SVTK_Prs Class Reference
#include <SVTK_Prs.h>
Inheritance diagram for SVTK_Prs:
 SVTK_Prs (const char *entry)
 SVTK_Prs (const char *entry, const vtkActor *obj)
 ~SVTK_Prs ()
vtkActorCollection * GetObjects () const
void AddObject (const vtkActor *obj)
bool IsNull () const
- Public Member Functions inherited from SALOME_VTKPrs
 SALOME_VTKPrs (const char *e)
virtual void DisplayIn (SALOME_View *) const
 It uses double dispatch in order to invoke Display() method corresponding to the actual type of presentation. More...
virtual void EraseIn (SALOME_View *, const bool=false) const
 It uses double dispatch in order to invoke Erase() method corresponding to the actual type of presentation. More...
virtual void BeforeDisplayIn (SALOME_Displayer *, SALOME_View *) const
 It uses double dispatch in order to invoke BeforeDisplayIn() method corresponding to the actual type of presentation. More...
virtual void AfterDisplayIn (SALOME_Displayer *, SALOME_View *) const
 It uses double dispatch in order to invoke AfterDisplayIn() method corresponding to the actual type of presentation. More...
virtual void BeforeEraseIn (SALOME_Displayer *, SALOME_View *) const
 It uses double dispatch in order to invoke BeforeEraseIn() method corresponding to the actual type of presentation. More...
virtual void AfterEraseIn (SALOME_Displayer *, SALOME_View *) const
 It uses double dispatch in order to invoke AfterEraseIn() method corresponding to the actual type of presentation. More...
virtual void Update (SALOME_Displayer *)
 It uses double dispatch in order to invoke Update() method corresponding to the actual type of presentation. More...
virtual void LocalSelectionIn (SALOME_View *, const int) const
 Key method for double dispatch of activation of sub-shapes selection. More...
- Public Member Functions inherited from SALOME_Prs
 SALOME_Prs (const char *)
virtual ~SALOME_Prs ()
const char * GetEntry () const
 Get entry. More...
virtual void DisplayIn (SALOME_View *) const =0
 Key method for double dispatch of display operation. More...
virtual void EraseIn (SALOME_View *, const bool=false) const =0
 Key method for double dispatch of erase operation. More...
virtual void BeforeDisplayIn (SALOME_Displayer *, SALOME_View *) const =0
 Key method for double dispatch of pre-display operation. More...
virtual void AfterDisplayIn (SALOME_Displayer *, SALOME_View *) const =0
 Key method for double dispatch of post-display operation. More...
virtual void BeforeEraseIn (SALOME_Displayer *, SALOME_View *) const =0
 Key method for double dispatch of pre-erase operation. More...
virtual void AfterEraseIn (SALOME_Displayer *, SALOME_View *) const =0
 Key method for double dispatch of post-erase operation. More...
virtual void Update (SALOME_Displayer *)=0
 Key method for double dispatch of update operation. More...
virtual bool IsNull () const =0
 Should return true, if this presentation contains a graphic object. More...
virtual void LocalSelectionIn (SALOME_View *, const int) const =0
virtual void LocalSelectionIn (SALOME_View *, const std::list< int >) const
bool IsClippable () const
void SetClippable (bool isClippable)
vtkActorCollection * myObjects
- Protected Attributes inherited from SALOME_Prs
std::string myEntry
bool myIsClippable
◆ SVTK_Prs() [1/2]
SVTK_Prs::SVTK_Prs ( const char *  entry)
explicit
Default constructor
◆ SVTK_Prs() [2/2]
SVTK_Prs::SVTK_Prs ( const char *  entry,
const vtkActor *  obj
Standard constructor
References AddObject().
◆ ~SVTK_Prs()
SVTK_Prs::~SVTK_Prs ( )
Destructor
References myObjects.
◆ AddObject()
void SVTK_Prs::AddObject ( const vtkActor *  obj)
Add actor
◆ GetObjects()
vtkActorCollection * SVTK_Prs::GetObjects ( ) const
actors list
◆ IsNull()
bool SVTK_Prs::IsNull ( ) const
0 if list of the actors is empty [ Reimplemented from SALOME_Prs ]
Implements SALOME_Prs.
◆ myObjects
vtkActorCollection* SVTK_Prs::myObjects
