SUIT_KeySequenceEdit Class Reference
#include <SUIT_ShortcutEditor.h>
Inheritance diagram for SUIT_KeySequenceEdit:
Signals
void editingStarted ()
void editingFinished ()
void restoreFromShortcutMgrClicked ()
 SUIT_KeySequenceEdit (QWidget *=nullptr)
virtual ~SUIT_KeySequenceEdit ()=default
void setConfirmedKeySequence (const QKeySequence &)
 Set a key sequence to edit. More...
void setEditedKeySequence (const QKeySequence &)
QKeySequence editedKeySequence () const
bool isKeySequenceModified () const
void restoreKeySequence ()
 Set confirmed key sequence to line editor. More...
static QString parseEvent (QKeyEvent *theEvent)
 Extracts key sequnce string from theEvent. More...
static bool isValidKey (int theKey)
 Check if the key event contains a 'valid' key. More...
virtual bool eventFilter (QObject *theObject, QEvent *theEvent)
Private Slots
void onClear ()
 Called when "Clear" button is clicked. More...
void onEditingFinished ()
 Called when myKeySequenceLineEdit loses focus. More...
void initialize ()
QLineEdit * myKeySequenceLineEdit
QString myConfirmedKeySequenceString
QString myPrevKeySequenceString
◆ SUIT_KeySequenceEdit()
SUIT_KeySequenceEdit::SUIT_KeySequenceEdit ( QWidget *  parent = nullptr)
◆ ~SUIT_KeySequenceEdit()
virtual SUIT_KeySequenceEdit::~SUIT_KeySequenceEdit ( )
virtualdefault
◆ editedKeySequence()
QKeySequence SUIT_KeySequenceEdit::editedKeySequence ( ) const
References myKeySequenceLineEdit.
◆ editingFinished
void SUIT_KeySequenceEdit::editingFinished ( )
signal
◆ editingStarted
void SUIT_KeySequenceEdit::editingStarted ( )
signal
◆ eventFilter()
bool SUIT_KeySequenceEdit::eventFilter ( QObject *  theObject,
QEvent *  theEvent
true if further event processing should be stopped.
References editingStarted(), myKeySequenceLineEdit, onEditingFinished(), and parseEvent().
◆ initialize()
void SUIT_KeySequenceEdit::initialize ( )
◆ isKeySequenceModified()
bool SUIT_KeySequenceEdit::isKeySequenceModified ( ) const
true, if the edited key sequence differs from confirmed one.
References editedKeySequence(), and myConfirmedKeySequenceString.
◆ isValidKey()
bool SUIT_KeySequenceEdit::isValidKey ( int  theKey)
theKeyCode of the key.
◆ onClear
void SUIT_KeySequenceEdit::onClear ( )
privateslot
References editingFinished(), myKeySequenceLineEdit, and myPrevKeySequenceString.
◆ onEditingFinished
void SUIT_KeySequenceEdit::onEditingFinished ( )
privateslot
◆ parseEvent()
QString SUIT_KeySequenceEdit::parseEvent ( QKeyEvent *  theEvent)
References isValidKey().
◆ restoreFromShortcutMgrClicked
void SUIT_KeySequenceEdit::restoreFromShortcutMgrClicked ( )
signal
◆ restoreKeySequence()
void SUIT_KeySequenceEdit::restoreKeySequence ( )
References myConfirmedKeySequenceString, myKeySequenceLineEdit, and myPrevKeySequenceString.
◆ setConfirmedKeySequence()
void SUIT_KeySequenceEdit::setConfirmedKeySequence ( const QKeySequence &  theKeySequence)
◆ setEditedKeySequence()
void SUIT_KeySequenceEdit::setEditedKeySequence ( const QKeySequence &  theKeySequence)
◆ myConfirmedKeySequenceString
QString SUIT_KeySequenceEdit::myConfirmedKeySequenceString
◆ myKeySequenceLineEdit
QLineEdit* SUIT_KeySequenceEdit::myKeySequenceLineEdit
◆ myPrevKeySequenceString
QString SUIT_KeySequenceEdit::myPrevKeySequenceString
