QtxIntValidator Class Reference
Validator for integer numbers with possibility to fix up the invalid value. More...
#include <QtxValidator.h>
Inheritance diagram for QtxIntValidator:
 QtxIntValidator (QObject *)
 QtxIntValidator (const int, const int, QObject *)
virtual ~QtxIntValidator ()
virtual void fixup (QString &) const
 Validate the input and fixup it if necessary. More...
◆ QtxIntValidator() [1/2]
QtxIntValidator::QtxIntValidator ( QObject *  parent)
parentparent object
◆ QtxIntValidator() [2/2]
QtxIntValidator::QtxIntValidator ( const int  bot,
const int  top,
QObject *  parent
botminimum possible value
topmaximum possible value
parentparent object
◆ ~QtxIntValidator()
QtxIntValidator::~QtxIntValidator ( )
◆ fixup()
void QtxIntValidator::fixup ( QString &  str) const
If the string represents integer value less then minimum value, it becomes equal to the minimum. if the string represents integer value more then mazimum value, it becomes equal to the maximum. If the string is not evaluated as integer it becomes equal to 0.
strthe string to be validated
