SUIT_DataObject::Signal Class Reference
Watcher class, responsible for the emitting signals on behalf of the data objects. More...
#include <SUIT_DataObject.h>
Inheritance diagram for SUIT_DataObject::Signal:
Signals
void created (SUIT_DataObject *)
 Emitted when data object is created. More...
void destroyed (SUIT_DataObject *)
 Emitted when data object is destroyed. More...
void inserted (SUIT_DataObject *, SUIT_DataObject *)
 Emitted when data object is inserted to the parent data object. More...
void removed (SUIT_DataObject *, SUIT_DataObject *)
 Emitted when data object is removed from the parent data object. More...
void modified (SUIT_DataObject *)
 Signal ()
virtual ~Signal ()
void emitCreated (SUIT_DataObject *)
 Emit signal about data object creation. More...
void emitDestroyed (SUIT_DataObject *)
 Emit signal about data object destroying. More...
void emitInserted (SUIT_DataObject *, SUIT_DataObject *)
 Emit signal about data object adding to the parent data object. More...
void emitRemoved (SUIT_DataObject *, SUIT_DataObject *)
 Emit signal about data object removed from the parent data object. More...
void emitModified (SUIT_DataObject *)
 Emit a signal to notify that the data object has been modified. More...
void deleteLater (SUIT_DataObject *)
 Schedule data object for the late deleting. More...
DataObjectList myDelLaterObjects
Friends
class SUIT_DataObject
SUIT_DataObject class does not inherit from QObject for the performance reasons, so it can not use signals/slots mechanism directly. Instead it uses the only Signal object to emit the signals when the data object is created, destroyed, inserted to the parent object or removed from it.
If some object needs to handle, for example, data object destroying, it can use SUIT_DataObject::signal() method to connect the signal:
MyHandler* h = new MyHandler();
h, SLOT(onDestroyed(SUIT_DataObject*)) );
void destroyed(SUIT_DataObject *)
Data object representing the data instance in the tree-like hierarchy.
Definition: SUIT_DataObject.h:49
static Signal * signal()
Get global signal handler.
Definition: SUIT_DataObject.cxx:812
The same can be done by using static method SUIT_DataObject::connect(). For example,
h, SLOT(onDestroyed(SUIT_DataObject*)));
static bool connect(const char *, QObject *, const char *)
Connect to the signal handlerx.
Definition: SUIT_DataObject.cxx:826
◆ Signal()
SUIT_DataObject::Signal::Signal ( )
◆ ~Signal()
SUIT_DataObject::Signal::~Signal ( )
Destroys data object which are scheduled for the deleting with the deleteLater().
◆ created
void SUIT_DataObject::Signal::created ( SUIT_DataObject *  object)
signal
objectdata object being created
◆ deleteLater()
void SUIT_DataObject::Signal::deleteLater ( SUIT_DataObject *  object)
objectdata object to be deleted later
◆ destroyed
void SUIT_DataObject::Signal::destroyed ( SUIT_DataObject *  object)
signal
objectdata object being destroyed
◆ emitCreated()
void SUIT_DataObject::Signal::emitCreated ( SUIT_DataObject *  object)
◆ emitDestroyed()
void SUIT_DataObject::Signal::emitDestroyed ( SUIT_DataObject *  object)
◆ emitInserted()
void SUIT_DataObject::Signal::emitInserted ( SUIT_DataObject *  object,
SUIT_DataObject *  parent
objectdata object being added
parentparent data object
References SUIT_DataObject::parent().
◆ emitModified()
void SUIT_DataObject::Signal::emitModified ( SUIT_DataObject *  object)
objectdata object that has been modified
References SUIT_DataObject::modified().
◆ emitRemoved()
void SUIT_DataObject::Signal::emitRemoved ( SUIT_DataObject *  object,
objectdata object being removed
◆ inserted
void SUIT_DataObject::Signal::inserted ( SUIT_DataObject *  object,
signal
◆ modified
void SUIT_DataObject::Signal::modified ( SUIT_DataObject *  )
signal
◆ removed
void SUIT_DataObject::Signal::removed ( SUIT_DataObject *  object,
signal
◆ SUIT_DataObject
friend class SUIT_DataObject
friend
◆ myDelLaterObjects
DataObjectList SUIT_DataObject::Signal::myDelLaterObjects
