QDS_StringValidator Class Reference
A validator for string values. More...
#include <QDS_Validator.h>
Inheritance diagram for QDS_StringValidator:
 QDS_StringValidator (QObject *p=0)
 QDS_StringValidator (const QString &f, QObject *p=0)
 QDS_StringValidator (const QString &ft, const QString &fg, QObject *p=0)
virtual ~QDS_StringValidator ()
virtual State validate (QString &, int &) const
 Validate the entered string input. More...
int length () const
 Get maximum valid string length. More...
void setLength (const int)
 Set maximum valid string length. More...
int myLen
 string length More...
QString myFlags
 string format flags More...
QString myFilter
 string filter More...
This class provides validation of the strings entered by the user for datum with 'String' value type according to datum properties: format, filter.
Inherits from QValidator.
◆ QDS_StringValidator() [1/3]
QDS_StringValidator::QDS_StringValidator ( QObject *  p = 0)
Create empty validator object.
pparent object
◆ QDS_StringValidator() [2/3]
QDS_StringValidator::QDS_StringValidator ( const QString &  f,
QObject *  p = 0
Create validator object with filter string f.
ffilter string
pparent object
◆ QDS_StringValidator() [3/3]
QDS_StringValidator::QDS_StringValidator ( const QString &  ft,
const QString &  fg,
QObject *  p = 0
Create validator object with filter string ft and format flags fg.
ftfilter string
fgformat string
pparent object
◆ ~QDS_StringValidator()
QDS_StringValidator::~QDS_StringValidator ( )
◆ length()
int QDS_StringValidator::length ( ) const
If maximum length is not specified, -1 is returned.
maximum string length
References myLen.
◆ setLength()
void QDS_StringValidator::setLength ( const int  l)
If l <= 0 is not specified, maximum valid length is reset (any string length is valid).
lmaximum strin length
References myLen.
◆ validate()
QValidator::State QDS_StringValidator::validate ( QString &  input,
int &  pos
Reimplemented from QValidator.
Convert specified string to the upper/lower case if the format flags contains specificator 'u'/'l' correspondingly. If valid string length is specified, then check given string length. If filter is specified, then perform also validation with filter by QRegExpValidator.
Returns QValidator::Invalid if input is invalid according to this validator's rules, QValidator::Intermediate if it is likely that a little more editing will make the input acceptable and QValidator::Acceptable if the input is valid.
inputstring being validated
poscursor position
validation state (QValidator::State)
References myFilter, myFlags, and myLen.
◆ myFilter
QString QDS_StringValidator::myFilter
string filter
◆ myFlags
QString QDS_StringValidator::myFlags
string format flags
◆ myLen
int QDS_StringValidator::myLen
string length
