Implementation of the color mask operator. More...
#include <ImageComposer_ColorMaskOperator.h>
| ImageComposer_ColorMaskOperator () | |
| Constructor. More... | |
| virtual | ~ImageComposer_ColorMaskOperator () |
| void | setArgs (const QColor &theRefColor, bool isMakeTransparent, int theRGBThreshold, int theAlphaThreshold) |
| Set operator arguments. More... | |
| virtual QString | name () const |
| Return name of the operator. More... | |
| QStringList | dumpArgsToPython (QString &theArrayName) const |
| Dumps arguments of operator to python script representation. More... | |
Public Member Functions inherited from ImageComposer_Operator | |
| ImageComposer_Operator () | |
| virtual | ~ImageComposer_Operator () |
| Destructor. More... | |
| void | getArgs (QColor &theBackground) const |
| Get operator arguments. More... | |
| void | setArgs (const QColor &theBackground) |
| QByteArray | getBinArgs () const |
| Get the operator's arguments in the form of a binary array. More... | |
| void | setBinArgs (const QByteArray &) |
| Set the operator's arguments in the form of a binary array. More... | |
| virtual QString | name () const =0 |
| virtual ImageComposer_Image | process (const QVariant &theObj1, const QVariant &theObj2) const |
| Perform the composing of images. More... | |
| static QString | Type () |
| virtual QRectF | calcResultBoundingRect (const QVariant &theObj1, const QVariant &theObj2) const |
| Calculate bounding rectangle for the result image. More... | |
| virtual void | drawResult (QPainter &thePainter, const QVariant &theObj1, const QVariant &theObj2) const |
| Draw result image using the given painter. More... | |
| virtual void | storeArgs (QDataStream &theStream) const |
| Store the operator's arguments to the stream. More... | |
| virtual void | restoreArgs (QDataStream &theStream) |
| Restore the operator's arguments from the stream. More... | |
| virtual QRectF | calcResultBoundingRect (const QVariant &theObj1, const QVariant &theObj2) const =0 |
| virtual void | drawResult (QPainter &thePainter, const QVariant &theObj1, const QVariant &theObj2) const =0 |
Private Attributes | |
| QColor | myRefColor |
| the color to the searched (the color for mask) More... | |
| bool | myIsMakeTransparent |
| the boolean flag controlling if the pixels with matching color should be made transparent or one with non-matching color More... | |
| int | myRGBThreshold |
| the threshold for RGB components More... | |
| int | myAlphaThreshold |
| the threshold for Alpha component More... | |
Friends | |
| class | ImageComposerTests_TestOperators |
| ImageComposer_ColorMaskOperator::ImageComposer_ColorMaskOperator | ( | ) |
protectedvirtual |
| theObj1 | first object to calculate |
| theObj2 | second object to calculate |
Implements ImageComposer_Operator.
References ImageComposer_Image::boundingRect().
protectedvirtual |
| thePainter | the painter on the result image |
| theObj1 | the first object to compose |
| theObj2 | the second object to compose |
References ImageComposer_Image::draw(), myAlphaThreshold, myIsMakeTransparent, myRefColor, myRGBThreshold, ImageComposer_Image::setTransform(), ImageComposer_Image::transform(), and TRANSPARENT().
| QStringList ImageComposer_ColorMaskOperator::dumpArgsToPython | ( | QString & | theArrayName | ) | const |
| theArrayName | name of result QByteArray array variable |
References ImageComposer_Operator::dumpArgsToPython(), myAlphaThreshold, myIsMakeTransparent, myRefColor, and myRGBThreshold.
References Type().
protectedvirtual |
| theStream | the stream for restoring |
Reimplemented from ImageComposer_Operator.
References myAlphaThreshold, myIsMakeTransparent, myRefColor, myRGBThreshold, and ImageComposer_Operator::restoreArgs().
| void ImageComposer_ColorMaskOperator::setArgs | ( | const QColor & | theRefColor, |
| bool | isMakeTransparent, | ||
| int | theRGBThreshold, | ||
| int | theAlphaThreshold | ||
| theRefColor | the color to the searched (the color for mask) |
| isMakeTransparent | the boolean flag controlling if the pixels with matching color should be made transparent or one with non-matching color |
| theRGBThreshold | the threshold for RGB components |
| theAlphaThreshold | the threshold for Alpha component |
References myAlphaThreshold, myIsMakeTransparent, myRefColor, and myRGBThreshold.
protectedvirtual |
| theStream | the stream for storing |
References myAlphaThreshold, myIsMakeTransparent, myRefColor, myRGBThreshold, and ImageComposer_Operator::storeArgs().
inlinestatic |
friend |
private |
private |
private |
private |
