LightApp_Driver Class Reference
#include <LightApp_Driver.h>
Inheritance diagram for LightApp_Driver:
typedef std::vector< std::string > ListOfFiles
 LightApp_Driver ()
virtual ~LightApp_Driver ()
virtual bool SaveDatasInFile (const char *theFileName, bool isMultiFile)
virtual bool ReadDatasFromFile (const char *theFileName, bool isMultiFile)
virtual std::string GetTmpDir (const char *theURL, const bool isMultiFile)
ListOfFiles GetListOfFiles (const char *theModuleName)
virtual void SetListOfFiles (const char *theModuleName, const ListOfFiles theListOfFiles)
virtual void RemoveTemporaryFiles (const char *theModuleName, const bool IsDirDeleted)
void RemoveFiles (const ListOfFiles &theFiles, const bool IsDirDeleted)
virtual void ClearDriverContents ()
Protected Types
typedef std::map< std::string, ListOfFiles > MapOfListOfFiles
void PutFilesToStream (const std::string &theModuleName, unsigned char *&theBuffer, long &theBufferSize, bool theNamesOnly=false)
ListOfFiles PutStreamToFiles (const unsigned char *theBuffer, const long theBufferSize, bool theNamesOnly=false)
std::string GetTmpDir ()
std::string GetDirFromPath (const std::string &thePath)
void SetIsTemporary (bool theFlag)
bool IsTemporary () const
MapOfListOfFiles myMap
std::string myTmpDir
bool myIsTemp
Description : Driver can save to file and read from file list of files for light modules
◆ ListOfFiles
typedef std::vector<std::string> LightApp_Driver::ListOfFiles
◆ MapOfListOfFiles
typedef std::map<std::string, ListOfFiles> LightApp_Driver::MapOfListOfFiles
◆ LightApp_Driver()
LightApp_Driver::LightApp_Driver ( )
◆ ~LightApp_Driver()
LightApp_Driver::~LightApp_Driver ( )
◆ ClearDriverContents()
void LightApp_Driver::ClearDriverContents ( )
Clears map of list files
References IsTemporary(), myMap, RemoveTemporaryFiles(), and SetIsTemporary().
◆ GetDirFromPath()
std::string LightApp_Driver::GetDirFromPath ( const std::string &  thePath)
the dir by the path
◆ GetListOfFiles()
LightApp_Driver::ListOfFiles LightApp_Driver::GetListOfFiles ( const char *  theModuleName)
list of files for module with name 'theModuleName'
References myMap.
◆ GetTmpDir() [1/2]
std::string LightApp_Driver::GetTmpDir ( )
a temp directory to store created files like "/tmp/sub_dir/"
References myTmpDir.
◆ GetTmpDir() [2/2]
std::string LightApp_Driver::GetTmpDir ( const char *  theURL,
temp directory for path 'theURL'
References GetDirFromPath(), and GetTmpDir().
◆ IsTemporary()
bool LightApp_Driver::IsTemporary ( ) const
inlineprotected
◆ PutFilesToStream()
void LightApp_Driver::PutFilesToStream ( const std::string &  theModuleName,
unsigned char *&  theBuffer,
long &  theBufferSize,
bool  theNamesOnly = false
Converts files which was created from module <theModuleName> into a byte sequence unsigned char
< TODO: conversion size_t to int
< TODO: conversion from size_t to int
References myMap.
◆ PutStreamToFiles()
LightApp_Driver::ListOfFiles LightApp_Driver::PutStreamToFiles ( const unsigned char *  theBuffer,
Converts a byte sequence <theBuffer> to files and return list of them
References GetTmpDir(), and SetIsTemporary().
◆ ReadDatasFromFile()
bool LightApp_Driver::ReadDatasFromFile ( const char *  theFileName,
bool  isMultiFile
Filling current driver from file 'theFileName'
Reimplemented in LightApp_HDFDriver.
References myTmpDir, PutStreamToFiles(), and SetListOfFiles().
◆ RemoveFiles()
void LightApp_Driver::RemoveFiles ( const ListOfFiles &  theFiles,
Remove files. First item in <theFiles> is a directory with slash at the end. Other items are names of files. If <IsDirDeleted> is true, then the directory is also deleted.
◆ RemoveTemporaryFiles()
void LightApp_Driver::RemoveTemporaryFiles ( const char *  theModuleName,
Removes files which was created from module theModuleName if <IsDirDeleted> is true tmp directory is also deleted if it is empty
References myMap, and RemoveFiles().
◆ SaveDatasInFile()
bool LightApp_Driver::SaveDatasInFile ( const char *  theFileName,
bool  isMultiFile
Save in file 'theFileName' datas from this driver
References myMap, myTmpDir, and PutFilesToStream().
◆ SetIsTemporary()
void LightApp_Driver::SetIsTemporary ( bool  theFlag)
inlineprotected
◆ SetListOfFiles()
void LightApp_Driver::SetListOfFiles ( const char *  theModuleName,
Sets list of files for module with name 'theModuleName'
References myMap.
◆ myIsTemp
bool LightApp_Driver::myIsTemp
◆ myMap
MapOfListOfFiles LightApp_Driver::myMap
◆ myTmpDir
std::string LightApp_Driver::myTmpDir
