LightApp_ModuleDlg Class Reference
A dialog box allowing to select study operation to be performed on the module activating. More...
#include <LightApp_ModuleDlg.h>
Inheritance diagram for LightApp_ModuleDlg:
Public Slots
void accept ()
 Called when any dialog button (except Cancel) is clicked. More...
 LightApp_ModuleDlg (QWidget *, const QString &, const QPixmap &=QPixmap())
 ~LightApp_ModuleDlg ()
int addButton (const QString &, const int=-1)
 Add operation button to the dialog box. More...
Private Types
typedef QMap< QPushButton *, int > ButtonMap
QPushButton * findButton (const int) const
 Search button with the specified identifier. More...
ButtonMap myButtons
QHBoxLayout * myButtonLayout
The dialog box is shown when the user tries to activate any module while there is no opened study. The dialog box proposes user to select one of the possible operations which should be done before module activating, for example, create new study or open study from the file. The available operations are assigned by adding the buttons with the unique identifier to the dialog box. When the user clicks any operation button, the dialog box sets its identifier as the return code and closes.
The typical usage of the dialog box:
LightApp_ModuleDlg dlg( desktop() );
dlg.addButton( "New study", NewStudyId );
dlg.addButton( "Open study...", OpenStudyId );
int ret = dlg.exec();
switch( ret ) {
case NewStudyId:
// create new study
createNewStudy();
break;
case OpenStudyId:
// open study from the file
// ... show dialog box to choose the file
QString fileName = QFileDialog::getOpenFileName( desktop(), "Open File" );
if ( !fileName.isEmpty() )
openStudy( fileName );
break;
default:
// operation is cancelled
break;
Definition: LightApp_ModuleDlg.h:39
See also
addButton()
◆ ButtonMap
typedef QMap<QPushButton*,int> LightApp_ModuleDlg::ButtonMap
◆ LightApp_ModuleDlg()
LightApp_ModuleDlg::LightApp_ModuleDlg ( QWidget *  parent,
const QString &  component,
const QPixmap &  icon = QPixmap()
parentparent widget
componentmodule name
iconmodule icon
References default_icon, and myButtonLayout.
◆ ~LightApp_ModuleDlg()
LightApp_ModuleDlg::~LightApp_ModuleDlg ( )
◆ accept
void LightApp_ModuleDlg::accept ( )
slot
Closes the dialog and sets its result code to the identifier of the button clicked by the user.
References myButtons.
◆ addButton()
int LightApp_ModuleDlg::addButton ( const QString &  button,
const int  id = -1
If the parameter id is equal to -1, then the button identifier is generated automatically.
buttonbutton text
idbutton identifier
button identifier
References accept(), findButton(), myButtonLayout, and myButtons.
◆ findButton()
QPushButton * LightApp_ModuleDlg::findButton ( const int  id) const
idbutton identifier
button or 0 if id is invalid
◆ myButtonLayout
QHBoxLayout* LightApp_ModuleDlg::myButtonLayout
◆ myButtons
ButtonMap LightApp_ModuleDlg::myButtons
