QtxPathListEdit Class Reference
The QtxPathListEdit class represents a widget for files or directories paths list preference items editing. More...
#include <QtxPathListEdit.h>
Inheritance diagram for QtxPathListEdit:
class  Delegate
 Custom item delegate for the paths list widget. More...
class  Editor
 Path editor widget. More...
 QtxPathListEdit (const Qtx::PathType, QWidget *=0)
 QtxPathListEdit (QWidget *=0)
virtual ~QtxPathListEdit ()
Qtx::PathType pathType () const
 Get widget mode. More...
void setPathType (const Qtx::PathType)
 Set widget mode. More...
QStringList pathList () const
 Get currently selected paths list. More...
void setPathList (const QStringList &)
 Set paths list. More...
bool isDuplicateEnabled () const
 Check if the duplication of paths is enabled. More...
void setDuplicateEnabled (const bool)
 Enable/disable paths duplication. More...
int count () const
 Get number of currently entered paths. More...
bool contains (const QString &) const
 Check if the specified path already exists in the paths list. More...
void clear ()
 Clear paths list. More...
void remove (const int)
 Remove path from the paths list. More...
void remove (const QString &)
void insert (const QString &, const int=-1)
 Add path to the list of paths. More...
bool eventFilter (QObject *, QEvent *)
 Customize child widget events processing. More...
Protected Slots
void onUp (bool=false)
 Called when <Up> button is clicked. More...
void onDown (bool=false)
 Called when <Down> button is clicked. More...
void onInsert (bool=false)
 Called when <Insert> button is clicked. More...
void onDelete (bool=false)
 Called when <Delete> button is clicked. More...
void initialize ()
 Perform internal widget initialization. More...
QWidget * createEditor (QWidget *)
 Create editor widget. More...
void setModelData (QWidget *, const QModelIndex &)
 Set modified data from the editor to the list widget. More...
void setEditorData (QWidget *, const QModelIndex &)
 Set data to the editor from the list widget when user starts path edition. More...
bool checkExistance (const QString &, const bool=true)
 Check if path is correct (exists) and optionally show the question message box. More...
bool checkDuplicate (const QString &, const int, const bool=true)
 Check if path already exists in the list and optionally show the warning message box. More...
QListView * myList
Qtx::PathType myType
QStringListModel * myModel
QCompleter * myCompleter
bool myDuplicate
Friends
class QtxPathListEdit::Delegate
The path list preference item is represented as the list box widget. It provides such operations like adding new file/directory path to the list, removing selected paths and modifying of already entered ones.
The widget can be used in two modes: list of files or list of directories. The mode defines the type of the standard browse dialog box which is invoked on the browse button clicking.
Initial path list value can be set with setPathList() method. Chosen path list can be retrieved with the pathList() method. The widget mode can be set with setPathType() and retrieved with pathType() method.
In addition, it is possible to add path items to the list with the insert() method, remove items with the remove() methods, clear all the widget contents with the clear() method. To get the number of entered paths can be retrieved with the count() method. To check if any path already exists in the paths list, use contains() method.
◆ QtxPathListEdit() [1/2]
QtxPathListEdit::QtxPathListEdit ( const Qtx::PathType  type,
QWidget *  parent = 0
typewidget mode (Qtx::PathType)
parentparent widget
See also
pathType(), setPathType()
References initialize().
◆ QtxPathListEdit() [2/2]
QtxPathListEdit::QtxPathListEdit ( QWidget *  parent = 0)
Qtx::PT_OpenFile mode is used by default.
parentparent widget
See also
◆ ~QtxPathListEdit()
QtxPathListEdit::~QtxPathListEdit ( )
◆ checkDuplicate()
bool QtxPathListEdit::checkDuplicate ( const QString &  str,
const int  row,
const bool  msg = true
strpath to be checked
rowrow corresponding to the path checked
msgif true and path does not exist, warning message box is shown
true if the user confirms the path adding
References myModel.
◆ checkExistance()
bool QtxPathListEdit::checkExistance ( const QString &  str,
msgif true and path does not exist, question message box is shown
References Qtx::makeEnvVarSubst(), pathType(), Qtx::PT_Directory, Qtx::PT_OpenFile, and Qtx::PT_SaveFile.
◆ clear()
void QtxPathListEdit::clear ( )
Clear paths list.
References myModel.
◆ contains()
bool QtxPathListEdit::contains ( const QString &  path) const
pathpath to be checked
true if the path is already selected by the user or false otherwise
References myModel.
◆ count()
int QtxPathListEdit::count ( ) const
current paths number
References myModel.
◆ createEditor()
QWidget * QtxPathListEdit::createEditor ( QWidget *  parent)
parentparent widget for the editor
created editor widget
References pathType(), and QtxPathEdit::setPathType().
◆ eventFilter()
bool QtxPathListEdit::eventFilter ( QObject *  o,
QEvent *  e
oevent receiver object
eevent
true if the further event processing should be stopped.
References onDelete(), onDown(), onInsert(), and onUp().
◆ initialize()
void QtxPathListEdit::initialize ( )
References delete_icon, insert_icon, movedown_icon, moveup_icon, myList, myModel, onDelete(), onDown(), onInsert(), and onUp().
◆ insert()
void QtxPathListEdit::insert ( const QString &  path,
const int  idx = -1
If the specified index is out of range, the path is added to the end of the list.
pathpath to be added
idxindex in the list to which the path should be inserted.
References myModel.
◆ isDuplicateEnabled()
bool QtxPathListEdit::isDuplicateEnabled ( ) const
true if the duplication is enabled
References myDuplicate.
◆ onDelete
void QtxPathListEdit::onDelete ( bool  = false)
protectedslot
Removes currently selected path item.
on(not used)
References myList, and myModel.
◆ onDown
void QtxPathListEdit::onDown ( bool  = false)
protectedslot
Move currently selected path item down to one row in the paths list.
on(not used)
◆ onInsert
void QtxPathListEdit::onInsert ( bool  = false)
protectedslot
Inserts new empty line to the list and sets input focus to it.
on(not used)
◆ onUp
void QtxPathListEdit::onUp ( bool  = false)
protectedslot
Move currently selected path item up to one row in the paths list.
on(not used)
◆ pathList()
QStringList QtxPathListEdit::pathList ( ) const
files or directories paths list entered by the user
See also
setPathList()
References myModel.
◆ pathType()
Qtx::PathType QtxPathListEdit::pathType ( ) const
Get widget mode.
currently used widget mode (Qtx::PathType)
See also
setPathType()
References myType.
◆ remove() [1/2]
void QtxPathListEdit::remove ( const int  idx)
idxpath index in the list
References myModel.
◆ remove() [2/2]
void QtxPathListEdit::remove ( const QString &  path)
pathpath to be removed
References myModel.
◆ setDuplicateEnabled()
void QtxPathListEdit::setDuplicateEnabled ( const bool  on)
onnew flag value
◆ setEditorData()
void QtxPathListEdit::setEditorData ( QWidget *  editor,
const QModelIndex &  index
editoreditor widget
indexdata model index
References myModel, and QtxPathEdit::setPath().
◆ setModelData()
void QtxPathListEdit::setModelData ( QWidget *  editor,
editoreditor widget
References checkDuplicate(), checkExistance(), isDuplicateEnabled(), myModel, and QtxPathEdit::path().
◆ setPathList()
void QtxPathListEdit::setPathList ( const QStringList &  lst)
Set paths list.
lstfiles or directories paths list
See also
pathList()
References myModel.
◆ setPathType()
void QtxPathListEdit::setPathType ( const Qtx::PathType  t)
Set widget mode.
tnew widget mode (Qtx::PathType)
See also
pathType()
References myCompleter, and myType.
◆ QtxPathListEdit::Delegate
friend class QtxPathListEdit::Delegate
friend
◆ myCompleter
QCompleter* QtxPathListEdit::myCompleter
◆ myDuplicate
bool QtxPathListEdit::myDuplicate
◆ myList
QListView* QtxPathListEdit::myList
◆ myModel
QStringListModel* QtxPathListEdit::myModel
◆ myType
Qtx::PathType QtxPathListEdit::myType
