QtxTreeViewSearcher Class Reference
A QTreeView class based searcher. More...
#include <QtxSearchTool.h>
Inheritance diagram for QtxTreeViewSearcher:
 QtxTreeViewSearcher (QTreeView *, int=0)
virtual ~QtxTreeViewSearcher ()
int searchColumn () const
 Get column for which search is performed. More...
void setSearchColumn (int)
 Set column for which search should be performed. More...
virtual bool find (const QString &, QtxSearchTool *)
 Start new search. More...
virtual bool findNext (const QString &, QtxSearchTool *)
 Search next appropriate item. More...
virtual bool findPrevious (const QString &, QtxSearchTool *)
 Search previous appropriate item. More...
virtual bool findFirst (const QString &, QtxSearchTool *)
 Search first appropriate item. More...
virtual bool findLast (const QString &, QtxSearchTool *)
 Search last appropriate item. More...
- Public Member Functions inherited from QtxSearchTool::Searcher
 Searcher ()
virtual ~Searcher ()
virtual bool find (const QString &, QtxSearchTool *)=0
virtual bool findNext (const QString &, QtxSearchTool *)=0
virtual bool findPrevious (const QString &, QtxSearchTool *)=0
virtual bool findFirst (const QString &, QtxSearchTool *)=0
virtual bool findLast (const QString &, QtxSearchTool *)=0
virtual Qt::MatchFlags matchFlags (QtxSearchTool *) const
 Get match flags to be used by the searcher. More...
QModelIndexList findItems (const QString &, QtxSearchTool *)
 Find all appropriate items. More...
QModelIndex findNearest (const QModelIndex &, const QModelIndexList &, bool)
 Find model index from the list nearest to the specified index. More...
void showItem (const QModelIndex &)
 Ensure the found item to become visible and selected. More...
QString getId (const QModelIndex &)
 Get unique item ID. More...
int compareIndices (const QModelIndex &, const QModelIndex &)
 Compare items. More...
QTreeView * myView
int myColumn
QPersistentModelIndex myIndex
The class QtxTreeViewSearcher can be used to find the items in the QTreeView widget.
The column for which data should be searched can be get/set with the searchColumn(), setSearchColumn() methods. By default, column 0 is used.
◆ QtxTreeViewSearcher()
QtxTreeViewSearcher::QtxTreeViewSearcher ( QTreeView *  view,
int  col = 0
viewtree view widget
colcolumn for which search to be performed (0 by default)
See also
setSearchColumn()
◆ ~QtxTreeViewSearcher()
QtxTreeViewSearcher::~QtxTreeViewSearcher ( )
◆ compareIndices()
int QtxTreeViewSearcher::compareIndices ( const QModelIndex &  left,
const QModelIndex &  right
Compare items.
leftfirst model index to be compared
rightlast model index to be compared
0 if items are equal, negative value if left item is less than right one and positive value otherwise
References getId().
◆ find()
bool QtxTreeViewSearcher::find ( const QString &  text,
QtxSearchTool *  st
Start new search.
texttext to be found
stsearch tool widget
See also
findNext(), findPrevious(), findFirst(), findLast()
Implements QtxSearchTool::Searcher.
References findItems(), findNearest(), QtxSearchTool::isSearchWrapped(), myView, and showItem().
◆ findFirst()
bool QtxTreeViewSearcher::findFirst ( const QString &  text,
QtxSearchTool *  st
See also
find(), findNext(), findPrevious(), findLast()
References findItems(), and showItem().
◆ findItems()
QModelIndexList QtxTreeViewSearcher::findItems ( const QString &  text,
QtxSearchTool *  st
References matchFlags(), myColumn, and myView.
◆ findLast()
bool QtxTreeViewSearcher::findLast ( const QString &  text,
QtxSearchTool *  st
See also
find(), findNext(), findPrevious(), findFirst()
◆ findNearest()
QModelIndex QtxTreeViewSearcher::findNearest ( const QModelIndex &  index,
const QModelIndexList &  lst,
bool  direction
indexmodel index for which a nearest item is searched
lstlist of model indices
directionif true find next appropriate item, otherwise find privious appropriate item
References compareIndices().
◆ findNext()
bool QtxTreeViewSearcher::findNext ( const QString &  text,
QtxSearchTool *  st
See also
find(), findPrevious(), findFirst(), findLast()
References findItems(), findNearest(), QtxSearchTool::isSearchWrapped(), myIndex, myView, and showItem().
◆ findPrevious()
bool QtxTreeViewSearcher::findPrevious ( const QString &  text,
QtxSearchTool *  st
See also
find(), findNext(), findFirst(), findLast()
◆ getId()
QString QtxTreeViewSearcher::getId ( const QModelIndex &  index)
Get unique item ID.
indexmodel index
item ID
◆ matchFlags()
Qt::MatchFlags QtxTreeViewSearcher::matchFlags ( QtxSearchTool *  st) const
References QtxSearchTool::isCaseSensitive(), and QtxSearchTool::isRegExpSearch().
◆ searchColumn()
int QtxTreeViewSearcher::searchColumn ( ) const
column number
See also
setSearchColumn()
References myColumn.
◆ setSearchColumn()
void QtxTreeViewSearcher::setSearchColumn ( int  column)
columncolumn number
See also
searchColumn()
◆ showItem()
void QtxTreeViewSearcher::showItem ( const QModelIndex &  index)
indexitem to be shown
References myIndex, and myView.
◆ myColumn
int QtxTreeViewSearcher::myColumn
◆ myIndex
QPersistentModelIndex QtxTreeViewSearcher::myIndex
◆ myView
QTreeView* QtxTreeViewSearcher::myView
