QtxActionToolMgr Class Reference
Toolbar actions manager. More...
#include <QtxActionToolMgr.h>
Inheritance diagram for QtxActionToolMgr:
struct  ToolBarInfo
class  ToolCreator
 Toolbars creator. More...
class  ToolNode
 Represents a toolbutton inside toolbar structure. More...
 QtxActionToolMgr (QMainWindow *)
virtual ~QtxActionToolMgr ()
QMainWindow * mainWindow () const
 Get parent main window. More...
int createToolBar (const QString &, int=-1, QMainWindow *=0, bool=true)
 Create toolbar and assign id to it. More...
int createToolBar (const QString &, const QString &, int=-1, QMainWindow *=0, bool=true)
int createToolBar (const QString &, bool, Qt::ToolBarAreas=Qt::AllToolBarAreas, int=-1, QMainWindow *=0, bool=true)
int createToolBar (const QString &, const QString &, bool, Qt::ToolBarAreas=Qt::AllToolBarAreas, int=-1, QMainWindow *=0, bool=true)
void removeToolBar (const QString &)
 Remove toolbar. More...
void removeToolBar (const int)
int insert (const int, const int, const int=-1)
 Insert action into toolbar. More...
int insert (QAction *, const int, const int=-1)
int insert (const int, const QString &, const int=-1)
int insert (QAction *, const QString &, const int=-1)
int append (const int, const int)
 Append action to the end of toolbar. More...
int append (QAction *, const int)
int append (const int, const QString &)
int append (QAction *, const QString &)
int prepend (const int, const int)
 Insert action to the beginning of toolbar. More...
int prepend (QAction *, const int)
int prepend (const int, const QString &)
int prepend (QAction *, const QString &)
virtual bool isVisible (const int, const int) const
 Check if an action with given id is visible in the toolbar tid. More...
virtual void setVisible (const int, const int, const bool)
 Show/hide action with given id in the toolbar tid. More...
void show (const int)
 Show action (in all toolbars). More...
void hide (const int)
 Hide action (in all toolbars). More...
bool isShown (const int) const
 Get visibility status for toolbar action with given id. More...
void setShown (const int, const bool)
 Set visibility status for toolbar action with given id. More...
void remove (const int, const int)
 Remove action from toolbar. More...
void remove (const int, const QString &)
void clear (const int)
 Remove all actions from toolbar. More...
void clear (const QString &)
QToolBar * toolBar (const int) const
 Get toolbar by given tid. More...
QToolBar * toolBar (const QString &) const
 Get toolbar by given title. More...
QIntList toolBarsIds () const
bool hasToolBar (const int) const
 Check if toolbar with given id already registered. More...
bool hasToolBar (const QString &) const
bool containsAction (const int, const int=-1) const
 Check if toolbar contains given action. More...
int index (const int, const int) const
 Get index of the action id within the toolbar tid. More...
virtual bool load (const QString &, QtxActionMgr::Reader &)
 Load toolbar contents from the file. More...
int find (QToolBar *) const
 Get toolbar identifier. More...
- Public Member Functions inherited from QtxActionMgr
 QtxActionMgr (QObject *parent)
virtual ~QtxActionMgr ()
virtual int registerAction (QAction *, const int=-1)
 Register an action in the internal map. More...
virtual void unRegisterAction (const int)
 Unregister action from internal map. More...
QAction * action (const int) const
 Get action by specified identifier. More...
int actionId (const QAction *) const
 Get action identifier. More...
bool contains (const int) const
 Check if an action with given id is registered in the action manager. More...
int count () const
 Get total number of registered actions. More...
bool isEmpty () const
 Check if there are no actions registered in the action manager. More...
QIntList idList () const
 Get all registered actions identifiers. More...
bool isUpdatesEnabled () const
 Check if update is enabled. More...
virtual void setUpdatesEnabled (const bool)
 Enable/disable update operation. More...
 Check if an action with actId identifier is visible to the parent action with place identifier. More...
 Set action's visibility flag. More...
void update ()
 Update actions. More...
virtual bool isEnabled (const int) const
 Check is action with given id is enabled. More...
virtual void setEnabled (const int, const bool)
Protected Slots
void onToolBarDestroyed ()
 Called when toolbar is destroyed. More...
int find (const QString &) const
 Search toolbar by given name. More...
QToolBar * find (const QString &, QMainWindow *) const
 Search toolbar with given title owned by main window \mw. More...
virtual void internalUpdate ()
 Update all registered toolbars. More...
void updateToolBar (const int)
 Update toolbar. More...
virtual void updateContent ()
 Called when delayed content update is performed. More...
- Protected Member Functions inherited from QtxActionMgr
 Internal update. More...
int generateId () const
 Generate unique action identifier. More...
void triggerUpdate ()
 Perform delayed update. More...
 Internal content update operation. More...
virtual void actionChanged (int)
 Internal action changing response operation. More...
Private Types
typedef QList< ToolNode > NodeList
 toolbar nodes list More...
typedef QMap< int, ToolBarInfo > ToolBarMap
 toolbars map More...
void simplifySeparators (QToolBar *)
 Remove extra separators from the toolbar. More...
void triggerUpdate (const int)
 Perform delayed toolbar update. More...
ToolBarMap myToolBars
 toobars map More...
QMainWindow * myMainWindow
 parent main window More...
QMap< int, int > myUpdateIds
 list of actions ID being updated More...
- Static Public Member Functions inherited from QtxActionMgr
static QAction * separator (const bool=false)
 Create new separator action. More...
Toolbar manager allows using of set of action for automatic generating of application toolbars and dynamic update of toolbars contents.
Use insert(), append() and remove() methods to create toolbar and add actions to it. Methods show(), hide() allow displaying/erasing of specified toolbar items.
Toolbar manager automatically optimizes toolbars by removing extra separators, etc.
◆ NodeList
toolbar nodes list
◆ ToolBarMap
toolbars map
◆ QtxActionToolMgr()
QtxActionToolMgr::QtxActionToolMgr ( QMainWindow *  p)
pparent main window
◆ ~QtxActionToolMgr()
QtxActionToolMgr::~QtxActionToolMgr ( )
◆ append() [1/4]
int QtxActionToolMgr::append ( const int  id,
const int  tid
idaction ID
tidtoolbar ID
action ID
References insert().
◆ append() [2/4]
const QString &  title
idaction ID
titletoolbar title
action ID
◆ append() [3/4]
int QtxActionToolMgr::append ( QAction *  a,
const int  tid
aaction
tidtoolbar ID
action ID
◆ append() [4/4]
aaction
titletoolbar title
action ID
◆ clear() [1/2]
void QtxActionToolMgr::clear ( const int  tid)
tidtoolbar ID
References myToolBars, and QtxActionMgr::triggerUpdate().
◆ clear() [2/2]
void QtxActionToolMgr::clear ( const QString &  title)
titletoolbar title
References clear(), and find().
◆ containsAction()
bool QtxActionToolMgr::containsAction ( const int  id,
const int  tid = -1
idaction ID
tidtoolbar ID
true if toolbar contains action
References myToolBars.
◆ createToolBar() [1/4]
int QtxActionToolMgr::createToolBar ( const QString &  title,
bool  floatable,
Qt::ToolBarAreas  dockAreas = Qt::AllToolBarAreas,
int  tid = -1,
QMainWindow *  mw = 0,
bool  vis = true
If tid is less than 0, the identifier is generated automatically. If toolbar with given tid is already registered, the toolbar will not be created.
titletoolbar title
floatableif true, new toolbar is made floatable
dockAreasdock areas of the main window where the new toolbar can be situated
tidrequested toolbar ID
mwparent main window; if it is null, the tool manager's main window is used
visshow toolbar visible immediately after creation (true by default)
id of created/found toolbar
References createToolBar().
◆ createToolBar() [2/4]
const QString &  name,
bool  floatable,
int  tid = -1,
bool  vis = true
The parameter name can be specified to give an unique string identifier to the toolbar. This can be useful in the multi-language environment where identifier of the toolbar should not be dependant on the language chosen (e.g. to store positions of toolbars of main menu in the preferences).
titletoolbar title
nametoolbar name (identifier)
References find(), mainWindow(), myToolBars, onToolBarDestroyed(), and QtxActionToolMgr::ToolBarInfo::toolBar.
◆ createToolBar() [3/4]
int  tid = -1,
bool  vis = true
titletoolbar title
◆ createToolBar() [4/4]
int  tid = -1,
bool  vis = true
titletoolbar title
◆ find() [1/3]
int QtxActionToolMgr::find ( const QString &  title) const
titletoolbar title
toolbar ID or -1 if it is not found
◆ find() [2/3]
QToolBar * QtxActionToolMgr::find ( const QString &  title,
QMainWindow *  mw
titletoolbar title
mwmain window
toolbar or 0 if it is not found
◆ find() [3/3]
int QtxActionToolMgr::find ( QToolBar *  tb) const
tbtoolbar
toolbar ID or -1 if toolbar is not registered
◆ hasToolBar() [1/2]
bool QtxActionToolMgr::hasToolBar ( const int  tid) const
tidtoolbar ID
true if toolbar is registered in the toolbar manager
◆ hasToolBar() [2/2]
bool QtxActionToolMgr::hasToolBar ( const QString &  title) const
titletoolbar title
References find().
◆ hide()
void QtxActionToolMgr::hide ( const int  id)
idaction ID
References setShown().
◆ index()
int QtxActionToolMgr::index ( const int  id,
const int  tid
idaction ID
tidtoolbar ID
index of the action in the toolbar or -1 if action is not contained in the toolbar
◆ insert() [1/4]
int QtxActionToolMgr::insert ( const int  id,
const int  tid,
const int  idx = -1
idaction ID
tidtoolbar ID
idxaction index in the toolbar (if < 0, action is appended to the end)
action ID
References QtxActionMgr::contains(), hasToolBar(), index(), myToolBars, and QtxActionMgr::triggerUpdate().
◆ insert() [2/4]
const int  idx = -1
idaction ID
titletoolbar title
action ID
References createToolBar(), and insert().
◆ insert() [3/4]
int QtxActionToolMgr::insert ( QAction *  a,
const int  tid,
const int  idx = -1
aaction
tidtoolbar ID
action ID
References insert(), and QtxActionMgr::registerAction().
◆ insert() [4/4]
const int  idx = -1
aaction
titletoolbar title
action ID
References createToolBar(), insert(), and QtxActionMgr::registerAction().
◆ internalUpdate()
void QtxActionToolMgr::internalUpdate ( )
Reimplemented from QtxActionMgr.
References QtxActionMgr::isUpdatesEnabled(), myToolBars, myUpdateIds, and updateToolBar().
◆ isShown()
bool QtxActionToolMgr::isShown ( const int  id) const
idaction ID
true if action is shown in all toolbars
References QtxActionToolMgr::ToolNode::id, and myToolBars.
◆ isVisible()
bool QtxActionToolMgr::isVisible ( const int  id,
const int  tid
idaction ID
tidtoolbar ID
true if action is shown in the toolbar
References QtxActionToolMgr::ToolNode::id, myToolBars, QtxActionToolMgr::ToolBarInfo::nodes, and QtxActionToolMgr::ToolNode::visible.
◆ load()
bool QtxActionToolMgr::load ( const QString &  fname,
QtxActionMgr::Reader &  r
fnamefile name
ractions reader
true on success and false on error
References QtxActionMgr::Reader::read().
◆ mainWindow()
QMainWindow * QtxActionToolMgr::mainWindow ( ) const
main window pointer
References myMainWindow.
◆ onToolBarDestroyed
void QtxActionToolMgr::onToolBarDestroyed ( )
protectedslot
Clears internal pointer to the toolbar to disable crashes.
References find(), and myToolBars.
◆ prepend() [1/4]
int QtxActionToolMgr::prepend ( const int  id,
const int  tid
idaction ID
tidtoolbar ID
action ID
◆ prepend() [2/4]
idaction ID
titletoolbar title
action ID
◆ prepend() [3/4]
int QtxActionToolMgr::prepend ( QAction *  a,
const int  tid
aaction
tidtoolbar ID
action ID
◆ prepend() [4/4]
aaction ID
titletoolbar title
action ID
◆ remove() [1/2]
void QtxActionToolMgr::remove ( const int  id,
const int  tid
idaction ID
tidtoolbar ID
◆ remove() [2/2]
idaction ID
titletoolbar title
References find(), and remove().
◆ removeToolBar() [1/2]
void QtxActionToolMgr::removeToolBar ( const int  tid)
Remove toolbar.
tidtoolbar ID
◆ removeToolBar() [2/2]
void QtxActionToolMgr::removeToolBar ( const QString &  title)
Remove toolbar.
titletoolbar title
References find(), and removeToolBar().
◆ setShown()
void QtxActionToolMgr::setShown ( const int  id,
const bool  on
idaction ID
onnew visibility status
References myToolBars, and setVisible().
◆ setVisible()
void QtxActionToolMgr::setVisible ( const int  id,
const int  tid,
const bool  on
idaction ID
tidtoolbar ID
References QtxActionToolMgr::ToolNode::id, myToolBars, QtxActionMgr::triggerUpdate(), updateContent(), and QtxActionToolMgr::ToolNode::visible.
◆ show()
void QtxActionToolMgr::show ( const int  id)
idaction ID
◆ simplifySeparators()
void QtxActionToolMgr::simplifySeparators ( QToolBar *  tb)
tbtoolbar
References Qtx::simplifySeparators().
◆ toolBar() [1/2]
QToolBar * QtxActionToolMgr::toolBar ( const int  tid) const
tidtoolbar ID
◆ toolBar() [2/2]
QToolBar * QtxActionToolMgr::toolBar ( const QString &  title) const
titletoolbar title
References find(), and toolBar().
◆ toolBarsIds()
QIntList QtxActionToolMgr::toolBarsIds ( ) const
\bried Get all registered toolbars identifiers
list of toolbars ids
◆ triggerUpdate()
void QtxActionToolMgr::triggerUpdate ( const int  tid)
tidtoolbar ID
References myUpdateIds, and QtxActionMgr::triggerUpdate().
◆ updateContent()
void QtxActionToolMgr::updateContent ( )
Customizes the content update operation.
References QtxActionMgr::isUpdatesEnabled(), myUpdateIds, and updateToolBar().
◆ updateToolBar()
void QtxActionToolMgr::updateToolBar ( const int  tid)
Update toolbar.
tidtoolbar ID
References QtxActionMgr::action(), QtxActionMgr::isUpdatesEnabled(), isVisible(), myToolBars, and simplifySeparators().
◆ myMainWindow
QMainWindow* QtxActionToolMgr::myMainWindow
parent main window
◆ myToolBars
ToolBarMap QtxActionToolMgr::myToolBars
toobars map
◆ myUpdateIds
QMap<int,int> QtxActionToolMgr::myUpdateIds
