GLViewer_Widget Class Reference
#include <GLViewer_Widget.h>
Inheritance diagram for GLViewer_Widget:
 GLViewer_Widget (QWidget *theParent, const char *theName=0)
 A constructor. More...
 ~GLViewer_Widget ()
 A destructor. More...
GLViewer_ViewPort2d * getViewPort () const
 Returns parent GLViewer_ViewPort2d. More...
GLint getWidth () const
 Returns width of OpenGl Window. More...
GLint getHeight () const
 Returns height of OpenGl Window. More...
void getScale (GLfloat &xScale, GLfloat &yScale, GLfloat &zScale)
 Returns scales on OpenGL scene along 3 directions. More...
void setScale (GLfloat xScale, GLfloat yScale, GLfloat zScaleGLfloat)
 A function for installing the scales of OpenGL scene. More...
void getPan (GLfloat &xPan, GLfloat &yPan, GLfloat &zPan)
 Returns offset parameters of Window in OpenGL global scene. More...
void setPan (GLfloat xPan, GLfloat yPan, GLfloat zPan)
 A function for installing the offset parameters of Window in OpenGL global scene. More...
GLfloat getRotationAngle () const
 Returns rotation angle of Window in OpenGL global scene in degree. More...
void setRotationAngle (GLfloat a)
 A function for installing the rotation angle of Window in OpenGL global scene in degree. More...
void getRotationStart (GLfloat &rotationStartX, GLfloat &rotationStartY, GLfloat &rotationStartZ)
 Returns start point of curren rotation of Window in OpenGL global scene. More...
void setRotationStart (GLfloat rotationStartX, GLfloat rotationStartY, GLfloat rotationStartZ)
 A function for installing the start point of curren rotation of Window in OpenGL global scene. More...
void getRotation (GLfloat &rotationAngle, GLfloat &rotationCenterX, GLfloat &rotationCenterY, GLfloat &rotationCenterZ)
 Returns parameters of current rotation. More...
void setRotation (GLfloat, GLfloat, GLfloat, GLfloat)
 A function for installing the parameters of current rotation. More...
void setBackground (QString theFileName)
 A function load picture from file with name theFileName and post it in center of global OpenGL scene. More...
void addToolTip (QString theTTText, QRect theTTRect)
 A function add the tool tip with text theTTText on theTTRect rect to the widget window. More...
void removeToolTip ()
 A function remove tool tip form widget window. More...
virtual void translateBackgroundToPS (QFile &hFile, GLViewer_CoordSystem *aViewerCS, GLViewer_CoordSystem *aPSCS)
 A function translate background of window in to PostScript file on disk. More...
void exportRepaint ()
 A function repaints OpenGL scene in export mode. More...
virtual void initializeGL ()
 A function is called before first display of window (create OpenGL scene) More...
virtual void paintGL ()
 A function is called in earch paint event of window. More...
virtual void resizeGL (int, int)
 A function is called in earch resize event of window. More...
virtual void paintEvent (QPaintEvent *)
virtual void mouseMoveEvent (QMouseEvent *)
virtual void mousePressEvent (QMouseEvent *)
virtual void mouseReleaseEvent (QMouseEvent *)
virtual void enterEvent (QEvent *)
virtual void leaveEvent (QEvent *)
virtual bool event (QEvent *)
void getBackgroundRectInViewerCS (double &left, double &top, double &right, double &bottom)
 Auxiliary function. Returns rect of window background in viewer coordinate system. More...
GLint myWidth
 width of window More...
GLint myHeight
 height of window More...
GLfloat myXScale
 Scale along X direction. More...
GLfloat myYScale
 Scale along Y direction. More...
GLfloat myZScale
 Scale along Z direction. More...
GLfloat myXPan
 Window offset along X direction. More...
GLfloat myYPan
 Window offset along Y direction. More...
GLfloat myZPan
 Window offset along Z direction. More...
GLfloat myRotationStartX
GLfloat myRotationStartY
GLfloat myRotationStartZ
GLfloat myRotationAngle
GLfloat myRotationCenterX
GLfloat myRotationCenterY
GLfloat myRotationCenterZ
GLfloat myRotationAnglePrev
GLboolean myStart
GLViewer_ViewPort2d * myViewPort
bool isLoadBackground
 True if background is loaded. More...
QString myBackgroundFile
 File name of background image. More...
GLuint texName
 Texture id of loaded background image. More...
int myIW
 Width of background image. More...
int myIH
 Height of background image. More...
int myBackgroundSize
 Size of background image. More...
QRect myToolTipRect
bool isExportMode
 Needs for export repaint. More...
Widget for visualization of OpenGL scene
◆ GLViewer_Widget()
GLViewer_Widget::GLViewer_Widget ( QWidget *  parent,
const char *  theName = 0
A constructor.
Parameters using for QOGLWidget as is
A constructor Parameters using for QOGLWidget as is
References isExportMode, myRotationAngle, myRotationAnglePrev, myRotationCenterX, myRotationCenterY, myRotationCenterZ, myStart, myViewPort, myXPan, myXScale, myYPan, myYScale, myZPan, and myZScale.
◆ ~GLViewer_Widget()
GLViewer_Widget::~GLViewer_Widget ( )
A destructor.
Destructor
◆ addToolTip()
void GLViewer_Widget::addToolTip ( QString  theString,
QRect  theRect
Adds tooltip
theString- tooltip text
theRect- tooltip rectangle
References myToolTipRect.
◆ enterEvent()
void GLViewer_Widget::enterEvent ( QEvent *  )
Custom enter event handler
◆ event()
bool GLViewer_Widget::event ( QEvent *  e)
Custom leave event handler
◆ exportRepaint()
void GLViewer_Widget::exportRepaint ( )
Provides repaint in export mode
References isExportMode, and paintGL().
◆ getBackgroundRectInViewerCS()
void GLViewer_Widget::getBackgroundRectInViewerCS ( double &  left,
double &  top,
double &  right,
double &  bottom
background rectangle in viewer CS
References myIH, and myIW.
◆ getHeight()
GLint GLViewer_Widget::getHeight ( ) const
◆ getPan()
void GLViewer_Widget::getPan ( GLfloat &  xPan,
GLfloat &  yPan,
GLfloat &  zPan
References myXPan, myYPan, and myZPan.
◆ getRotation()
void GLViewer_Widget::getRotation ( GLfloat &  rotationAngle,
GLfloat &  rotationCenterX,
GLfloat &  rotationCenterY,
GLfloat &  rotationCenterZ
parameters of rotation
rotationAngle- angle
rotationCenterX- center x
rotationCenterY- center y
rotationCenterZ- center z
References myRotationAngle, myRotationCenterX, myRotationCenterY, and myRotationCenterZ.
◆ getRotationAngle()
GLfloat GLViewer_Widget::getRotationAngle ( ) const
Only in 2D
◆ getRotationStart()
void GLViewer_Widget::getRotationStart ( GLfloat &  rotationStartX,
GLfloat &  rotationStartY,
GLfloat &  rotationStartZ
References myRotationStartX, myRotationStartY, and myRotationStartZ.
◆ getScale()
void GLViewer_Widget::getScale ( GLfloat &  xScale,
GLfloat &  yScale,
GLfloat &  zScale
in 2d scene zScale = 1.0
scales on OpenGL scene along 3 directions in 2d scene zScale = 1.0
References myXScale, myYScale, and myZScale.
◆ getViewPort()
GLViewer_ViewPort2d * GLViewer_Widget::getViewPort ( ) const
ViewPort2d because this class is not use for 3D Viewer
◆ getWidth()
GLint GLViewer_Widget::getWidth ( ) const
◆ initializeGL()
void GLViewer_Widget::initializeGL ( )
Initialization (redefined virtual from QGLWidget)
References Qtx::getenv(), isLoadBackground, and setBackground().
◆ leaveEvent()
void GLViewer_Widget::leaveEvent ( QEvent *  )
◆ mouseMoveEvent()
void GLViewer_Widget::mouseMoveEvent ( QMouseEvent *  e)
Custom mouse move event handler
References myViewPort.
◆ mousePressEvent()
void GLViewer_Widget::mousePressEvent ( QMouseEvent *  e)
Custom mouse press event handler
◆ mouseReleaseEvent()
void GLViewer_Widget::mouseReleaseEvent ( QMouseEvent *  e)
Custom mouse release event handler
◆ paintEvent()
void GLViewer_Widget::paintEvent ( QPaintEvent *  e)
Custom paint event handler
◆ paintGL()
◆ removeToolTip()
void GLViewer_Widget::removeToolTip ( )
Removes tooltip
◆ resizeGL()
void GLViewer_Widget::resizeGL ( int  w,
int  h
Resets OpenGl parameters after resize
w- new width
h- new height
References GLViewer_ViewPort2d::initResize(), myHeight, myStart, myViewPort, and myWidth.
◆ setBackground()
void GLViewer_Widget::setBackground ( QString  filename)
Sets image as background
filename- name of file
References isLoadBackground, myBackgroundFile, myBackgroundSize, myIH, myIW, and texName.
◆ setPan()
void GLViewer_Widget::setPan ( GLfloat  xPan,
GLfloat  yPan,
GLfloat  zPan
◆ setRotation()
void GLViewer_Widget::setRotation ( GLfloat  rotationAngle,
GLfloat  rotationCenterX,
GLfloat  rotationCenterY,
GLfloat  rotationCenterZ
Sets parameters of rotation
◆ setRotationAngle()
void GLViewer_Widget::setRotationAngle ( GLfloat  a)
Only in 2D
◆ setRotationStart()
void GLViewer_Widget::setRotationStart ( GLfloat  rotationStartX,
A function for installing the rotation angle of Window in OpenGL global scene in degree (Only in 2D)
◆ setScale()
void GLViewer_Widget::setScale ( GLfloat  xScale,
GLfloat  yScale,
GLfloat  zScale
◆ translateBackgroundToPS()
void GLViewer_Widget::translateBackgroundToPS ( QFile &  hFile,
GLViewer_CoordSystem *  aViewerCS,
GLViewer_CoordSystem *  aPSCS
hFilethe name of PostScript file chosen by user
aViewerCSthe GLViewer_CoordSystem of window
aPSCSthe GLViewer_CoordSystem of PostScript page
Translates background to PostScript
hFile- PostScript file
aViewerCS- viewer co-ordinate system
aPSCS- paper co-ordinate system
References AddImagePart(), getBackgroundRectInViewerCS(), isLoadBackground, myBackgroundFile, and GLViewer_CoordSystem::transform().
◆ isExportMode
bool GLViewer_Widget::isExportMode
◆ isLoadBackground
bool GLViewer_Widget::isLoadBackground
◆ myBackgroundFile
QString GLViewer_Widget::myBackgroundFile
◆ myBackgroundSize
int GLViewer_Widget::myBackgroundSize
◆ myHeight
GLint GLViewer_Widget::myHeight
height of window
◆ myIH
int GLViewer_Widget::myIH
◆ myIW
int GLViewer_Widget::myIW
◆ myRotationAngle
GLfloat GLViewer_Widget::myRotationAngle
◆ myRotationAnglePrev
GLfloat GLViewer_Widget::myRotationAnglePrev
◆ myRotationCenterX
GLfloat GLViewer_Widget::myRotationCenterX
◆ myRotationCenterY
GLfloat GLViewer_Widget::myRotationCenterY
◆ myRotationCenterZ
GLfloat GLViewer_Widget::myRotationCenterZ
◆ myRotationStartX
GLfloat GLViewer_Widget::myRotationStartX
◆ myRotationStartY
GLfloat GLViewer_Widget::myRotationStartY
◆ myRotationStartZ
GLfloat GLViewer_Widget::myRotationStartZ
◆ myStart
GLboolean GLViewer_Widget::myStart
◆ myToolTipRect
QRect GLViewer_Widget::myToolTipRect
◆ myViewPort
GLViewer_ViewPort2d* GLViewer_Widget::myViewPort
◆ myWidth
GLint GLViewer_Widget::myWidth
width of window
◆ myXPan
GLfloat GLViewer_Widget::myXPan
◆ myXScale
GLfloat GLViewer_Widget::myXScale
◆ myYPan
GLfloat GLViewer_Widget::myYPan
◆ myYScale
GLfloat GLViewer_Widget::myYScale
◆ myZPan
GLfloat GLViewer_Widget::myZPan
◆ myZScale
GLfloat GLViewer_Widget::myZScale
◆ texName
GLuint GLViewer_Widget::texName
