QtxWorkstackAction Class Reference
Implements actions group for menu Windows with standard operations, like "Split vertical", "Split horizontal", etc. More...
#include <QtxWorkstackAction.h>
Inheritance diagram for QtxWorkstackAction:
enum  {
  SplitVertical = 0x0001 , SplitHorizontal = 0x0002 , Windows = 0x0010 , Split = SplitVertical | SplitHorizontal ,
  Standard = Split | Windows
 Actions (menu items) ID. More...
 QtxWorkstackAction (QtxWorkstack *, QObject *=0)
virtual ~QtxWorkstackAction ()
QtxWorkstack * workstack () const
 Get workstack. More...
QAction * getArrangeViewsAction ()
 Get arrange views action. More...
int menuActions () const
 Get menu actions which are currently visible in the menu bar. More...
void setMenuActions (const int)
 Set actions to be visible in the menu. More...
QIcon icon (const int) const
 Get icon for the specified action. More...
QString text (const int) const
 Get menu item text for the specified action. More...
int accel (const int) const
 Get keyboard accelerator for the specified action. More...
QString statusTip (const int) const
 Get status bar tip for the specified action. More...
void setIcon (const int, const QIcon &)
 Set menu item icon for the specified action. More...
void setText (const int, const QString &)
 Set menu item text for the specified action. More...
void setStatusTip (const int, const QString &)
 Set menu item status bar tip for the specified action. More...
void perform (const int)
 Process action activated by the user. More...
- Public Member Functions inherited from QtxActionSet
 QtxActionSet (QObject *=0)
virtual ~QtxActionSet ()
QList< QAction * > actions () const
 Get list of child actions. More...
void setActions (const QList< QAction * > &)
 Assign child actions. More...
void insertActions (const QList< QAction * > &, const int=-1)
 Insert actions at the specified position. More...
int insertAction (QAction *, const int id=-1, const int=-1)
 Insert action at the specified position. More...
int insertAction (const QString &, const int id=-1, const int=-1)
int insertAction (const QString &, const QIcon &, const int id=-1, const int=-1)
void removeAction (QAction *)
 Remove specified action. More...
void removeAction (const int)
void clear ()
 Remove all actions. More...
 QtxAction (QObject *=0, bool=false, const QString &=QString())
 QtxAction (QObject *, bool, const QString &, const QString &, const QString &=QString(), const QIcon &=QIcon())
 QtxAction (const QString &, const QString &, int, QObject *, bool=false, const QString &=QString())
 QtxAction (const QString &, const QString &, const QKeySequence &, QObject *, bool=false, const QString &=QString())
 QtxAction (const QString &, const QIcon &, const QString &, int, QObject *, bool=false, const QString &=QString())
 QtxAction (const QString &, const QIcon &, const QString &, const QKeySequence &, QObject *, bool=false, const QString &=QString())
virtual ~QtxAction ()
 Customize action events. More...
QString shortcutActionName () const
void setShortcutActionName (const QString &)
const QString & ID () const
 Unique for the entire application ID. More...
void setID (const QString &theID)
virtual void addedTo (QWidget *)
 Called when action is added to the menu bar. More...
virtual void removedFrom (QWidget *)
 Called when action is removed from the menu bar. More...
- Protected Member Functions inherited from QtxActionSet
 Called when this action set is added to the menu bar (or toolbar). More...
 Called when this action set is removed from the menu bar (or toolbar). More...
virtual void actionAdded (QAction *)
 Notify that action was added. More...
virtual void actionRemoved (QAction *)
 Notify that action was removed. More...
QAction * action (int) const
 Get action by specified identifier. More...
int actionId (QAction *) const
 Get action identifier for the action. More...
void setActionId (QAction *, const int)
 Set action identifier for the action. More...
virtual bool isEmptyAction () const
 Check if the action itself should be invisible (only child action are shown) More...
virtual void updateAction ()
 Update action set. More...
virtual void updateAction (QWidget *)
 Update action set for the specified widget. More...
 Called when the action is added to the widget. More...
 Called when the action is removed from the widget. More...
virtual void customEvent (QEvent *)
 Process notification events. More...
Private Slots
void onAboutToShow ()
 Called when parent menu is about to show. More...
void onTriggered (int)
 Called when menu item is activated by the user. More...
void updateContent ()
 Update all menu action state. More...
void updateWindows ()
 Update actions which refer to the opened child windows. More...
void splitVertical ()
 Split the window area in the workstack in the vertical direction. More...
void splitHorizontal ()
 Split the window area in the workstack in the horizontal direction. More...
void activateItem (const int)
 Called when menu item corresponding to some child window is activated. More...
QtxWorkstack * myWorkstack
 parent workstack More...
bool myWindowsFlag
 "show child windows items" flag More...
QAction * myArrangeViewsAction
- Signals inherited from QtxActionSet
void triggered (int)
 Emitted when some child action is activated by the user. More...
void triggered (QAction *)
◆ anonymous enum
anonymous enum
SplitVertical
"Split window vertically" operation
SplitHorizontal
"Split window horizontally" operation
Windows
A list of child windows menu items.
Split
Standard
◆ QtxWorkstackAction()
QtxWorkstackAction::QtxWorkstackAction ( QtxWorkstack *  ws,
QObject *  parent = 0
◆ ~QtxWorkstackAction()
QtxWorkstackAction::~QtxWorkstackAction ( )
◆ accel()
int QtxWorkstackAction::accel ( const int  id) const
idmenu action ID
keyboard accelerator of menu item or 0 if there is no such action
References QtxActionSet::action().
◆ activateItem()
void QtxWorkstackAction::activateItem ( const int  idx)
Activates correposponding child window.
idxmenu item index
References QtxWorkstack::windowList(), and workstack().
◆ addedTo()
void QtxWorkstackAction::addedTo ( QWidget *  w)
wmenu bar widget this action is being added to
Reimplemented from QtxActionSet.
References QtxActionSet::addedTo(), and onAboutToShow().
◆ getArrangeViewsAction()
QAction * QtxWorkstackAction::getArrangeViewsAction ( )
References myArrangeViewsAction.
◆ icon()
QIcon QtxWorkstackAction::icon ( const int  id) const
If id is invalid, null icon is returned.
idmenu action ID
menu item icon
◆ menuActions()
int QtxWorkstackAction::menuActions ( ) const
ORed together actions flags
See also
setMenuActions()
References QtxActionSet::action(), myWindowsFlag, SplitHorizontal, SplitVertical, and Windows.
◆ onAboutToShow
void QtxWorkstackAction::onAboutToShow ( )
privateslot
Updates all menu items.
References updateContent().
◆ onTriggered
void QtxWorkstackAction::onTriggered ( int  id)
privateslot
Perform the corresponding action.
idmenu item identifier
References activateItem(), perform(), and Windows.
◆ perform()
void QtxWorkstackAction::perform ( const int  )
typeaction ID
◆ removedFrom()
void QtxWorkstackAction::removedFrom ( QWidget *  w)
wmenu bar widget this action is being removed from
References onAboutToShow(), and QtxActionSet::removedFrom().
◆ setIcon()
void QtxWorkstackAction::setIcon ( const int  id,
const QIcon &  icon
idmenu action ID
iconew menu item icon
References QtxActionSet::action(), and icon().
◆ setMenuActions()
void QtxWorkstackAction::setMenuActions ( const int  flags)
Actions, which IDs are set in flags parameter, will be shown in the menu bar. Other actions will not be shown.
flagsORed together actions flags
◆ setStatusTip()
void QtxWorkstackAction::setStatusTip ( const int  id,
const QString &  txt
idmenu action ID
txtnew menu item status bar tip
◆ setText()
void QtxWorkstackAction::setText ( const int  id,
const QString &  txt
idmenu action ID
txtnew menu item text
◆ splitHorizontal()
void QtxWorkstackAction::splitHorizontal ( )
References QtxWorkstack::splitHorizontal(), and workstack().
◆ splitVertical()
void QtxWorkstackAction::splitVertical ( )
References QtxWorkstack::splitVertical(), and workstack().
◆ statusTip()
QString QtxWorkstackAction::statusTip ( const int  id) const
idmenu action ID
status bar tip menu item or null QString if there is no such action
◆ text()
QString QtxWorkstackAction::text ( const int  id) const
idmenu action ID
menu item text or null QString if there is no such action
◆ updateContent()
void QtxWorkstackAction::updateContent ( )
◆ updateWindows()
◆ workstack()
QtxWorkstack * QtxWorkstackAction::workstack ( ) const
Get workstack.
parent workstack
References myWorkstack.
◆ myArrangeViewsAction
QAction* QtxWorkstackAction::myArrangeViewsAction
◆ myWindowsFlag
bool QtxWorkstackAction::myWindowsFlag
◆ myWorkstack
QtxWorkstack* QtxWorkstackAction::myWorkstack
parent workstack
