QtxEvalSetString Class Reference
Provides set of string operations for the parser. More...
#include <QtxEvalExpr.h>
Inheritance diagram for QtxEvalSetString:
 QtxEvalSetString ()
virtual ~QtxEvalSetString ()
virtual bool createValue (const QString &, QVariant &) const
 Create value from its string representation. More...
virtual int priority (const QString &, bool isBin) const
 Get the operation priority. More...
virtual QtxEvalExpr::Error calculate (const QString &, QVariant &, QVariant &) const
 Calculate the operation. More...
virtual QString name () const
 Get operations set name. More...
- Public Member Functions inherited from QtxEvalSetBase
 QtxEvalSetBase ()
virtual ~QtxEvalSetBase ()
virtual void operationList (QStringList &) const
 Get the list of possible operations. More...
virtual void bracketsList (QStringList &, bool open) const
 Get list of brackets. More...
virtual QtxEvalExpr::Error isValid (const QString &, const QVariant::Type, const QVariant::Type) const
 Check operation validity. More...
 QtxEvalSet ()
virtual ~QtxEvalSet ()
virtual QString name () const =0
 Get unique operations set name. More...
virtual void operationList (QStringList &) const =0
virtual void bracketsList (QStringList &, bool open) const =0
virtual int priority (const QString &, bool isBin) const =0
virtual QtxEvalExpr::Error isValid (const QString &, const QVariant::Type, const QVariant::Type) const =0
virtual QtxEvalExpr::Error calculate (const QString &, QVariant &, QVariant &) const =0
static QString Name ()
- Protected Types inherited from QtxEvalSetBase
typedef QList< QVariant::Type > ListOfTypes
- Protected Member Functions inherited from QtxEvalSetBase
void addTypes (const ListOfTypes &)
 Add operand types. More...
void addOperations (const QStringList &)
 Add operation names to the internal list of operations. More...
◆ QtxEvalSetString()
QtxEvalSetString::QtxEvalSetString ( )
◆ ~QtxEvalSetString()
QtxEvalSetString::~QtxEvalSetString ( )
◆ calculate()
QtxEvalExpr::Error QtxEvalSetString::calculate ( const QString &  op,
QVariant &  v1,
QVariant &  v2
Process binary operation with values v1 and v2. For unary operation the \v2 is invalid. The result of the operation is returned in the parameter v1.
opoperation name
v1first argument (not valid for unary prefix operations)
v2second argument (not valid for unary postfix operations)
error code (QtxEvalExpr::Error)
Implements QtxEvalSet.
References QtxEvalExpr::OK.
◆ createValue()
bool QtxEvalSetString::createValue ( const QString &  str,
QVariant &  val
Creates string value from Qt string representation.
strstring representration of the value
valreturning value
true if str can be evaluated as custom value and false otherwise (parameter)
Reimplemented from QtxEvalSet.
References QtxEvalSet::createValue().
◆ Name()
QString QtxEvalSetString::Name ( )
operations set name
QString QtxEvalSetString::name ( ) const
operations set name
References Name().
◆ priority()
int QtxEvalSetString::priority ( const QString &  op,
bool  isBin
Operation priority counts from 1. If the operation is impossible, this function returns value <= 0.
opoperation
isBintrue if the operation is binary and false if it is unary
operation priority
