SOCC_Prs Class Reference
#include <SOCC_Prs.h>
Inheritance diagram for SOCC_Prs:
 SOCC_Prs (const char *entry)
 SOCC_Prs (const char *entry, const Handle(AIS_InteractiveObject)&obj)
 ~SOCC_Prs ()
void GetObjects (AIS_ListOfInteractive &list) const
void AddObject (const Handle(AIS_InteractiveObject)&obj)
void PrependObject (const Handle(AIS_InteractiveObject)&obj)
void RemoveFirst ()
void Clear ()
bool IsNull () const
void SetToActivate (const bool)
bool ToActivate () const
- Public Member Functions inherited from SALOME_OCCPrs
 SALOME_OCCPrs (const char *e)
virtual void DisplayIn (SALOME_View *) const
 It uses double dispatch in order to invoke Display() method corresponding to the actual type of presentation. More...
virtual void EraseIn (SALOME_View *, const bool=false) const
 It uses double dispatch in order to invoke Erase() method corresponding to the actual type of presentation. More...
virtual void BeforeDisplayIn (SALOME_Displayer *, SALOME_View *) const
 It uses double dispatch in order to invoke BeforeDisplayIn() method corresponding to the actual type of presentation. More...
virtual void AfterDisplayIn (SALOME_Displayer *, SALOME_View *) const
 It uses double dispatch in order to invoke AfterDisplayIn() method corresponding to the actual type of presentation. More...
virtual void BeforeEraseIn (SALOME_Displayer *, SALOME_View *) const
 It uses double dispatch in order to invoke BeforeEraseIn() method corresponding to the actual type of presentation. More...
virtual void AfterEraseIn (SALOME_Displayer *, SALOME_View *) const
 It uses double dispatch in order to invoke AfterEraseIn() method corresponding to the actual type of presentation. More...
virtual void Update (SALOME_Displayer *)
 It uses double dispatch in order to invoke Update() method corresponding to the actual type of presentation. More...
virtual void LocalSelectionIn (SALOME_View *, const int) const
 Key method for double dispatch of activation of sub-shapes selection. More...
virtual void LocalSelectionIn (SALOME_View *, const std::list< int >) const
- Public Member Functions inherited from SALOME_Prs
 SALOME_Prs (const char *)
virtual ~SALOME_Prs ()
const char * GetEntry () const
 Get entry. More...
virtual void DisplayIn (SALOME_View *) const =0
 Key method for double dispatch of display operation. More...
virtual void EraseIn (SALOME_View *, const bool=false) const =0
 Key method for double dispatch of erase operation. More...
virtual void BeforeDisplayIn (SALOME_Displayer *, SALOME_View *) const =0
 Key method for double dispatch of pre-display operation. More...
virtual void AfterDisplayIn (SALOME_Displayer *, SALOME_View *) const =0
 Key method for double dispatch of post-display operation. More...
virtual void BeforeEraseIn (SALOME_Displayer *, SALOME_View *) const =0
 Key method for double dispatch of pre-erase operation. More...
virtual void AfterEraseIn (SALOME_Displayer *, SALOME_View *) const =0
 Key method for double dispatch of post-erase operation. More...
virtual void Update (SALOME_Displayer *)=0
 Key method for double dispatch of update operation. More...
virtual bool IsNull () const =0
 Should return true, if this presentation contains a graphic object. More...
virtual void LocalSelectionIn (SALOME_View *, const int) const =0
bool IsClippable () const
void SetClippable (bool isClippable)
AIS_ListOfInteractive myObjects
bool myToActivate
- Protected Attributes inherited from SALOME_Prs
std::string myEntry
bool myIsClippable
◆ SOCC_Prs() [1/2]
SOCC_Prs::SOCC_Prs ( const char *  entry)
explicit
Default constructor
References myToActivate.
◆ SOCC_Prs() [2/2]
SOCC_Prs::SOCC_Prs ( const char *  entry,
const Handle(AIS_InteractiveObject)&  obj
Standard constructor
References AddObject().
◆ ~SOCC_Prs()
SOCC_Prs::~SOCC_Prs ( )
Destructor
References myObjects.
◆ AddObject()
void SOCC_Prs::AddObject ( const Handle(AIS_InteractiveObject)&  obj)
Add interactive object
◆ Clear()
void SOCC_Prs::Clear ( )
Remove all interactive objects
◆ GetObjects()
void SOCC_Prs::GetObjects ( AIS_ListOfInteractive &  list) const
Get interactive objects list
◆ IsNull()
bool SOCC_Prs::IsNull ( ) const
0 if list of the interactive objects is empty [ Reimplemented from SALOME_Prs ]
Implements SALOME_Prs.
◆ PrependObject()
void SOCC_Prs::PrependObject ( const Handle(AIS_InteractiveObject)&  obj)
Prepend interactive object
◆ RemoveFirst()
void SOCC_Prs::RemoveFirst ( )
Remove first interactive object
◆ SetToActivate()
void SOCC_Prs::SetToActivate ( const bool  toActivate)
This method is used for activisation/deactivisation of objects in the moment of displaying
◆ ToActivate()
bool SOCC_Prs::ToActivate ( ) const
◆ myObjects
AIS_ListOfInteractive SOCC_Prs::myObjects
◆ myToActivate
bool SOCC_Prs::myToActivate
