GLViewer_Selector Class Referenceabstract
#include <GLViewer_Selector.h>
Inheritance diagram for GLViewer_Selector:
Signals
void selSelectionCancel ()
void selSelectionDone (bool append, SelectionChangeStatus status)
 GLViewer_Selector (GLViewer_Viewer *)
 ~GLViewer_Selector ()
void lock (bool)
 Sets lock status (enable/disable interavtive) More...
void setMinRectSize (const QSize &minSize)
virtual void detect (int x, int y)=0
 Highlights in point (x,y) More...
virtual void undetectAll ()=0
virtual void select (bool append=false)=0
 Selects highlight objects. More...
virtual void select (const QRect &, bool append=false)=0
 Selects by rect. More...
virtual void unselectAll ()=0
virtual int numSelected () const =0
virtual void setHilightColor (Quantity_NameOfColor)=0
virtual void setSelectColor (Quantity_NameOfColor)=0
virtual void checkSelection (int, bool, int)=0
 Checks selection state and emits 'selSelectionDone' or 'selSelectionCancel'
More...
static int appendKey ()
static void setAppendKey (int k)
GLViewer_Viewer * myViewer
bool myLocked
QSize myMinRectSize
Static Private Attributes
static int apppendKey = Qt::ShiftModifier
\Class GLViewer_Selector Base class for object selection in SUIT-based application
◆ GLViewer_Selector()
GLViewer_Selector::GLViewer_Selector ( GLViewer_Viewer *  viewer)
Constructor
◆ ~GLViewer_Selector()
GLViewer_Selector::~GLViewer_Selector ( )
Destructor
◆ appendKey()
static int GLViewer_Selector::appendKey ( )
inlinestatic
Sets/returns the key for appending selected objects ( SHIFT by default )
◆ checkSelection()
virtual void GLViewer_Selector::checkSelection ( int  ,
bool  ,
int
pure virtual
Should be called by after non-interactive selection.
Implemented in GLViewer_Selector2d.
◆ detect()
virtual void GLViewer_Selector::detect ( int  x,
int  y
pure virtual
◆ lock()
void GLViewer_Selector::lock ( bool  locked)
Locks / unlocks the selector. If locked, nothing can be selected regadless of the selection mode. [ public ]
References myLocked.
◆ numSelected()
virtual int GLViewer_Selector::numSelected ( ) const
pure virtual
◆ select() [1/2]
virtual void GLViewer_Selector::select ( bool  append = false)
pure virtual
◆ select() [2/2]
virtual void GLViewer_Selector::select ( const QRect &  ,
bool  append = false
pure virtual
Selects by rect.
◆ selSelectionCancel
void GLViewer_Selector::selSelectionCancel ( )
signal
◆ selSelectionDone
void GLViewer_Selector::selSelectionDone ( bool  append,
signal
◆ setAppendKey()
static void GLViewer_Selector::setAppendKey ( int  k)
inlinestatic
◆ setHilightColor()
virtual void GLViewer_Selector::setHilightColor ( Quantity_NameOfColor  )
pure virtual
◆ setMinRectSize()
void GLViewer_Selector::setMinRectSize ( const QSize &  minSize)
Sets the min size of rectangle to treat it as a rectangle for multiple selection( sensitivity ). If a rectangle size is less than that min size, the right-bottom point of the rectangle will be used for single selection. The default min size is ( 1,1 ). [ public ]
References myMinRectSize.
◆ setSelectColor()
virtual void GLViewer_Selector::setSelectColor ( Quantity_NameOfColor  )
pure virtual
◆ undetectAll()
virtual void GLViewer_Selector::undetectAll ( )
pure virtual
◆ unselectAll()
virtual void GLViewer_Selector::unselectAll ( )
pure virtual
◆ apppendKey
int GLViewer_Selector::apppendKey = Qt::ShiftModifier
staticprivate
◆ myLocked
bool GLViewer_Selector::myLocked
◆ myMinRectSize
QSize GLViewer_Selector::myMinRectSize
◆ myViewer
GLViewer_Viewer* GLViewer_Selector::myViewer
