SUIT_FoundActionTree Class Reference
#include <SUIT_FindActionDialog.h>
Inheritance diagram for SUIT_FoundActionTree:
enum  ColumnIdx { Name , ToolTip , KeySequence }
enum class  SortKey {
  MatchMetrics , ID , Name , ToolTip ,
  KeySequence
 SUIT_FoundActionTree (SUIT_FindActionWidget *theParent, const QString &theActionItemToolTip, bool theEnableItemsOfUnavailableActions=false, bool theShowKeySequenceColumn=false, const std::function< std::pair< QString, bool >(const QString &, const QString &)> &theKeySequenceGetter=std::function< std::pair< QString, bool >(const QString &, const QString &)>())
 SUIT_FoundActionTree (const SUIT_FoundActionTree &)=delete
SUIT_FoundActionTree & operator= (const SUIT_FoundActionTree &)=delete
virtual ~SUIT_FoundActionTree ()=default
void updateItems (const std::map< QString, std::map< QString, SUIT_ActionSearcher::AssetsAndSearchData > > &theActionAssetsAndSD)
void sort (SUIT_FoundActionTree::SortKey theKey, Qt::SortOrder theOrder)
void keyPressEvent (QKeyEvent *theEvent)
static std::pair< QString, bool > getKeySequenceFromShortcutMgr (const QString &theModuleID, const QString &theInModuleActionID)
 Default key sequence getter. More...
Public Attributes
const QString myActionItemToolTip
const bool myEnableItemsOfUnavailableActions
const bool myShowKeySequenceColumn
const std::function< std::pair< QString, bool >(const QString &, const QString &)> myKeySequenceGetter
 std::pair<QString, bool> getKeySequence(theModuleID, theInModuleActionID). More...
Static Public Attributes
static const QList< std::pair< SUIT_FoundActionTree::SortKey, Qt::SortOrder > > DEFAULT_SORT_SCHEMA
bool eventFilter (QObject *theQObject, QEvent *theEvent)
Private Slots
void onItemExecuted (QTreeWidgetItem *theWidgetItem, int theColIdx)
std::pair< SUIT_FoundActionTreeModule *, int > findModuleItem (const QString &theModuleID) const
std::set< SUIT_FoundActionTreeAction *, std::function< bool(SUIT_FoundActionTreeAction *, SUIT_FoundActionTreeAction *)> > createActionSetWithComparator () const
SUIT_FoundActionTree::SortKey mySortKey
Qt::SortOrder mySortOrder
std::map< QString, bool > myModuleItemExpansionStates
 {moduleID, isExpanded}[] More...
◆ ColumnIdx
Name
ToolTip
KeySequence
◆ SortKey
enum class SUIT_FoundActionTree::SortKey
strong
MatchMetrics
ID
Name
ToolTip
KeySequence
◆ SUIT_FoundActionTree() [1/2]
SUIT_FoundActionTree::SUIT_FoundActionTree ( SUIT_FindActionWidget *  theParent,
const QString &  theActionItemToolTip,
bool  theEnableItemsOfUnavailableActions = false,
bool  theShowKeySequenceColumn = false,
const std::function< std::pair< QString, bool >(const QString &, const QString &)> &  theKeySequenceGetter = std::function<std::pair<QString, bool>(const QString&, const QString&)>()
theKeySequenceGetterIf default or empty, SUIT_FoundActionTree::getKeySequenceFromShortcutMgr is used.
References MatchMetrics, myShowKeySequenceColumn, mySortKey, mySortOrder, and onItemExecuted().
◆ SUIT_FoundActionTree() [2/2]
SUIT_FoundActionTree::SUIT_FoundActionTree ( const SUIT_FoundActionTree &  )
delete
◆ ~SUIT_FoundActionTree()
virtual SUIT_FoundActionTree::~SUIT_FoundActionTree ( )
virtualdefault
◆ createActionSetWithComparator()
std::set< SUIT_FoundActionTreeAction *, std::function< bool(SUIT_FoundActionTreeAction *, SUIT_FoundActionTreeAction *)> > SUIT_FoundActionTree::createActionSetWithComparator ( ) const
◆ eventFilter()
bool SUIT_FoundActionTree::eventFilter ( QObject *  theQObject,
QEvent *  theEvent
References keyPressEvent().
◆ findModuleItem()
std::pair< SUIT_FoundActionTreeModule *, int > SUIT_FoundActionTree::findModuleItem ( const QString &  theModuleID) const
◆ getKeySequenceFromShortcutMgr()
std::pair< QString, bool > SUIT_FoundActionTree::getKeySequenceFromShortcutMgr ( const QString &  theModuleID,
const QString &  theInModuleActionID
{keySequence, false}
References SUIT_ShortcutMgr::get().
◆ keyPressEvent()
void SUIT_FoundActionTree::keyPressEvent ( QKeyEvent *  theEvent)
References onItemExecuted().
◆ onItemExecuted
void SUIT_FoundActionTree::onItemExecuted ( QTreeWidgetItem *  theWidgetItem,
int  theColIdx
privateslot
◆ operator=()
SUIT_FoundActionTree & SUIT_FoundActionTree::operator= ( const SUIT_FoundActionTree &  )
delete
◆ sort()
void SUIT_FoundActionTree::sort ( SUIT_FoundActionTree::SortKey  theKey,
◆ updateItems()
◆ DEFAULT_SORT_SCHEMA
const QList< std::pair< SUIT_FoundActionTree::SortKey, Qt::SortOrder > > SUIT_FoundActionTree::DEFAULT_SORT_SCHEMA
◆ myActionItemToolTip
const QString SUIT_FoundActionTree::myActionItemToolTip
◆ myEnableItemsOfUnavailableActions
const bool SUIT_FoundActionTree::myEnableItemsOfUnavailableActions
◆ myKeySequenceGetter
const std::function<std::pair<QString, bool>(const QString&, const QString&)> SUIT_FoundActionTree::myKeySequenceGetter
Returns true, if KeySequence column of an action item must be styled as modified.
◆ myModuleItemExpansionStates
std::map<QString, bool> SUIT_FoundActionTree::myModuleItemExpansionStates
◆ myShowKeySequenceColumn
const bool SUIT_FoundActionTree::myShowKeySequenceColumn
◆ mySortKey
SUIT_FoundActionTree::SortKey SUIT_FoundActionTree::mySortKey
◆ mySortOrder
Qt::SortOrder SUIT_FoundActionTree::mySortOrder
