SUIT_ShortcutContainer Class Reference
Provides means to keep and edit shortcuts in compliance with the application logics. See SUIT_ShortcutMgr for details. More...
#include <SUIT_ShortcutMgr.h>
 SUIT_ShortcutContainer ()
 Uncomment this to enable DevTools. More...
std::set< QString > getIDsOfInterferingModules (const QString &theModuleID) const
std::set< QString > getIDsOfAllModules () const
bool isEmpty () const
std::set< std::pair< QString, QString > > setShortcut (QString theModuleID, const QString &theInModuleActionID, const QKeySequence &theKeySequence, bool theOverride)
 Checks for conflicts. If theOverride, modifies incoming and disables all conflicting shortcuts. Redefining a key sequence for the action, if theKeySequence does not conflict with other shortcuts, is not considered as a conflict. More...
std::set< std::pair< QString, QString > > getConflicts (QString theModuleID, const QString &theInModuleActionID, const QKeySequence &theKeySequence) const
 Checks for conflicts. Existence of a shortcut with another key sequence for the action, if theKeySequence does not conflict with other shortcuts, is not considered as a conflict. More...
const QKeySequence & getKeySequence (QString theModuleID, const QString &theInModuleActionID) const
bool hasShortcut (QString theModuleID, const QString &theInModuleActionID) const
const std::map< QString, QKeySequence > & getModuleShortcutsInversed (const QString &theModuleID) const
const std::map< QString, QKeySequence > getModuleShortcutsInversed (const QString &theModuleID, const QString &theInModuleActionIDPrefix) const
 Seeks for shortcuts in the module with in-module action IDs, which start with theInModuleActionIDPrefix. More...
std::map< QString, std::map< QString, std::pair< QKeySequence, QKeySequence > > > merge (const SUIT_ShortcutContainer &theOther, bool theOverride, bool theTreatAbsentIncomingAsDisabled=false)
 Merges shortcuts of theOther into this. More...
bool hasKeySequence (const QString &theModuleID, const QKeySequence &theKeySequence) const
QString toString () const
 Generates human-readable text representation of content. More...
std::map< QString, std::map< QKeySequence, QString > > myShortcuts
 { moduleID, { keySequence, inModuleActionID }[] }[]. More...
std::map< QString, std::map< QString, QKeySequence > > myShortcutsInversed
 { moduleID, { inModuleActionID, keySequence }[] }[]. More...
◆ SUIT_ShortcutContainer()
SUIT_ShortcutContainer::SUIT_ShortcutContainer ( )
References myShortcuts, myShortcutsInversed, and SUIT_ShortcutMgr::ROOT_MODULE_ID.
◆ getConflicts()
std::set< std::pair< QString, QString > > SUIT_ShortcutContainer::getConflicts ( QString  theModuleID,
const QString &  theInModuleActionID,
const QKeySequence &  theKeySequence
theInModuleActionIDIf theInModuleActionID is meta-action ID, the shortcut is looked for in root module, and theModuleID is ignored.
theKeySequenceEmpty theKeySequence does not have conflicts.
{moduleID, inModuleActionID}[] - Set of conflicting actions.
References getIDsOfInterferingModules(), SUIT_ShortcutMgr::isInModuleMetaActionID(), myShortcuts, and SUIT_ShortcutMgr::ROOT_MODULE_ID.
◆ getIDsOfAllModules()
std::set< QString > SUIT_ShortcutContainer::getIDsOfAllModules ( ) const
References myShortcutsInversed.
◆ getIDsOfInterferingModules()
std::set< QString > SUIT_ShortcutContainer::getIDsOfInterferingModules ( const QString &  theModuleID) const
IDs of modules, which interfere with the module: if the module is root (theModuleID is empty) - returns all module IDs, otherwise returns ["", theModuleID].
References myShortcuts, and SUIT_ShortcutMgr::ROOT_MODULE_ID.
◆ getKeySequence()
const QKeySequence & SUIT_ShortcutContainer::getKeySequence ( QString  theModuleID,
empty key sequence if shortcut for the action is not set.
theInModuleActionIDIf theInModuleActionID is meta-action ID, seeks in root module, and theModuleID is ignored.
References SUIT_ShortcutMgr::isInModuleMetaActionID(), myShortcutsInversed, NO_KEYSEQUENCE, and SUIT_ShortcutMgr::ROOT_MODULE_ID.
◆ getModuleShortcutsInversed() [1/2]
const std::map< QString, QKeySequence > & SUIT_ShortcutContainer::getModuleShortcutsInversed ( const QString &  theModuleID) const
{inModuleActionID, keySequence}[] - If the module was not added, the map is empty.
◆ getModuleShortcutsInversed() [2/2]
const std::map< QString, QKeySequence > SUIT_ShortcutContainer::getModuleShortcutsInversed ( const QString &  theModuleID,
const QString &  theInModuleActionIDPrefix
◆ hasKeySequence()
bool SUIT_ShortcutContainer::hasKeySequence ( const QString &  theModuleID,
References myShortcuts.
◆ hasShortcut()
bool SUIT_ShortcutContainer::hasShortcut ( QString  theModuleID,
true, if shortcut for the action is set (even if the mapped key sequence is empty).
References SUIT_ShortcutMgr::isInModuleMetaActionID(), myShortcutsInversed, and SUIT_ShortcutMgr::ROOT_MODULE_ID.
◆ isEmpty()
bool SUIT_ShortcutContainer::isEmpty ( ) const
True, if no shortcut is added.
◆ merge()
std::map< QString, std::map< QString, std::pair< QKeySequence, QKeySequence > > > SUIT_ShortcutContainer::merge ( const SUIT_ShortcutContainer &  theOther,
bool  theOverride,
bool  theTreatAbsentIncomingAsDisabled = false
theOverrideif true, overrides conflicting shortcuts. If false, and this has no shortcut for an incoming action, and the incoming shortcut conflicts with an existing shortcut, disabled shortcut for the incoming action is set.
theTreatAbsentIncomingAsDisabledIf theOverride == false, theTreatAbsentIncomingAsDisabled is ignored. If theOverride and theTreatAbsentIncomingAsDisabled, and theOther has no shortcut for an action, which exists in this, the existing shortcut in this is set disabled.
{ moduleID, { inModuleActionID, {oldKeySequence, newKeySequence} }[] }[] - Modiified shortcuts inversed.
References getKeySequence(), hasShortcut(), myShortcuts, myShortcutsInversed, NO_KEYSEQUENCE, and setShortcut().
◆ setShortcut()
std::set< std::pair< QString, QString > > SUIT_ShortcutContainer::setShortcut ( QString  theModuleID,
const QKeySequence &  theKeySequence,
bool  theOverride
theModuleIDThe method has no effect if theModuleID is invalid. See SUIT_ShortcutMgr::isModuleIDValid(const QString&) for details.
theInModuleActionIDThe method has no effect if theInModuleActionID is invalid. See SUIT_ShortcutMgr::isInModuleActionIDValid(const QString&). If theInModuleActionID is meta-action ID, the shortcut is set to root module, and theModuleID is ignored.
theKeySequenceEmpty theKeySequence does not cause conflicts, in this case a shortcut for the action is disabled: theInModuleActionID is added/retained in the container but mapped to empty key sequence.
theOverrideIf true, conflicting shortcuts are disabled.
{moduleID, inModuleActionID}[] - Set of conflicting actions if theOverride = false, otherwise set of actions (without incoming one), whose shortcuts have been disabled.
References getIDsOfInterferingModules(), SUIT_ShortcutMgr::isInModuleActionIDValid(), SUIT_ShortcutMgr::isInModuleMetaActionID(), SUIT_ShortcutMgr::isModuleIDValid(), myShortcuts, myShortcutsInversed, NO_KEYSEQUENCE, SUIT_ShortcutMgr::ROOT_MODULE_ID, and ShCutDbg().
◆ toString()
QString SUIT_ShortcutContainer::toString ( ) const
References myShortcuts, and myShortcutsInversed.
◆ myShortcuts
std::map<QString, std::map<QKeySequence, QString> > SUIT_ShortcutContainer::myShortcuts
keySequence can not be empty. Can not contain entries like { <non-root module ID>, { keySequence, <meta-action ID> } }.
◆ myShortcutsInversed
std::map<QString, std::map<QString, QKeySequence> > SUIT_ShortcutContainer::myShortcutsInversed
keySequence can be empty. Can not contain entries like { <non-root module ID>, { <meta-action ID>, keySequence } }.
