QVTK_GenericRenderWindowInteractor Class Reference
#include <SVTK_GenericRenderWindowInteractor.h>
Inheritance diagram for QVTK_GenericRenderWindowInteractor:
 vtkTypeMacro (QVTK_GenericRenderWindowInteractor, vtkGenericRenderWindowInteractor) virtual int CreateTimer(int)
 Starts the QTimer instance on defined microseconds. More...
virtual int DestroyTimer ()
 Stops the QTimer instance. More...
static QVTK_GenericRenderWindowInteractor * New ()
Protected Slots
void OnTimeOut ()
 The slot connects to QTimer::timeout signal to invoke vtkCommand::TimerEvent. More...
 QVTK_GenericRenderWindowInteractor ()
 Instatiate QTimer. More...
 ~QVTK_GenericRenderWindowInteractor ()
 Destroy the instance of QTimer. More...
QTimer * myTimer
 Qt timer device. More...
Introduction of the class is intended to implement Qt based #CreateTimer and DestroyTimer functionality. The class intendes to implement platform indepenedant subclass of vtkRenderWindowInteractor. This is done by usage of Qt library.
The Signal/Slot mechanism used by Qt requires that QObject appear as the first class when using multiple inheritance. Hence the order of the two classes QObject and vtkRenderWindowInteractor matters here. So, be careful, not to change the sequence of the inheritance by accident.
◆ QVTK_GenericRenderWindowInteractor()
QVTK_GenericRenderWindowInteractor::QVTK_GenericRenderWindowInteractor ( )
Instatiate QTimer.
◆ ~QVTK_GenericRenderWindowInteractor()
QVTK_GenericRenderWindowInteractor::~QVTK_GenericRenderWindowInteractor ( )
Destructor
References myTimer.
◆ DestroyTimer()
int QVTK_GenericRenderWindowInteractor::DestroyTimer ( void  )
◆ New()
static QVTK_GenericRenderWindowInteractor * QVTK_GenericRenderWindowInteractor::New ( )
◆ OnTimeOut
void QVTK_GenericRenderWindowInteractor::OnTimeOut ( )
protectedslot
◆ vtkTypeMacro()
QVTK_GenericRenderWindowInteractor::vtkTypeMacro ( QVTK_GenericRenderWindowInteractor  ,
◆ myTimer
QTimer* QVTK_GenericRenderWindowInteractor::myTimer
Qt timer device.
