SUIT_ProxyModel Class Reference
Proxy model which can be used above the SUIT_TreeModel class to enable custom sorting/filtering of the data. More...
#include <SUIT_TreeModel.h>
Inheritance diagram for SUIT_ProxyModel:
Public Slots
virtual void updateTree (const QModelIndex &)
 Update tree model. More...
virtual void updateTree (SUIT_DataObject *=0)
void setSortingEnabled (bool)
 Enable/disable sorting. More...
Signals
void modelUpdated ()
void clicked (SUIT_DataObject *, int)
void dropped (const QList< SUIT_DataObject * > &, SUIT_DataObject *, int, Qt::DropAction)
void renamed (SUIT_DataObject *)
 SUIT_ProxyModel (QObject *=0)
 SUIT_ProxyModel (SUIT_DataObject *, QObject *=0)
 SUIT_ProxyModel (SUIT_AbstractModel *, QObject *=0)
 ~SUIT_ProxyModel ()
 Get data tree root object. More...
void setRoot (SUIT_DataObject *)
 Set data tree root object. More...
SUIT_DataObject * object (const QModelIndex &=QModelIndex()) const
 Get data object by the specified model index. More...
QModelIndex index (const SUIT_DataObject *, int=0) const
 Get model index by the specified data object. More...
bool autoDeleteTree () const
 Get 'auto-delete data tree' flag value. More...
void setAutoDeleteTree (const bool)
 Set 'auto-delete data tree' flag value. More...
bool autoUpdate () const
 Get 'auto-update tree' flag value. More...
void setAutoUpdate (const bool)
 Set 'auto-update tree' flag value. More...
bool updateModified () const
 Get 'updateModified' flag value. More...
void setUpdateModified (const bool)
 Set 'updateModified' flag value. More...
bool isSortingEnabled () const
 Check if sorting is enabled. More...
bool customSorting (const int) const
 Check if the specified column supports custom sorting. More...
virtual void forgetObject (const SUIT_DataObject *)
virtual bool lessThan (const QModelIndex &, const QModelIndex &) const
 Compares two model indexes for the sorting purposes. More...
virtual void registerColumn (const int group_id, const QString &name, const int custom_id)
 Register new column in the model. More...
virtual void unregisterColumn (const int group_id, const QString &name)
 Remove column from the model. More...
virtual void setColumnIcon (const QString &name, const QPixmap &icon)
 Change column icon. More...
virtual QPixmap columnIcon (const QString &name) const
 Get column icon. More...
virtual void setAppropriate (const QString &name, const Qtx::Appropriate appr)
 Change appropriate status. More...
virtual Qtx::Appropriate appropriate (const QString &name) const
 Check if the column should appear in the tree view header popup menu (to show/hide the column). More...
virtual void setVisibilityState (const QString &id, Qtx::VisibilityState state, bool emitChanged=true)
 Set visibility state of the object. More...
virtual void setVisibilityStateForAll (Qtx::VisibilityState state)
 Set visibility state for all objects. More...
virtual Qtx::VisibilityState visibilityState (const QString &id) const
 Get visibility state of the object. More...
virtual void setHeaderFlags (const QString &name, const Qtx::HeaderViewFlags flags)
 Set header flags. More...
virtual Qtx::HeaderViewFlags headerFlags (const QString &name) const
 Get the header flags. More...
virtual void emitClicked (SUIT_DataObject *obj, const QModelIndex &index)
virtual SUIT_DataSearcher * searcher () const
virtual void setSearcher (SUIT_DataSearcher *)
QAbstractItemDelegate * delegate () const
 Get item delegate for the model. More...
- Public Member Functions inherited from SUIT_AbstractModel
 SUIT_AbstractModel ()
 operator const QAbstractItemModel * () const
 operator QAbstractItemModel * ()
 operator const QObject * () const
virtual SUIT_DataObject * root () const =0
virtual void setRoot (SUIT_DataObject *)=0
virtual SUIT_DataObject * object (const QModelIndex &=QModelIndex()) const =0
virtual QModelIndex index (const SUIT_DataObject *, int=0) const =0
virtual bool autoDeleteTree () const =0
virtual void setAutoDeleteTree (const bool)=0
virtual bool autoUpdate () const =0
virtual void setAutoUpdate (const bool)=0
virtual bool updateModified () const =0
virtual void setUpdateModified (const bool)=0
virtual QAbstractItemDelegate * delegate () const =0
virtual bool customSorting (const int) const =0
virtual bool lessThan (const QModelIndex &left, const QModelIndex &right) const =0
virtual void forgetObject (const SUIT_DataObject *)=0
virtual void updateTree (const QModelIndex &)=0
virtual void updateTree (SUIT_DataObject *=0)=0
virtual void registerColumn (const int group_id, const QString &name, const int custom_id)=0
virtual void unregisterColumn (const int group_id, const QString &name)=0
virtual void setColumnIcon (const QString &name, const QPixmap &icon)=0
virtual QPixmap columnIcon (const QString &name) const =0
virtual void setAppropriate (const QString &name, const Qtx::Appropriate appr)=0
virtual Qtx::Appropriate appropriate (const QString &name) const =0
virtual void setVisibilityState (const QString &id, Qtx::VisibilityState state, bool emitChanged=true)=0
virtual void setVisibilityStateForAll (Qtx::VisibilityState state)=0
virtual Qtx::VisibilityState visibilityState (const QString &id) const =0
virtual void setHeaderFlags (const QString &name, const Qtx::HeaderViewFlags flags)=0
virtual Qtx::HeaderViewFlags headerFlags (const QString &name) const =0
virtual void emitClicked (SUIT_DataObject *obj, const QModelIndex &index)=0
SUIT_AbstractModel * treeModel () const
virtual bool filterAcceptsRow (int, const QModelIndex &) const
 Filter rows. More...
bool mySortingEnabled
The SUIT_TreeModel class does not support custom sorting/filtering of the data. To use these features, the SUIT_ProxyModel class can be used as top-level wrapper for the SUIT_DataObject-based data tree model.
◆ SUIT_ProxyModel() [1/3]
SUIT_ProxyModel::SUIT_ProxyModel ( QObject *  parent = 0)
parentparent object
References clicked(), dropped(), modelUpdated(), and renamed().
◆ SUIT_ProxyModel() [2/3]
SUIT_ProxyModel::SUIT_ProxyModel ( SUIT_DataObject *  root,
rootroot data object
parentparent object
References clicked(), dropped(), modelUpdated(), renamed(), and root().
◆ SUIT_ProxyModel() [3/3]
SUIT_ProxyModel::SUIT_ProxyModel ( SUIT_AbstractModel *  model,
modeltree model
parentparent object
◆ ~SUIT_ProxyModel()
SUIT_ProxyModel::~SUIT_ProxyModel ( )
◆ appropriate()
Qtx::Appropriate SUIT_ProxyModel::appropriate ( const QString &  name) const
Default implementation (if appropriate status is not specified yet) returns Shown, it means that column should be always visible.
name- column name
appropriate status
Implements SUIT_AbstractModel.
References SUIT_AbstractModel::appropriate(), Qtx::Shown, and treeModel().
◆ autoDeleteTree()
bool SUIT_ProxyModel::autoDeleteTree ( ) const
See also
setAutoDeleteTree()
References SUIT_AbstractModel::autoDeleteTree(), and treeModel().
◆ autoUpdate()
bool SUIT_ProxyModel::autoUpdate ( ) const
See also
setAutoUpdate(), updateTree()
References SUIT_AbstractModel::autoUpdate(), and treeModel().
◆ clicked
void SUIT_ProxyModel::clicked ( SUIT_DataObject *  ,
int
signal
◆ columnIcon()
QPixmap SUIT_ProxyModel::columnIcon ( const QString &  name) const
Get column icon.
name- column name
icon of the specified column
References SUIT_AbstractModel::columnIcon(), and treeModel().
◆ customSorting()
bool SUIT_ProxyModel::customSorting ( const int  column) const
columncolumn index on which data is being sorted
true if column requires custom sorting
See also
lessThan()
References SUIT_AbstractModel::customSorting(), and treeModel().
◆ delegate()
QAbstractItemDelegate * SUIT_ProxyModel::delegate ( ) const
new item delegate
References SUIT_AbstractModel::delegate(), and treeModel().
◆ dropped
void SUIT_ProxyModel::dropped ( const QList< SUIT_DataObject * > &  ,
SUIT_DataObject *  ,
int  ,
Qt::DropAction
signal
◆ emitClicked()
void SUIT_ProxyModel::emitClicked ( SUIT_DataObject *  obj,
const QModelIndex &  index
◆ filterAcceptsRow()
bool SUIT_ProxyModel::filterAcceptsRow ( int  sourceRow,
const QModelIndex &  sourceParent
Filter rows.
sourceRowrow index of the source data model
sourceParentparent model index of the source data model
true if the specified row should be filtered out (i.e. not displayed) or false otherwise
References SUIT_DataObject::expandable(), index(), SUIT_DataObject::isVisible(), SUIT_AbstractModel::object(), SUIT_DataObject::parent(), and treeModel().
◆ forgetObject()
void SUIT_ProxyModel::forgetObject ( const SUIT_DataObject *  obj)
◆ headerFlags()
Qtx::HeaderViewFlags SUIT_ProxyModel::headerFlags ( const QString &  name) const
These flags allow show in the header of the column text (name of the column), icon or both text and icon.
name- column name
header flags
References SUIT_AbstractModel::headerFlags(), Qtx::ShowAll, and treeModel().
◆ index()
QModelIndex SUIT_ProxyModel::index ( const SUIT_DataObject *  obj,
int  column = 0
objdata object
columndata object column
model index
References index(), and treeModel().
◆ isSortingEnabled()
bool SUIT_ProxyModel::isSortingEnabled ( ) const
true if sorting is enabled
See also
setSortingEnabled()
References mySortingEnabled.
◆ lessThan()
bool SUIT_ProxyModel::lessThan ( const QModelIndex &  left,
const QModelIndex &  right
leftfirst index to compare
rightsecond index to compare
result of the comparison
References customSorting(), isSortingEnabled(), SUIT_AbstractModel::lessThan(), and treeModel().
◆ modelUpdated
void SUIT_ProxyModel::modelUpdated ( )
signal
◆ object()
SUIT_DataObject * SUIT_ProxyModel::object ( const QModelIndex &  index = QModelIndex()) const
indexmodel index
data object corresponding to the model index
References index(), SUIT_AbstractModel::object(), and treeModel().
◆ registerColumn()
void SUIT_ProxyModel::registerColumn ( const int  group_id,
const QString &  name,
const int  custom_id
group_id- unique data object identificator allowing the classification of objects
name- translated column name
custom_id- custom column id that should be passed into method SUIT_DataObject::data()
References SUIT_AbstractModel::registerColumn(), and treeModel().
◆ renamed
void SUIT_ProxyModel::renamed ( SUIT_DataObject *  )
signal
◆ root()
SUIT_DataObject * SUIT_ProxyModel::root ( ) const
data tree root
See also
setRoot()
References SUIT_AbstractModel::root(), and treeModel().
◆ searcher()
SUIT_DataSearcher * SUIT_ProxyModel::searcher ( ) const
Reimplemented from SUIT_AbstractModel.
References SUIT_AbstractModel::searcher(), and treeModel().
◆ setAppropriate()
void SUIT_ProxyModel::setAppropriate ( const QString &  name,
Appropriate status determines if the column should appear in the tree view header popup menu (to show/hide the column).
If appropriate status is not specified yet, the Shown value is taken, it means that column should be always visible.
name- column name
appr- new appropriate status
References SUIT_AbstractModel::setAppropriate(), and treeModel().
◆ setAutoDeleteTree()
void SUIT_ProxyModel::setAutoDeleteTree ( const bool  on)
If this flag is set to true, the data tree is deleted when the tree model is destroyed. Default value for this flag is false.
on'auto-delete data tree' flag value
See also
autoDeleteTree()
References SUIT_AbstractModel::setAutoDeleteTree(), and treeModel().
◆ setAutoUpdate()
void SUIT_ProxyModel::setAutoUpdate ( const bool  on)
If this flag is set to true (by default), the model is updated automatically when data tree is changed.
on'auto-update tree' flag value
See also
autoUpdate(), updateTree()
References SUIT_AbstractModel::setAutoUpdate(), and treeModel().
◆ setColumnIcon()
void SUIT_ProxyModel::setColumnIcon ( const QString &  name,
const QPixmap &  icon
Change column icon.
name- column name
icon- new icon of the specified column
References SUIT_AbstractModel::setColumnIcon(), and treeModel().
◆ setHeaderFlags()
void SUIT_ProxyModel::setHeaderFlags ( const QString &  name,
Set header flags.
name- column name
flags- header flags
References SUIT_AbstractModel::setHeaderFlags(), and treeModel().
◆ setRoot()
void SUIT_ProxyModel::setRoot ( SUIT_DataObject *  r)
rnew data tree root
See also
root()
References SUIT_AbstractModel::setRoot(), and treeModel().
◆ setSearcher()
void SUIT_ProxyModel::setSearcher ( SUIT_DataSearcher *  s)
◆ setSortingEnabled
void SUIT_ProxyModel::setSortingEnabled ( bool  enabled)
slot
enablednew flag state
See also
isSortingEnabled()
◆ setUpdateModified()
void SUIT_ProxyModel::setUpdateModified ( const bool  on)
If this flag is set to true (default=false), the model is updated by updateTreeModel that uses the isModified flag to update only modified objects
on'updateModified' flag value
References SUIT_AbstractModel::setUpdateModified(), and treeModel().
◆ setVisibilityState()
void SUIT_ProxyModel::setVisibilityState ( const QString &  id,
bool  emitChanged = true
id- column name
state- visible state
emitChanged- if set to false, blocks dataChanged() signal, this can be used to prevent emitting dataChanged() several times for the same data object
References SUIT_AbstractModel::setVisibilityState(), and treeModel().
◆ setVisibilityStateForAll()
void SUIT_ProxyModel::setVisibilityStateForAll ( Qtx::VisibilityState  state)
id- column name
References SUIT_AbstractModel::setVisibilityStateForAll(), and treeModel().
◆ treeModel()
SUIT_AbstractModel * SUIT_ProxyModel::treeModel ( ) const
◆ unregisterColumn()
void SUIT_ProxyModel::unregisterColumn ( const int  group_id,
Please take into account that column is removed only for given group_id, it means that information of data objects with such group_id won't be shown. If there is not any registered group_id for this column after removing, the column will be hidden otherwise it continue to be shown
References treeModel(), and SUIT_AbstractModel::unregisterColumn().
◆ updateModified()
bool SUIT_ProxyModel::updateModified ( ) const
References treeModel(), and SUIT_AbstractModel::updateModified().
◆ updateTree [1/2]
void SUIT_ProxyModel::updateTree ( const QModelIndex &  index)
virtualslot
Update tree model.
Call this method when data tree is changed outside the model. If the 'auto-update' flag is set to true, the model is updated automatically when the data tree is changed.
indexstarting index for the updating
See also
setAutoUpdate()
References index(), treeModel(), and SUIT_AbstractModel::updateTree().
◆ updateTree [2/2]
void SUIT_ProxyModel::updateTree ( SUIT_DataObject *  obj = 0)
virtualslot
Update tree model.
objstarting data object for the updating
See also
setAutoUpdate()
References treeModel(), and SUIT_AbstractModel::updateTree().
◆ visibilityState()
Qtx::VisibilityState SUIT_ProxyModel::visibilityState ( const QString &  id) const
id- column name
visible state
References treeModel(), Qtx::UnpresentableState, and SUIT_AbstractModel::visibilityState().
◆ mySortingEnabled
bool SUIT_ProxyModel::mySortingEnabled
