void SetMin (const Standard_Real &)
 Set item's minimum value. More...
Standard_EXPORT void SetMax (const Standard_Real &)
 Set item's maximum value. More...
Standard_EXPORT void SetDefaultValue (const Standard_Real &)
 Set item's default value as a real number. More...
Standard_EXPORT void SetDefaultValue (const TCollection_AsciiString &)
 Set item's default value as a string. More...
Standard_EXPORT void SetListOfValues (const Handle(TColStd_HArray1OfExtendedString)&, const Handle(TColStd_HArray1OfInteger)&)
 Set item's value list. More...
Standard_EXPORT void SetListOfValues (const Handle(TColStd_HArray1OfExtendedString)&, const Handle(TColStd_HArray1OfInteger)&, const Handle(TColStd_HArray1OfExtendedString)&)
 Set item's value list and icons. More...
Standard_EXPORT DDS_DicItem (const DDS_DicItem &)
 Copy constructor (put in private section to prevent object copying). More...
Standard_EXPORT void operator= (const DDS_DicItem &)
 Assignment operator (put in private section to prevent object copying). More...
virtual Standard_EXPORT void FillDataMap (TCollection_AsciiString, const LDOM_Element &, const LDOM_Element &, const LDOM_Element &, const TColStd_SequenceOfAsciiString &)
 Parse record from XML file and retrieve information relevant for the dictionary item. More...
Private Types
typedef NCollection_DataMap< TCollection_AsciiString, TCollection_ExtendedString > OptionsMap
Standard_EXPORT void PrepareFormats (const TCollection_AsciiString &)
 Prepare formats for all units systems. More...
Standard_EXPORT void GetDefaultFormat ()
 Restore default formats for all the units systems. More...
Standard_EXPORT UnitSystem GetActiveUnitSystem () const
 Get the active units system. More...
Standard_EXPORT void GetStringFormat (const TCollection_AsciiString &, const TCollection_AsciiString &, const TCollection_AsciiString &, const TCollection_AsciiString &, TCollection_AsciiString &)
 Get format for the string. More...
Standard_EXPORT void GetIntegerFormat (const TCollection_AsciiString &, const TCollection_AsciiString &, const TCollection_AsciiString &, const TCollection_AsciiString &, const Standard_Character, TCollection_AsciiString &)
 Get format for the integer. More...
Standard_EXPORT void GetFloatFormat (const TCollection_AsciiString &, const TCollection_AsciiString &, const TCollection_AsciiString &, const TCollection_AsciiString &, const Standard_Character, TCollection_AsciiString &)
 Returns format for the float. More...
Standard_EXPORT void Split (const TCollection_AsciiString &, Handle(TColStd_HArray1OfExtendedString)&)
 Split the string theStr separated by spaces. More...
Standard_EXPORT UnitData * GetUnitData (const UnitSystem &) const
 Get units structure for specified units system sys. More...
 Handle (TColStd_HArray1OfExtendedString) myListRef
 Handle (TColStd_HArray1OfInteger) myListRefID
 Handle (TColStd_HArray1OfExtendedString) myListRefIcons
 Handle (Standard_Transient) myComponent
TCollection_AsciiString myId
TCollection_ExtendedString myLabel
TCollection_ExtendedString myFilter
TCollection_ExtendedString myRequired
Standard_Integer myType
Standard_Integer myWarnLevel
TCollection_ExtendedString myLongDescr
TCollection_ExtendedString myShortDescr
Standard_Real myMax
Standard_Real myMin
Standard_Real myDefValue
TCollection_ExtendedString myDefString
Standard_Integer myData
TCollection_ExtendedString myListName
Standard_Real myMinZoom
Standard_Real myMaxZoom
Standard_Real myZoomOrder
OptionsMap myOptions
NCollection_DataMap< UnitSystem, UnitData > myUnitData
Friends
class DDS_DicGroup
◆ OptionsMap
typedef NCollection_DataMap<TCollection_AsciiString, TCollection_ExtendedString> DDS_DicItem::OptionsMap
◆ UnitSystem
typedef TCollection_AsciiString DDS_DicItem::UnitSystem
◆ Data
Enum describes the flags for existance of domain data
MinValue
Flag of minimum value definition existence.
MaxValue
Flag of maximum value definition existence.
DefaultValue
Flag of default value definition existence.
◆ Type
Enum describes type of datum value
String
String type of value.
Float
Real (double) numeric type of value.
Integer
Integer (int) numeric type of value.
List
List type of enumerable value.
Unknown
Unknown or undefined type of value.
◆ DDS_DicItem() [1/2]
Standard_EXPORT DDS_DicItem::DDS_DicItem ( )
◆ DDS_DicItem() [2/2]
DDS_DicItem::DDS_DicItem ( const DDS_DicItem &  )
◆ FillDataMap()
void DDS_DicItem::FillDataMap ( TCollection_AsciiString  theID,
const LDOM_Element &  theDatum,
const LDOM_Element &  theCompElement,
const LDOM_Element &  theDocElement,
const TColStd_SequenceOfAsciiString &  theSystems
theIDitem identifier
theDatumdatum XML node
theCompElementcomponent XML node
theDocElementdocument XML node
theSystemsunits system names
References DDS_MT_ALARM, DDS_MT_ERROR, DDS_MT_INFO, DDS_MT_NONE, DDS_MT_WARNING, DefaultValue, Float, Handle(), Integer, List, MaxValue, MinValue, myData, myDefString, myDefValue, myFilter, myId, myLabel, myListName, myLongDescr, myMax, myMaxZoom, myMin, myMinZoom, myOptions, myRequired, DDS_DicItem::UnitData::myScale, myShortDescr, myType, myUnitData, DDS_DicItem::UnitData::myUnits, myWarnLevel, DDS_DicItem::UnitData::myZero, myZoomOrder, PrepareFormats(), Split(), String, and Unknown.
◆ FromSI() [1/2]
Standard_Real DDS_DicItem::FromSI ( const Standard_Real  theVal) const
theValvalue being converted
value converted from SI
References FromSI(), and GetActiveUnitSystem().
◆ FromSI() [2/2]
Standard_Real DDS_DicItem::FromSI ( const Standard_Real  theVal,
const UnitSystem &  theUnitsSystem
theUnitsSystemunits system
value converted from the specified units system
References GetUnitData(), DDS_DicItem::UnitData::myScale, and DDS_DicItem::UnitData::myZero.
◆ GetActiveUnitSystem()
DDS_DicItem::UnitSystem DDS_DicItem::GetActiveUnitSystem ( ) const
active units system
References Handle().
◆ GetComponent()
TCollection_AsciiString DDS_DicItem::GetComponent ( ) const
component name
◆ GetDefaultFormat()
void DDS_DicItem::GetDefaultFormat ( )
References Float, Integer, DDS_DicItem::UnitData::myFormat, myType, myUnitData, and String.
◆ GetDefaultValue() [1/2]
TCollection_ExtendedString DDS_DicItem::GetDefaultValue ( ) const
Default value is returned as string. If type of the value is numerical (Float or Integer) and default value is defined, then the returning value is converted to SI.
default value
References GetActiveUnitSystem(), and GetDefaultValue().
◆ GetDefaultValue() [2/2]
TCollection_ExtendedString DDS_DicItem::GetDefaultValue ( const UnitSystem &  theSystem) const
theSystemunits system
default value
References Float, FromSI(), Integer, List, myDefString, myDefValue, myType, and String.
◆ GetFilter()
TCollection_ExtendedString DDS_DicItem::GetFilter ( ) const
parameter filter
References myFilter.
◆ GetFloatFormat()
void DDS_DicItem::GetFloatFormat ( const TCollection_AsciiString &  theFlags,
const TCollection_AsciiString &  theWidth,
const TCollection_AsciiString &  thePrecision,
const TCollection_AsciiString &  theTypePrefix,
const Standard_Character  theType,
TCollection_AsciiString &  theFormat
theFlagsformat flags
theWidthfield width
thePrecisionprecision
theTypePrefixtype prefix
theTypefloating point value type
theFormatreturning format string
◆ GetFormat() [1/2]
TCollection_AsciiString DDS_DicItem::GetFormat ( const Standard_Boolean  theCanonical = Standard_True) const
If argument theCanonical is true, format string is reduced according to the sprintf() specification (without extra non standard qualifiers).
theCanonical'canonical form' flag
format string
References GetActiveUnitSystem(), and GetFormat().
◆ GetFormat() [2/2]
TCollection_AsciiString DDS_DicItem::GetFormat ( const UnitSystem &  theSystem,
format string
References GetUnitData(), and DDS_DicItem::UnitData::myFormat.
◆ GetId()
TCollection_AsciiString DDS_DicItem::GetId ( ) const
parameter ID
References myId.
◆ GetIntegerFormat()
void DDS_DicItem::GetIntegerFormat ( const TCollection_AsciiString &  theFlags,
theWidthfield width
theTypeinteger value type
◆ GetLabel()
TCollection_ExtendedString DDS_DicItem::GetLabel ( ) const
parameter label
References myLabel.
◆ GetListOfValues() [1/2]
Standard_Boolean DDS_DicItem::GetListOfValues ( Handle(TColStd_HArray1OfExtendedString)&  theStrings,
Handle(TColStd_HArray1OfInteger)&  theIntegers
These sequences are empty if the list reference is not defined. In this case, other properties (Type, DefaultValue, MaxValue, MinValue) should be used.
theStringsreturning items names
theIntegersreturning items identifiers
true if returning lists are not empty
See also
GetNameOfValues()
◆ GetListOfValues() [2/2]
Handle(TColStd_HArray1OfInteger)&  theIntegers,
Handle(TColStd_HArray1OfExtendedString)&  theIcons
This is an overloaded member function, provided for convenience. It differs from the above function only in what argument(s) it accepts.
theIconsreturning items icons
See also
GetNameOfValues()
◆ GetLongDescription()
TCollection_ExtendedString DDS_DicItem::GetLongDescription ( ) const
long description
References myLongDescr.
◆ GetMaxValue() [1/2]
Standard_Real DDS_DicItem::GetMaxValue ( ) const
Returned value converted to SI.
maximum value
References GetActiveUnitSystem(), and GetMaxValue().
◆ GetMaxValue() [2/2]
Standard_Real DDS_DicItem::GetMaxValue ( const UnitSystem &  theUnitsSystem) const
maximum value
References FromSI(), and myMax.
◆ GetMaxZoom()
Standard_Real DDS_DicItem::GetMaxZoom ( ) const
lateral zooming maximum value
References myMaxZoom.
◆ GetMinValue() [1/2]
Standard_Real DDS_DicItem::GetMinValue ( ) const
Returned value is converted to SI.
minimum value
References GetActiveUnitSystem(), and GetMinValue().
◆ GetMinValue() [2/2]
Standard_Real DDS_DicItem::GetMinValue ( const UnitSystem &  theUnitsSystem) const
minimum value
References FromSI(), and myMin.
◆ GetMinZoom()
Standard_Real DDS_DicItem::GetMinZoom ( ) const
lateral zooming minimum value
References myMinZoom.
◆ GetNameOfValues()
TCollection_ExtendedString DDS_DicItem::GetNameOfValues ( ) const
This string is empty if the list reference is not defined. In this case, other properties (Type, DefaultValue, MaxValue, MinValue) should be used.
referenced list name
See also
GetListOfValues()
References myListName.
◆ GetOption()
TCollection_ExtendedString DDS_DicItem::GetOption ( const TCollection_AsciiString &  name) const
If option is not found, empty string is returned.
nameoption name
option value
References myOptions.
◆ GetOptionNames()
Standard_Boolean DDS_DicItem::GetOptionNames ( TColStd_SequenceOfAsciiString &  names) const
namesreturning list of options
true if list is not empty
◆ GetPrecision() [1/2]
Standard_Integer DDS_DicItem::GetPrecision ( ) const
parameter precision
References GetActiveUnitSystem(), and GetPrecision().
◆ GetPrecision() [2/2]
Standard_Integer DDS_DicItem::GetPrecision ( const UnitSystem &  theSystem) const
If specified units system doesn't exist, zero is returned.
parameter precision
References GetUnitData(), and DDS_DicItem::UnitData::myPrecision.
◆ GetRequired()
TCollection_ExtendedString DDS_DicItem::GetRequired ( ) const
Required attribute
References myRequired.
◆ GetShortDescription()
TCollection_ExtendedString DDS_DicItem::GetShortDescription ( ) const
short description
References myShortDescr.
◆ GetSpecialValues()
Standard_Boolean DDS_DicItem::GetSpecialValues ( TColStd_MapOfReal &  theMap) const
theMapreturning map of the special values
true if returning map is not empty
◆ GetStringFormat()
void DDS_DicItem::GetStringFormat ( const TCollection_AsciiString &  theFlags,
theWidthfield width
◆ GetType()
DDS_DicItem::Type DDS_DicItem::GetType ( ) const
parameter type
References myType.
◆ GetUnitData()
DDS_DicItem::UnitData * DDS_DicItem::GetUnitData ( const UnitSystem &  sys) const
sysunits system
units system information structure
References myUnitData.
◆ GetUnits() [1/2]
TCollection_AsciiString DDS_DicItem::GetUnits ( ) const
parameter units
References GetActiveUnitSystem(), and GetUnits().
◆ GetUnits() [2/2]
TCollection_AsciiString DDS_DicItem::GetUnits ( const UnitSystem &  theSystem) const
If specified units system doesn't exist, empty string is returned.
parameter units
References GetUnitData(), and DDS_DicItem::UnitData::myUnits.
◆ GetWarningLevel()
DDS_MsgType DDS_DicItem::GetWarningLevel ( ) const
warning level
References myWarnLevel.
◆ GetZoomOrder()
Standard_Real DDS_DicItem::GetZoomOrder ( ) const
lateral zooming order
References myZoomOrder.
◆ Handle() [1/4]
DDS_DicItem::Handle ( Standard_Transient  )
◆ Handle() [2/4]
DDS_DicItem::Handle ( TColStd_HArray1OfExtendedString  )
◆ Handle() [3/4]
◆ Handle() [4/4]
DDS_DicItem::Handle ( TColStd_HArray1OfInteger  )
◆ HasData()
Standard_Boolean DDS_DicItem::HasData ( const Standard_Integer  flag) const
flagdata flag
true if data specified by flag exists
References myData.
◆ operator=()
void DDS_DicItem::operator= ( const DDS_DicItem &  )
◆ PrepareFormats()
void DDS_DicItem::PrepareFormats ( const TCollection_AsciiString &  theFormat)
◆ SetComponent()
void DDS_DicItem::SetComponent ( const Handle(Standard_Transient)&  theComponent)
theComponentcomponent pointer.
◆ SetDefaultValue() [1/2]
void DDS_DicItem::SetDefaultValue ( const Standard_Real &  theDefVal)
theDefValdefault value.
References DefaultValue, myData, and myDefValue.
◆ SetDefaultValue() [2/2]
void DDS_DicItem::SetDefaultValue ( const TCollection_AsciiString &  theDefStr)
theDefStrdefault value.
References myDefString.
◆ SetFilter()
void DDS_DicItem::SetFilter ( const TCollection_AsciiString &  theFilter)
theFilterfilter string.
◆ SetId()
void DDS_DicItem::SetId ( const TCollection_AsciiString &  theId)
theIdidentify string.
References myId.
◆ SetLabel()
void DDS_DicItem::SetLabel ( const TCollection_AsciiString &  theLabel)
theLabellabel string.
References myLabel.
◆ SetListOfValues() [1/2]
void DDS_DicItem::SetListOfValues ( const Handle(TColStd_HArray1OfExtendedString)&  theStrings,
const Handle(TColStd_HArray1OfInteger)&  theIntegers
theStringslist of value strings.
theIntegerslist of integer values associated with string item.
◆ SetListOfValues() [2/2]
const Handle(TColStd_HArray1OfInteger)&  theIntegers,
const Handle(TColStd_HArray1OfExtendedString)&  theIcons
theIconslist of icons associated with string item.
◆ SetLongDescription()
void DDS_DicItem::SetLongDescription ( const TCollection_ExtendedString &  theLongDescr)
theLongDescrlong description string.
◆ SetMax()
void DDS_DicItem::SetMax ( const Standard_Real &  theMaxVal)
theMaxValmaximum possible value.
References MaxValue, myData, and myMax.
◆ SetMaxZoom()
void DDS_DicItem::SetMaxZoom ( const Standard_Real &  theMaxZoom)
theMaxZoommaximum zoom value.
◆ SetMin()
void DDS_DicItem::SetMin ( const Standard_Real &  theMinVal)
theMinValminimum possible value.
References MinValue, myData, and myMin.
◆ SetMinZoom()
void DDS_DicItem::SetMinZoom ( const Standard_Real &  theMinZoom)
theMinZoomminimum zoom value.
◆ SetOption()
bool DDS_DicItem::SetOption ( const TCollection_AsciiString &  theOptionName,
const TCollection_AsciiString &  theOptionValue
Add item's option.
theOptionNameoption name string.
theOptionValueoption value string.
◆ SetRequired()
void DDS_DicItem::SetRequired ( const TCollection_AsciiString &  theRequired)
theRequiredrequired value string.
◆ SetShortDescription()
void DDS_DicItem::SetShortDescription ( const TCollection_ExtendedString &  theShortDescr)
theShortDescrshort description string.
◆ SetType()
void DDS_DicItem::SetType ( const DDS_DicItem::Type &  theType)
theTypeitem value type.
References myType.
◆ SetWarningLevel()
void DDS_DicItem::SetWarningLevel ( const Standard_Integer &  theWarningLevel)
theWarningLevelwarning level value.
◆ SetZoomOrder()
void DDS_DicItem::SetZoomOrder ( const Standard_Real &  theZoomOrder)
theZoomOrderzoom order value.
◆ Split()
void DDS_DicItem::Split ( const TCollection_AsciiString &  theStr,
Handle(TColStd_HArray1OfExtendedString)&  aRes
theStrsource string
aResreturning substrings array
◆ ToSI() [1/2]
Standard_Real DDS_DicItem::ToSI ( const Standard_Real  theVal) const
References GetActiveUnitSystem(), and ToSI().
◆ ToSI() [2/2]
Standard_Real DDS_DicItem::ToSI ( const Standard_Real  theVal,
value converted to the specified units system
◆ DDS_DicGroup
friend class DDS_DicGroup
friend
◆ myData
Standard_Integer DDS_DicItem::myData
◆ myDefString
TCollection_ExtendedString DDS_DicItem::myDefString
◆ myDefValue
Standard_Real DDS_DicItem::myDefValue
◆ myFilter
TCollection_ExtendedString DDS_DicItem::myFilter
◆ myId
TCollection_AsciiString DDS_DicItem::myId
◆ myLabel
TCollection_ExtendedString DDS_DicItem::myLabel
◆ myListName
TCollection_ExtendedString DDS_DicItem::myListName
◆ myLongDescr
TCollection_ExtendedString DDS_DicItem::myLongDescr
◆ myMax
Standard_Real DDS_DicItem::myMax
◆ myMaxZoom
Standard_Real DDS_DicItem::myMaxZoom
◆ myMin
Standard_Real DDS_DicItem::myMin
◆ myMinZoom
Standard_Real DDS_DicItem::myMinZoom
◆ myOptions
OptionsMap DDS_DicItem::myOptions
◆ myRequired
TCollection_ExtendedString DDS_DicItem::myRequired
◆ myShortDescr
TCollection_ExtendedString DDS_DicItem::myShortDescr
◆ myType
Standard_Integer DDS_DicItem::myType
◆ myUnitData
NCollection_DataMap<UnitSystem, UnitData> DDS_DicItem::myUnitData
◆ myWarnLevel
Standard_Integer DDS_DicItem::myWarnLevel
◆ myZoomOrder
Standard_Real DDS_DicItem::myZoomOrder
