QtxListAction::ListFrame Class Reference
Expanding frame with action list and comment. More...
Inheritance diagram for QtxListAction::ListFrame:
 ListFrame (QtxListAction *, QWidget *parent)
virtual ~ListFrame ()
void clear ()
 Clear list of names. More...
const QStringList names () const
 Get list of names. More...
void addNames (const QStringList &)
 Add names to the list. More...
void setSingleComment (const QString &)
 Set comment which is displayed when single name is selected. More...
void setMultipleComment (const QString &)
 Set comment which is displayed when multiple names are selected. More...
int selected () const
 Get number of selected names. More...
void setSelected (const int)
 Set number of selected names. More...
int linesNumber () const
 Get maximum numer of lines shown without activation of vertical scroll bar. More...
int charsNumber () const
 Get maximum numer of characters in the line. More...
void setLinesNumber (const int)
 Set maximum numer of lines shown without activation of vertical scroll bar. More...
void setCharsNumber (const int)
 Set maximum numer of characters in the line. More...
virtual QSize sizeHint () const
 Get preferable size for the list widget. More...
virtual QSize minimumSizeHint () const
 Get preferable minimum size for the list widget. More...
 Process mouse events on the viewport of the list widget. More...
virtual void setVisible (bool)
 Called when list widget is shown/hidden. More...
virtual void keyPressEvent (QKeyEvent *)
 Process key press event. More...
void accept ()
 Validate the action. More...
void updateComment ()
 Update displayed comment. More...
void setNames (const QStringList &)
 Set names to the list. More...
void removePostedEvens (QObject *, int)
 Filter all events of specified type sent to specified object. More...
QListWidget * myList
QStringList myNames
QtxListAction * myAction
QLabel * myComment
int myLines
int myChars
QString mySingleComment
QString myMultipleComment
◆ ListFrame()
QtxListAction::ListFrame::ListFrame ( QtxListAction *  a,
QWidget *  parent
alist action
parentparent widget
References main(), myComment, myList, and myMultipleComment.
◆ ~ListFrame()
QtxListAction::ListFrame::~ListFrame ( )
◆ accept()
void QtxListAction::ListFrame::accept ( )
◆ addNames()
void QtxListAction::ListFrame::addNames ( const QStringList &  names)
Truncates each name to fit the frame width. Method QtxListAction::setCharsNumber(int) can be used to change the frame width (in characters).
nameslist of names to be added
See also
setNames(), QtxListAction::setCharsNumber(int)
References QtxListAction::names().
◆ charsNumber()
int QtxListAction::ListFrame::charsNumber ( ) const
If the name length is greater than this value, it will be truncated.
number of characters
See also
setCharsNumber(), linesNumber(), setLinesNumber()
◆ clear()
void QtxListAction::ListFrame::clear ( )
◆ eventFilter()
bool QtxListAction::ListFrame::eventFilter ( QObject *  o,
QEvent *  e
oobject recieving event (viewport)
eevent
true if further event processing should be stopped.
References QtxListAction::ScrollEvent::isDown(), and QtxListAction::ScrollEvent::Scroll.
◆ keyPressEvent()
void QtxListAction::ListFrame::keyPressEvent ( QKeyEvent *  e)
The following keys are supported:
  • Up/Down
  • PageUp/PageDown
  • Enter
  • Escape
ekey press event
References QtxListAction::linesNumber().
◆ linesNumber()
int QtxListAction::ListFrame::linesNumber ( ) const
number of lines
See also
setLinesNumber(), charsNumber(), setCharsNumber()
◆ minimumSizeHint()
QSize QtxListAction::ListFrame::minimumSizeHint ( ) const
References QtxListAction::charsNumber(), and QtxListAction::linesNumber().
◆ names()
const QStringList QtxListAction::ListFrame::names ( ) const
Get list of names.
list of names
◆ removePostedEvens()
void QtxListAction::ListFrame::removePostedEvens ( QObject *  o,
int  type
oobject
typeevent type to be filtered
References QtxAction::eventFilter().
◆ selected()
int QtxListAction::ListFrame::selected ( ) const
number of selected items
◆ setCharsNumber()
void QtxListAction::ListFrame::setCharsNumber ( const int  maxChars)
maxCharsnumber of characters
See also
charsNumber(), linesNumber(), setLinesNumber()
◆ setLinesNumber()
void QtxListAction::ListFrame::setLinesNumber ( const int  maxLines)
maxLinesnumber of lines
See also
linesNumber(), charsNumber(), setCharsNumber()
◆ setMultipleComment()
void QtxListAction::ListFrame::setMultipleComment ( const QString &  comment)
commentcomment format
◆ setNames()
void QtxListAction::ListFrame::setNames ( const QStringList &  names)
nameslist of names to be set
See also
addNames(), QtxListAction::setCharsNumber(int)
References QtxListAction::charsNumber(), and QtxListAction::names().
◆ setSelected()
void QtxListAction::ListFrame::setSelected ( const int  lastSel)
lastSelnumber of items to be selected
References QtxListAction::ScrollEvent::Scroll.
◆ setSingleComment()
void QtxListAction::ListFrame::setSingleComment ( const QString &  comment)
◆ setVisible()
void QtxListAction::ListFrame::setVisible ( bool  on)
onif true, widget is shown, otherswise it is hidden
◆ sizeHint()
QSize QtxListAction::ListFrame::sizeHint ( ) const
preferable size
◆ updateComment()
void QtxListAction::ListFrame::updateComment ( )
◆ myAction
QtxListAction* QtxListAction::ListFrame::myAction
◆ myChars
int QtxListAction::ListFrame::myChars
◆ myComment
QLabel* QtxListAction::ListFrame::myComment
◆ myLines
int QtxListAction::ListFrame::myLines
◆ myList
QListWidget* QtxListAction::ListFrame::myList
◆ myMultipleComment
QString QtxListAction::ListFrame::myMultipleComment
◆ myNames
QStringList QtxListAction::ListFrame::myNames
◆ mySingleComment
QString QtxListAction::ListFrame::mySingleComment
