QtxActionMenuMgr Class Reference
Main menu actions manager. More...
#include <QtxActionMenuMgr.h>
Inheritance diagram for QtxActionMenuMgr:
class  MenuCreator
 Menu actions creator. More...
class  MenuNode
 Represents a menu item inside main menu structure. More...
Signals
void menuAboutToShow (QMenu *)
 Emitted when the menu is about to be shown. More...
void menuAboutToHide (QMenu *)
 Emitted when the menu is about to be hidden. More...
 QtxActionMenuMgr (QMainWindow *)
 QtxActionMenuMgr (QWidget *, QObject *)
virtual ~QtxActionMenuMgr ()
QWidget * menuWidget () const
 Get the menu widget. More...
virtual bool isVisible (const int, const int) const
 Check if an action with actId identifier is visible to the parent action with place identifier. More...
virtual void setVisible (const int, const int, const bool)
 Set action's visibility flag. More...
int insert (const int, const QString &, const int, const int=-1)
 Insert action to the menu. More...
int insert (QAction *, const QString &, const int, const int=-1)
int insert (const int, const QStringList &, const int, const int=-1)
int insert (QAction *, const QStringList &, const int, const int=-1)
virtual int insert (const int, const int, const int, const int=-1)
int insert (QAction *, const int, const int, const int=-1)
int insert (const QString &, const QString &, const int, const int=-1, const int=-1)
 Create and insert menu item action to the menu. More...
int insert (const QString &, const QStringList &, const int, const int=-1, const int=-1)
virtual int insert (const QString &, const int, const int, const int=-1, const int=-1, QMenu *=0)
int append (const int, const int, const int)
 Create and add menu item action to the end of menu. More...
int append (QAction *, const int, const int)
int append (const QString &, const int, const int, const int=-1)
int prepend (const int, const int, const int)
 Create and add menu item action to the beginning of menu. More...
int prepend (QAction *, const int, const int)
int prepend (const QString &, const int, const int, const int=-1)
void remove (const int)
 Remove menu item with given id. More...
void remove (const int, const int, const int=-1)
void show (const int)
 Show menu item with given id. More...
void hide (const int)
 Hide menu item with given id. More...
bool isShown (const int) const
 Get visibility status for menu item with given id. More...
void setShown (const int, const bool)
 Set visibility status for menu item with given id. More...
virtual void change (const int, const QString &)
 Change menu title for the action with given id. More...
virtual bool load (const QString &, QtxActionMgr::Reader &)
 Load actions description from the file. More...
bool containsMenu (const QString &, const int, const bool=false) const
 Check if the parent menu contains menu item with given title. More...
bool containsMenu (const int, const int, const bool=false) const
 Check if the parent menu contains menu item with given id. More...
QMenu * findMenu (const int) const
 Get menu by the specified identifier. More...
QMenu * findMenu (const QString &, const int, const bool=false) const
 Get menu by the title. More...
bool isEmptyEnabled (const int) const
 Check if empty menu is enabled. More...
void setEmptyEnabled (const int, const bool)
 Enable/disable empty menu. More...
- Public Member Functions inherited from QtxActionMgr
 QtxActionMgr (QObject *parent)
virtual ~QtxActionMgr ()
virtual int registerAction (QAction *, const int=-1)
 Register an action in the internal map. More...
virtual void unRegisterAction (const int)
 Unregister action from internal map. More...
QAction * action (const int) const
 Get action by specified identifier. More...
int actionId (const QAction *) const
 Get action identifier. More...
bool contains (const int) const
 Check if an action with given id is registered in the action manager. More...
int count () const
 Get total number of registered actions. More...
bool isEmpty () const
 Check if there are no actions registered in the action manager. More...
QIntList idList () const
 Get all registered actions identifiers. More...
bool isUpdatesEnabled () const
 Check if update is enabled. More...
virtual void setUpdatesEnabled (const bool)
 Enable/disable update operation. More...
void update ()
 Update actions. More...
virtual bool isEnabled (const int) const
 Check is action with given id is enabled. More...
virtual void setEnabled (const int, const bool)
void setMenuWidget (QWidget *)
 Assign new menu widget to the menu manager. More...
MenuNode * find (const int, const int, const bool=true) const
 Search menu node. More...
MenuNode * find (const int, MenuNode *=0, const bool=true) const
bool find (const int, NodeList &, MenuNode *=0) const
 Search recursively all menu nodes with given id. More...
MenuNode * find (const QString &, const int, const bool=true) const
MenuNode * find (const QString &, MenuNode *=0, const bool=true) const
bool find (const QString &, NodeList &, MenuNode *=0) const
 Search recursively all menu nodes with given title. More...
int findId (const int, const int=-1) const
 Find menu item by given ID (one-level only). More...
void removeMenu (const int, MenuNode *)
 Removes menu node (with all its children). More...
QAction * itemAction (const int) const
 Get action by id. More...
QAction * menuAction (const int) const
 Get submenu action by id. More...
int menuActionId (QAction *) const
void updateMenu (MenuNode *=0, const bool=true, const bool=true)
 Update menu. More...
virtual void internalUpdate ()
 Internal update. More...
virtual void updateContent ()
 Called when delayed content update is performed. More...
virtual void actionChanged (int)
 Called when action is changed. More...
- Protected Member Functions inherited from QtxActionMgr
int generateId () const
 Generate unique action identifier. More...
void triggerUpdate ()
 Perform delayed update. More...
 Internal content update operation. More...
 Internal action changing response operation. More...
Private Types
typedef QList< MenuNode * > NodeList
 menu nodes list More...
typedef QMap< int, QAction * > MenuMap
 actions map More...
Private Slots
void onAboutToShow ()
 Called when the submenu is about to show. More...
void onAboutToHide ()
 Called when the submenu is about to hide. More...
void onDestroyed (QObject *)
 Called when the corresponding menu object is destroyed. More...
bool ownAction (QAction *, MenuNode *) const
 Check if action belongs to the menu manager. More...
bool checkWidget (QWidget *) const
 Check if menu widget has any actions. More...
QWidget * menuWidget (MenuNode *) const
 Get menu widget for the given node. More...
void simplifySeparators (QWidget *)
 Remove extra separators from menu widget. More...
QString clearTitle (const QString &) const
 Remove special symbols (&) from string to get clear menu title. More...
int createMenu (const QStringList &, const int)
 Create and inserts menu item recursively. More...
void triggerUpdate (const int, const bool rec=true)
 Perform delayed menu update. More...
MenuNode * myRoot
 root menu node More...
QWidget * myMenu
 menu widget More...
MenuMap myMenus
 actions map More...
QMap< int, bool > myUpdateIds
 list of actions ID being updated More...
- Static Public Member Functions inherited from QtxActionMgr
static QAction * separator (const bool=false)
 Create new separator action. More...
Menu manager allows using of set of action for automatic generating of application main menu and dynamic update of its contents.
Use insert(), append() and remove() methods to create main menu. Methods show(), hide() allow displaying/erasing of specified menu items.
Actions can be grouped with help of group identificator. Inside the popup or main menu bar menu items are ordered by the group identifier (ascending).
Menu manager automatically optimizes the menu by removing extra separators, hiding empty popup menus etc.
◆ MenuMap
typedef QMap<int, QAction*> QtxActionMenuMgr::MenuMap
actions map
◆ NodeList
menu nodes list
◆ QtxActionMenuMgr() [1/2]
QtxActionMenuMgr::QtxActionMenuMgr ( QMainWindow *  p)
pparent main window
References myMenu, and onDestroyed().
◆ QtxActionMenuMgr() [2/2]
QtxActionMenuMgr::QtxActionMenuMgr ( QWidget *  mw,
QObject *  p
mwmenu widget
pparent object
◆ ~QtxActionMenuMgr()
QtxActionMenuMgr::~QtxActionMenuMgr ( )
References myMenus, and myRoot.
◆ actionChanged()
void QtxActionMenuMgr::actionChanged ( int  id)
Schedule delayed update for parent menu of changed action.
Reimplemented from QtxActionMgr.
References find(), QtxActionMenuMgr::MenuNode::id, myRoot, QtxActionMenuMgr::MenuNode::parent, QtxActionMgr::triggerUpdate(), and QtxActionMenuMgr::MenuNode::visible.
◆ append() [1/3]
int QtxActionMenuMgr::append ( const int  id,
const int  pId,
const int  group
idaction ID
pIdparent menu action ID
groupgroup ID
action ID
References insert().
◆ append() [2/3]
int QtxActionMenuMgr::append ( const QString &  title,
const int  pId,
const int  group,
const int  id = -1
titlemenu text
groupgroup ID
idaction ID
action ID
◆ append() [3/3]
int QtxActionMenuMgr::append ( QAction *  a,
const int  pId,
const int  group
aaction
groupgroup ID
action ID
◆ change()
void QtxActionMenuMgr::change ( const int  id,
idmenu action ID
titlenew menu title
References menuAction().
◆ checkWidget()
bool QtxActionMenuMgr::checkWidget ( QWidget *  wid) const
widwidget to be checked
true if widget contains action(s)
◆ clearTitle()
QString QtxActionMenuMgr::clearTitle ( const QString &  txt) const
txtstring to be processed
clear title
◆ containsMenu() [1/2]
bool QtxActionMenuMgr::containsMenu ( const int  id,
const int  pid,
const bool  rec = false
idmenu item ID
pidparent menu item ID
true if parent menu item contains such child item
References find().
◆ containsMenu() [2/2]
bool QtxActionMenuMgr::containsMenu ( const QString &  title,
const int  pid,
titlemenu title
References find().
◆ createMenu()
int QtxActionMenuMgr::createMenu ( const QStringList &  lst,
const int  pId
lstlist of menu names
pIdparent menu item ID
created menu item ID (last in the chain)
References createMenu(), and insert().
◆ find() [1/6]
QtxActionMenuMgr::MenuNode * QtxActionMenuMgr::find ( const int  id,
const int  pId,
const bool  rec = true
Search menu node.
idmenu action ID
recif true perform recursive search
menu node or 0 if it is not found
References find().
◆ find() [2/6]
MenuNode *  startNode = 0,
Search menu node.
idmenu action ID
startNodestart menu node (if 0, search from root node)
References QtxActionMenuMgr::MenuNode::children, find(), and myRoot.
◆ find() [3/6]
bool QtxActionMenuMgr::find ( const int  id,
NodeList &  lst,
idmenu action ID
NodeListresulting list of menu nodes
true if at least one node is found
References QtxActionMenuMgr::MenuNode::children, find(), QtxActionMenuMgr::MenuNode::id, and myRoot.
◆ find() [4/6]
QtxActionMenuMgr::MenuNode * QtxActionMenuMgr::find ( const QString &  title,
const int  pId,
Search menu node.
titlemenu item title
References find().
◆ find() [5/6]
Search menu node.
References QtxActionMenuMgr::MenuNode::children, clearTitle(), find(), itemAction(), menuAction(), and myRoot.
◆ find() [6/6]
bool QtxActionMenuMgr::find ( const QString &  title,
NodeList &  lst,
◆ findId()
int QtxActionMenuMgr::findId ( const int  id,
const int  pid = -1
idmenu action ID
pidparent meun item ID
id (>0) on success or -1 if menu item is not found
◆ findMenu() [1/2]
QMenu * QtxActionMenuMgr::findMenu ( const int  id) const
idmenu item ID
menu pointer or 0 if menu is not found
◆ findMenu() [2/2]
QMenu * QtxActionMenuMgr::findMenu ( const QString &  title,
const int  pid,
titlemenu text
pidparent menu item ID (to start search)
recif true, perform recursive update
References find(), QtxActionMenuMgr::MenuNode::id, and menuAction().
◆ hide()
void QtxActionMenuMgr::hide ( const int  id)
idmenu action ID
See also
show()
References setShown().
◆ insert() [1/9]
int QtxActionMenuMgr::insert ( const int  id,
const int  pId,
const int  group,
const int  idx = -1
idaction ID
groupgroup ID
idxmenu index inside the menu group
action ID
References find(), QtxActionMenuMgr::MenuNode::id, myRoot, and QtxActionMgr::triggerUpdate().
◆ insert() [2/9]
const QString &  menus,
const int  group,
const int  idx = -1
Insert an action to the named menu. The menus parameter represents the menu name: it can be a sequence of strings, separated by '|' symbol. For example, "File|Edit" means File->Edit submenu. If submenu doesn't exist, it will be created.
idaction ID
menusmenu name
groupgroup ID
action ID
◆ insert() [3/9]
const QStringList &  menus,
const int  group,
const int  idx = -1
Insert an action to the named menu. The menus parameter represents the menu names list. For example, string list consisting from two items "File" and "Edit" means File->Edit submenu. If submenu doesn't exist, it will be created.
idaction ID
menusmenu names list
groupgroup ID
action ID
◆ insert() [4/9]
int QtxActionMenuMgr::insert ( const QString &  title,
const int  pId,
const int  group,
const int  id = -1,
const int  idx = -1,
QMenu *  _menu = 0
titlemenu text
groupgroup ID
idaction ID
action ID
References QtxActionMenuMgr::MenuNode::children, clearTitle(), find(), QtxActionMgr::generateId(), QtxActionMenuMgr::MenuNode::id, myMenus, myRoot, onAboutToHide(), onAboutToShow(), and QtxActionMgr::triggerUpdate().
◆ insert() [5/9]
const int  group,
const int  id = -1,
const int  idx = -1
titlemenu text
menusmenu name
groupgroup ID
idaction ID
action ID
◆ insert() [6/9]
const int  group,
const int  id = -1,
const int  idx = -1
titlemenu text
groupgroup ID
idaction ID
action ID
◆ insert() [7/9]
int QtxActionMenuMgr::insert ( QAction *  a,
const int  pId,
const int  group,
const int  idx = -1
aaction
groupgroup ID
action ID
References insert(), and QtxActionMgr::registerAction().
◆ insert() [8/9]
const int  group,
const int  idx = -1
aaction
menusmenu name
groupgroup ID
action ID
◆ insert() [9/9]
const int  group,
const int  idx = -1
aaction
groupgroup ID
action ID
◆ internalUpdate()
void QtxActionMenuMgr::internalUpdate ( )
Internal update.
Customizes the menu update processing.
Reimplemented in QtxPopupMgr.
References QtxActionMgr::isUpdatesEnabled(), myUpdateIds, and updateMenu().
◆ isEmptyEnabled()
bool QtxActionMenuMgr::isEmptyEnabled ( const int  id) const
idmenu item ID
true if empty menu is enabled
References QtxActionMenuMgr::MenuNode::emptyEnabled, find(), and menuAction().
◆ isShown()
bool QtxActionMenuMgr::isShown ( const int  id) const
idmenu action ID
true if an item is shown
See also
setShown()
References find(), and QtxActionMenuMgr::MenuNode::visible.
◆ isVisible()
bool QtxActionMenuMgr::isVisible ( const int  actId,
const int  place
actIdaction ID
placesome parent action ID
true if an action is visible to the parent
See also
setVisible()
◆ itemAction()
QAction * QtxActionMenuMgr::itemAction ( const int  id) const
Get action by id.
idaction ID
action or 0 if id is invalid
References QtxActionMgr::action().
◆ load()
bool QtxActionMenuMgr::load ( const QString &  fname,
QtxActionMgr::Reader &  r
fnamefile name
raction reader
true on success and false on error
References QtxActionMgr::Reader::read().
◆ menuAboutToHide
void QtxActionMenuMgr::menuAboutToHide ( QMenu *  m)
signal
mmenu being hidden
◆ menuAboutToShow
void QtxActionMenuMgr::menuAboutToShow ( QMenu *  m)
signal
mmenu being shown
◆ menuAction()
QAction * QtxActionMenuMgr::menuAction ( const int  id) const
idsubmenu ID
submenu action or 0 if action is not found
References myMenus.
◆ menuActionId()
int QtxActionMenuMgr::menuActionId ( QAction *  a) const
idsubmenu ID
submenu action or 0 if it is not found
References myMenus.
◆ menuWidget() [1/2]
QWidget * QtxActionMenuMgr::menuWidget ( ) const
menu widget (QMenuBar)
References myMenu.
◆ menuWidget() [2/2]
QWidget * QtxActionMenuMgr::menuWidget ( MenuNode *  node) const
nodemenu node
popup menu or main menu corresponding to the menu node (or 0 if it is not found)
References QtxActionMenuMgr::MenuNode::id, myMenu, myMenus, and myRoot.
◆ onAboutToHide
void QtxActionMenuMgr::onAboutToHide ( )
privateslot
Emits the signal menuAboutToHide(QMenu*).
References menuAboutToHide().
◆ onAboutToShow
void QtxActionMenuMgr::onAboutToShow ( )
privateslot
Emits the signal menuAboutToShow(QMenu*).
References menuAboutToShow().
◆ onDestroyed
void QtxActionMenuMgr::onDestroyed ( QObject *  obj)
privateslot
Clears internal pointer to menu to disable crashes.
obj(menu) object being destroyed
References myMenu.
◆ ownAction()
bool QtxActionMenuMgr::ownAction ( QAction *  a,
MenuNode *  node
aaction being checked
nodeparent menu node
true if action belongs to the menu node
References QtxActionMenuMgr::MenuNode::children, itemAction(), and menuAction().
◆ prepend() [1/3]
int QtxActionMenuMgr::prepend ( const int  id,
const int  pId,
const int  group
idaction ID
groupgroup ID
action ID
◆ prepend() [2/3]
int QtxActionMenuMgr::prepend ( const QString &  title,
const int  pId,
const int  group,
const int  id = -1
titlemenu text
groupgroup ID
idaction ID
action ID
◆ prepend() [3/3]
int QtxActionMenuMgr::prepend ( QAction *  a,
const int  pId,
const int  group
aaction
groupgroup ID
action ID
◆ remove() [1/2]
void QtxActionMenuMgr::remove ( const int  id)
idmenu action ID
References removeMenu(), and QtxActionMgr::update().
◆ remove() [2/2]
void QtxActionMenuMgr::remove ( const int  id,
const int  pId,
const int  group = -1
idmenu action ID
groupgroup ID
References QtxActionMenuMgr::MenuNode::children, find(), QtxActionMenuMgr::MenuNode::id, itemAction(), menuAction(), menuWidget(), myMenus, myRoot, and QtxActionMgr::triggerUpdate().
◆ removeMenu()
void QtxActionMenuMgr::removeMenu ( const int  id,
idmenu action ID
startNodeparent menu node which search starts from (if 0, search starts from root)
References QtxActionMenuMgr::MenuNode::children, myRoot, and removeMenu().
◆ setEmptyEnabled()
void QtxActionMenuMgr::setEmptyEnabled ( const int  id,
const bool  enable
idmenu item ID
enableif true, empty menu will be enabled, otherwise empty menu will be disabled
References QtxActionMenuMgr::MenuNode::emptyEnabled, find(), menuAction(), and updateMenu().
◆ setMenuWidget()
void QtxActionMenuMgr::setMenuWidget ( QWidget *  mw)
mwnew menu widget
References myMenu, onDestroyed(), and QtxActionMgr::triggerUpdate().
◆ setShown()
void QtxActionMenuMgr::setShown ( const int  id,
const bool  on
idmenu action ID
onnew visibility status
See also
isShown()
◆ setVisible()
void QtxActionMenuMgr::setVisible ( const int  actId,
const int  place,
const bool  v
actIdaction ID
vnew visibility state
See also
isVisible()
◆ show()
void QtxActionMenuMgr::show ( const int  id)
idmenu action ID
See also
hide()
◆ simplifySeparators()
void QtxActionMenuMgr::simplifySeparators ( QWidget *  wid)
widmenu widget to be processed
References Qtx::simplifySeparators().
◆ triggerUpdate()
void QtxActionMenuMgr::triggerUpdate ( const int  id,
idmenu item ID
References myUpdateIds, and QtxActionMgr::triggerUpdate().
◆ updateContent()
void QtxActionMenuMgr::updateContent ( )
Customizes the content update operation.
References find(), myRoot, myUpdateIds, and updateMenu().
◆ updateMenu()
void QtxActionMenuMgr::updateMenu ( MenuNode *  startNode = 0,
const bool  rec = true,
const bool  updParent = true
Update menu.
Does nothing if update is disabled.
startNodestart menu item to be updated
updParentif true update also parent item (without recursion)
See also
isUpdatesEnabled() and setUpdatesEnabled()
References QtxActionMenuMgr::MenuNode::children, QtxActionMenuMgr::MenuNode::emptyEnabled, QtxActionMenuMgr::MenuNode::id, QtxActionMgr::isUpdatesEnabled(), isVisible(), itemAction(), menuAction(), menuWidget(), myRoot, ownAction(), QtxActionMenuMgr::MenuNode::parent, simplifySeparators(), and updateMenu().
◆ myMenu
QWidget* QtxActionMenuMgr::myMenu
menu widget
◆ myMenus
MenuMap QtxActionMenuMgr::myMenus
actions map
◆ myRoot
MenuNode* QtxActionMenuMgr::myRoot
root menu node
◆ myUpdateIds
QMap<int, bool> QtxActionMenuMgr::myUpdateIds
