DDS_KeyWords Class Reference
This class defines the pairs of internal keys and XML tags or attributes names. More...
#include <DDS_KeyWords.h>
Inheritance diagram for DDS_KeyWords:
Standard_EXPORT TCollection_AsciiString GetKeyWord (const TCollection_AsciiString &) const
 Get the XML keyword by specified internal key key. More...
Standard_EXPORT void SetKeyWord (const TCollection_AsciiString &, const TCollection_AsciiString &)
 Register the pair of the internal key key and XML keyword keyWord. More...
static Standard_EXPORT Handle (DDS_KeyWords) Get()
Private Types
typedef NCollection_DataMap< TCollection_AsciiString, TCollection_AsciiString > KeyWordMap
 DDS_KeyWords ()
KeyWordMap myKeyWord
This class allows user to define a set of XML keywords used in the datums definition (XML) file.
Default keywords table:
  • D_URI - dictionary
  • COMPONENT - component
  • COMPONENT_NAME - name
  • UNIT_SYSTEMS - unitSystems
  • UNIT_SYSTEM - system
  • UNIT_SYSTEM_NAME - name
  • UNIT_SYSTEM_LABEL - label
  • DATUM - datum
  • DATUM_ID - id
  • DATUM_LABEL - label
  • DATUM_UNITS - units
  • DATUM_FORMAT - format
  • DATUM_FILTER - filter
  • DATUM_REQUIRED - required
  • VALUE_LIST - valueList
  • VALUE_LIST_ID - listid
  • VALUE_LIST_NAME - name
  • VALUE_LIST_TYPE - type
  • VALUE_LIST_VALUE - value
  • VALUE_LIST_VALUEID - id
  • VALUE_LIST_VALUEICON - icon
  • DY_DOMAIN - domain
  • WARNING_LEVEL - warningLevel
  • WRONG_VALUE - wrongValue
  • VALUE_DESCR - valueDescr
  • VALUE_LIST_REF - listRef
  • DESCR - description
  • LONG_D - longDescr
  • SHORT_D - shortDescr
  • VD_TYPE - type
  • VD_DEFV - default
  • VD_MAXV - max
  • VD_MINV - min
  • VD_SPEC - specVal
  • VLR_LIST - list
  • PRS - presentation
  • LATERAL_ZOOM - lateralZoom
  • LZ_MINV - min
  • LZ_MAXV - max
  • LZ_ORDER - order
  • OPTIONS - options
  • OPTION - option
  • OPTION_NAME - name
There is the only instance of the class DDS_KeyWords in the application which can be retrieved by method Get().
◆ KeyWordMap
typedef NCollection_DataMap<TCollection_AsciiString, TCollection_AsciiString> DDS_KeyWords::KeyWordMap
◆ DDS_KeyWords()
DDS_KeyWords::DDS_KeyWords ( )
◆ GetKeyWord()
TCollection_AsciiString DDS_KeyWords::GetKeyWord ( const TCollection_AsciiString &  key) const
If the internal key is not registered, empty string is returned.
keyinternal key
XML keyword
References myKeyWord.
◆ Handle()
static Standard_EXPORT DDS_KeyWords::Handle ( DDS_KeyWords  )
◆ SetKeyWord()
void DDS_KeyWords::SetKeyWord ( const TCollection_AsciiString &  key,
const TCollection_AsciiString &  keyWord
keyinternal key
keyWordXML keyword
◆ myKeyWord
KeyWordMap DDS_KeyWords::myKeyWord
