SPlot2d_Prs Class Reference
#include <SPlot2d_Prs.h>
Inheritance diagram for SPlot2d_Prs:
 SPlot2d_Prs (const char *entry)
 SPlot2d_Prs (const char *entry, const Plot2d_Object *obj)
 SPlot2d_Prs (const Plot2d_Prs *prs)
 ~SPlot2d_Prs ()
virtual bool IsNull () const
objectList GetObjects () const
- Public Member Functions inherited from SALOME_Prs2d
 SALOME_Prs2d (const char *e)
virtual void DisplayIn (SALOME_View *) const
 It uses double dispatch in order to invoke Display() method corresponding to the actual type of presentation. More...
virtual void EraseIn (SALOME_View *, const bool=false) const
 It uses double dispatch in order to invoke Erase() method corresponding to the actual type of presentation. More...
virtual void BeforeDisplayIn (SALOME_Displayer *, SALOME_View *) const
 It uses double dispatch in order to invoke BeforeDisplayIn() method corresponding to the actual type of presentation. More...
virtual void AfterDisplayIn (SALOME_Displayer *, SALOME_View *) const
 It uses double dispatch in order to invoke AfterDisplayIn() method corresponding to the actual type of presentation. More...
virtual void BeforeEraseIn (SALOME_Displayer *, SALOME_View *) const
 It uses double dispatch in order to invoke BeforeEraseIn() method corresponding to the actual type of presentation. More...
virtual void AfterEraseIn (SALOME_Displayer *, SALOME_View *) const
 It uses double dispatch in order to invoke AfterEraseIn() method corresponding to the actual type of presentation. More...
virtual void Update (SALOME_Displayer *)
 It uses double dispatch in order to invoke Update() method corresponding to the actual type of presentation. More...
virtual void LocalSelectionIn (SALOME_View *, const int) const
 Key method for double dispatch of activation of sub-shapes selection. More...
 SALOME_Prs (const char *)
virtual ~SALOME_Prs ()
const char * GetEntry () const
 Get entry. More...
virtual void DisplayIn (SALOME_View *) const =0
 Key method for double dispatch of display operation. More...
virtual void EraseIn (SALOME_View *, const bool=false) const =0
 Key method for double dispatch of erase operation. More...
virtual void BeforeDisplayIn (SALOME_Displayer *, SALOME_View *) const =0
 Key method for double dispatch of pre-display operation. More...
virtual void AfterDisplayIn (SALOME_Displayer *, SALOME_View *) const =0
 Key method for double dispatch of post-display operation. More...
virtual void BeforeEraseIn (SALOME_Displayer *, SALOME_View *) const =0
 Key method for double dispatch of pre-erase operation. More...
virtual void AfterEraseIn (SALOME_Displayer *, SALOME_View *) const =0
 Key method for double dispatch of post-erase operation. More...
virtual void Update (SALOME_Displayer *)=0
 Key method for double dispatch of update operation. More...
virtual bool IsNull () const =0
 Should return true, if this presentation contains a graphic object. More...
virtual void LocalSelectionIn (SALOME_View *, const int) const =0
virtual void LocalSelectionIn (SALOME_View *, const std::list< int >) const
bool IsClippable () const
void SetClippable (bool isClippable)
- Public Member Functions inherited from Plot2d_Prs
 Plot2d_Prs (bool theDelete=false)
 Plot2d_Prs (Plot2d_Object *obj, bool theDelete=false)
virtual ~Plot2d_Prs ()
objectList getObjects () const
void AddObject (Plot2d_Object *obj)
bool isSecondY () const
void setAutoDel (bool theDel)
- Protected Attributes inherited from SALOME_Prs
std::string myEntry
bool myIsClippable
- Protected Attributes inherited from Plot2d_Prs
objectList myObjects
bool mySecondY
bool myIsAutoDel
◆ SPlot2d_Prs() [1/3]
SPlot2d_Prs::SPlot2d_Prs ( const char *  entry)
explicit
Default constructor
◆ SPlot2d_Prs() [2/3]
SPlot2d_Prs::SPlot2d_Prs ( const char *  entry,
const Plot2d_Object *  obj
Standard constructor
◆ SPlot2d_Prs() [3/3]
◆ ~SPlot2d_Prs()
SPlot2d_Prs::~SPlot2d_Prs ( )
Destructor
◆ GetObjects()
objectList SPlot2d_Prs::GetObjects ( ) const
Get contained objects
References Plot2d_Prs::getObjects().
◆ IsNull()
bool SPlot2d_Prs::IsNull ( ) const
Check if the presentation is empty
Implements SALOME_Prs.
References Plot2d_Prs::IsNull().
