Qtx::Localizer Class Reference
Localization helper. More...
#include <Qtx.h>
 Localizer ()
 Default constructor. Forces "C" locale to be set as LC_NUMERIC. More...
 Localizer (int, const char *)
 Constructor. Forces locale to be set for category. More...
 ~Localizer ()
 Destructor. Reverts back to the initial locale. More...
void init (int, const char *)
 Internal initialization. More...
int myCategory
QString myOriginalLocale
This helper class can be used to solve the localization problems, usually related to the textual files reading/writing, namely when floating point values are read / written with API functions. The problem relates to such locale specific settings as decimal point separator, thousands separator, etc.
To use the Localizer class, just create a local variable in the beginning of the code where you need to read / write data from textual file(s). The constructor of the class forces setting "C" locale temporarily. The destructor switches back to the initial locale.
There are two ways to create a localizer. First constructor accepts category and locale value to be forced as parameters. The second constructor does not take parameters, and is just a shortcut to the first one, setting LC_NUMERIC as a category and "C" as a locale to force.
readSomething();
writeSomething();
Definition: Qtx.h:151
◆ Localizer() [1/2]
Qtx::Localizer::Localizer ( )
References init().
◆ Localizer() [2/2]
Qtx::Localizer::Localizer ( int  category,
const char *  locale
◆ ~Localizer()
Qtx::Localizer::~Localizer ( )
◆ init()
void Qtx::Localizer::init ( int  category,
const char *  locale
◆ myCategory
int Qtx::Localizer::myCategory
◆ myOriginalLocale
QString Qtx::Localizer::myOriginalLocale
