Qtx::BackgroundData Class Reference
Stores background data. More...
#include <Qtx.h>
 BackgroundData ()
 Default constructor. Creates invalid background data. More...
 BackgroundData (const QColor &)
 Constructor. Creates background data initialized with the specified color. More...
 BackgroundData (int, const QColor &, const QColor &)
 Constructor. Creates background data initialized with the specified two-color gradient. More...
 BackgroundData (const QGradient &)
 Constructor. Creates background data initialized with the arbirtary gradient data. More...
virtual ~BackgroundData ()
bool operator== (const BackgroundData &) const
 Compares two background data objects. More...
bool operator!= (const BackgroundData &other) const
bool isValid () const
 Returns false if background data is not set (invalid) More...
BackgroundMode mode () const
 Get background mode. More...
void setMode (const BackgroundMode)
 Set background mode. More...
TextureMode texture (QString &) const
 Get file name used as a texture image. More...
void setTexture (const QString &, TextureMode=Qtx::CenterTexture)
 Set file name to be used as a texture image. More...
bool isTextureShown () const
 Check if "show texture" flag is switched on. More...
void setTextureShown (bool)
 Specify if texture should be shown on the background or no. More...
QColor color () const
 Get background color. Returns null QColor if color is not set. More...
void setColor (const QColor &)
 Set background color and switch to the Qtx::ColorBackground mode. More...
int gradient (QColor &, QColor &) const
 Get simple gradient data. Returns -1 and null QColor for c1 and c2 if gradient data is not set. More...
void setGradient (int, const QColor &, const QColor &)
 Set simple background gradient data and switch to the Qtx::SimpleGradientBackground mode. More...
const QGradient * gradient () const
 Get complex gradient data. Returns QGradient of QGradient::NoGradient if gradient data is not set. More...
void setGradient (const QGradient &)
 Set complex background gradient data and switch to the Qtx::CustomGradientBackground mode. More...
BackgroundMode myMode
TextureMode myTextureMode
QString myFileName
QColorList myColors
int myGradientType
QGradient myGradient
bool myTextureShown
This class is used to store background data. Depending on the mode, the background can be specified by:
The class stores all the data passed to it, so switching between different modes can be done just by calling setMode() function.
Texture is used with combination of the background mode.
Two-color gradient is specified by two colors and integer identifier. The interpretation of this identifier should be done in the calling code.
bg.setColor( QColor(100, 100, 100) ); // bg is switched to Qtx::ColorBackground mode
bg.setGradient( Qt::Horizontal, Qt::gray, Qt::white ); // bg is switched to Qtx::ColorBackground mode
QLinearGradient grad( 0,0,1,1 );
grad.setColorAt( 0.0, Qt::gray );
grad.setColorAt( 0.5, Qt::white );
grad.setColorAt( 1.0, Qt::green );
grad.setSpread( QGradient::PadSpread );
bg.setGradient( grad ); // bg is switched to Qtx::CustomGradientBackground mode
bg.setMode( Qtx::ColorBackground ); // bg is switched back to Qtx::ColorBackground mode
bg.setTexture( "/data/images/background.png" ); // specify texture (in the centered mode by default)
bg.setTextureShown( true ); // draw texture on the solid color background
@ Horizontal
Horizontal orientation.
Definition: SalomePyQt.h:148
Definition: Qtx.h:178
void setTexture(const QString &, TextureMode=Qtx::CenterTexture)
Definition: Qtx.cxx:1987
void setGradient(int, const QColor &, const QColor &)
Definition: Qtx.cxx:2059
void setColor(const QColor &)
Definition: Qtx.cxx:2028
void setMode(const BackgroundMode)
Definition: Qtx.cxx:1961
void setTextureShown(bool)
Definition: Qtx.cxx:2008
@ ColorBackground
Definition: Qtx.h:138
◆ BackgroundData() [1/4]
Qtx::BackgroundData::BackgroundData ( )
References Qtx::NoBackground, and setMode().
◆ BackgroundData() [2/4]
Qtx::BackgroundData::BackgroundData ( const QColor &  c)
ccolor
References setColor().
◆ BackgroundData() [3/4]
Qtx::BackgroundData::BackgroundData ( int  type,
const QColor &  c1,
const QColor &  c2
typegradient type identifier
c1first gradient color
c2second gradient color
the interpretation of the gradient identifier should be done in the calling code
References setGradient().
◆ BackgroundData() [4/4]
Qtx::BackgroundData::BackgroundData ( const QGradient &  grad)
gradgradient data
◆ ~BackgroundData()
Qtx::BackgroundData::~BackgroundData ( )
◆ color()
QColor Qtx::BackgroundData::color ( ) const
solid background color
See also
setColor(), mode()
◆ gradient() [1/2]
const QGradient * Qtx::BackgroundData::gradient ( ) const
This function does not transform simple gradient data set with setGradient( const QString&, const QColor&, const QColor& ) to QGradient class
gradient data
See also
setGradient(const QGradient&), mode()
◆ gradient() [2/2]
int Qtx::BackgroundData::gradient ( QColor &  c1,
QColor &  c2
c1first gradient color is returned via this parameter
c2second gradient color is returned via this parameter
current two-colored gradient mode type identifier
See also
setGradient(int, const QColor&, const QColor&), mode()
◆ isTextureShown()
bool Qtx::BackgroundData::isTextureShown ( ) const
true if "show texture" flag is set or false otherwise
See also
setTextureShown(), texture()
◆ isValid()
bool Qtx::BackgroundData::isValid ( ) const
true if background data is valid or false otherwise
See also
mode()
References Qtx::NoBackground.
◆ mode()
Qtx::BackgroundMode Qtx::BackgroundData::mode ( ) const
current background mode
See also
setMode()
◆ operator!=()
bool Qtx::BackgroundData::operator!= ( const BackgroundData &  other) const
References operator==().
◆ operator==()
bool Qtx::BackgroundData::operator== ( const BackgroundData &  other) const
References myColors, myFileName, myGradient, myGradientType, myMode, myTextureMode, and myTextureShown.
◆ setColor()
void Qtx::BackgroundData::setColor ( const QColor &  c)
ccolor
See also
color(), mode()
References Qtx::ColorBackground.
◆ setGradient() [1/2]
void Qtx::BackgroundData::setGradient ( const QGradient &  grad)
gradgradient data (QLinearGradient, QRadialGradient or QConicalGradient)
See also
gradient(), mode()
References Qtx::CustomGradientBackground.
◆ setGradient() [2/2]
void Qtx::BackgroundData::setGradient ( int  type,
const QColor &  c1,
const QColor &  c2
typetwo-colored gradient mode type identifier
See also
gradient(QColor&, QColor&), mode()
References Qtx::SimpleGradientBackground.
◆ setMode()
void Qtx::BackgroundData::setMode ( const  BackgroundMode)
mbackground mode being set
See also
mode()
◆ setTexture()
void Qtx::BackgroundData::setTexture ( const QString &  fileName,
const Qtx::TextureMode  m = Qtx::CenterTexture
To show texture image on the background it is necessary to call additionally setTextureShown() method.
fileNamepath to the texture image file name
mtexture mode (Qtx::CenterTexture by default)
See also
texture(), setTextureShown()
◆ setTextureShown()
void Qtx::BackgroundData::setTextureShown ( bool  on)
ontrue if texture should be shown or false otherwise
See also
isTextureShown(), texture()
◆ texture()
Qtx::TextureMode Qtx::BackgroundData::texture ( QString &  fileName) const
See also
setTexture(), setTextureShown()
◆ myColors
QColorList Qtx::BackgroundData::myColors
◆ myFileName
QString Qtx::BackgroundData::myFileName
◆ myGradient
QGradient Qtx::BackgroundData::myGradient
◆ myGradientType
int Qtx::BackgroundData::myGradientType
◆ myMode
BackgroundMode Qtx::BackgroundData::myMode
◆ myTextureMode
TextureMode Qtx::BackgroundData::myTextureMode
◆ myTextureShown
bool Qtx::BackgroundData::myTextureShown
