QtxWorkstackTabBar Class Reference
Workstack tab bar widget. More...
#include <QtxWorkstack.h>
Inheritance diagram for QtxWorkstackTabBar:
Signals
void dragActiveTab ()
 Emitted when dragging operation is started. More...
void contextMenuRequested (QPoint)
 Emitted when context popup menu is requested. More...
 QtxWorkstackTabBar (QWidget *=0)
virtual ~QtxWorkstackTabBar ()
bool isActive () const
 Check if the tab bar is active. More...
void setActive (const bool)
 Set tab bar active/inactive. More...
int tabId (const int) const
 Get tab page identifier. More...
int indexOf (const int) const
 Get tab page index by specified identifier. More...
void setTabId (const int, const int)
 Set tab page identifier. More...
void updateActiveState ()
 Update tab bar according to the 'active' state. More...
virtual void changeEvent (QEvent *)
 Process widget change state events (style, palette, enable state changing, etc). More...
virtual void mouseMoveEvent (QMouseEvent *)
 Customize mouse move event handler. More...
virtual void mousePressEvent (QMouseEvent *)
 Customize mouse press event handler. More...
virtual void mouseReleaseEvent (QMouseEvent *)
 Customize mouse release event handler. More...
virtual void contextMenuEvent (QContextMenuEvent *)
 Customize context menu event handler. More...
Private Slots
void onCurrentChanged (int)
 Called when current tab page is changed. More...
int myId
 current tab page index More...
bool myActive
 "active" status More...
◆ QtxWorkstackTabBar()
QtxWorkstackTabBar::QtxWorkstackTabBar ( QWidget *  parent = 0)
parentparent widget
References onCurrentChanged().
◆ ~QtxWorkstackTabBar()
QtxWorkstackTabBar::~QtxWorkstackTabBar ( )
◆ changeEvent()
void QtxWorkstackTabBar::changeEvent ( QEvent *  )
echange event (not used)
References updateActiveState().
◆ contextMenuEvent()
void QtxWorkstackTabBar::contextMenuEvent ( QContextMenuEvent *  e)
econtext menu event
References contextMenuRequested().
◆ contextMenuRequested
void QtxWorkstackTabBar::contextMenuRequested ( QPoint  p)
signal
ppoint popup menu to be shown at
◆ dragActiveTab
void QtxWorkstackTabBar::dragActiveTab ( )
signal
◆ indexOf()
int QtxWorkstackTabBar::indexOf ( const int  id) const
idtab page ID
tab page index or -1 if not found
References tabId().
◆ isActive()
bool QtxWorkstackTabBar::isActive ( ) const
true if tab bar is active
References myActive.
◆ mouseMoveEvent()
void QtxWorkstackTabBar::mouseMoveEvent ( QMouseEvent *  e)
emouse event
References dragActiveTab(), indexOf(), and myId.
◆ mousePressEvent()
void QtxWorkstackTabBar::mousePressEvent ( QMouseEvent *  e)
emouse event
References myId, and tabId().
◆ mouseReleaseEvent()
void QtxWorkstackTabBar::mouseReleaseEvent ( QMouseEvent *  e)
emouse event
References contextMenuRequested(), and myId.
◆ onCurrentChanged
void QtxWorkstackTabBar::onCurrentChanged ( int  )
privateslot
idxtab page index (not used)
◆ setActive()
void QtxWorkstackTabBar::setActive ( const bool  on)
onnew active state
References myActive, and updateActiveState().
◆ setTabId()
void QtxWorkstackTabBar::setTabId ( const int  index,
const int  id
indextab page index
idtab page ID
◆ tabId()
int QtxWorkstackTabBar::tabId ( const int  index) const
indextab page index
tab page ID or -1 if index is out of range
◆ updateActiveState()
void QtxWorkstackTabBar::updateActiveState ( )
References isActive().
◆ myActive
bool QtxWorkstackTabBar::myActive
"active" status
◆ myId
int QtxWorkstackTabBar::myId
