VTKViewer_ShrinkFilter Class Reference
#include <VTKViewer_ShrinkFilter.h>
Inheritance diagram for VTKViewer_ShrinkFilter:
 vtkTypeMacro (VTKViewer_ShrinkFilter, vtkShrinkFilter) void SetStoreMapping(int theStoreMapping)
int GetStoreMapping ()
virtual vtkIdType GetNodeObjId (vtkIdType theVtkID)
virtual vtkIdType GetElemObjId (vtkIdType theVtkID)
static VTKViewer_ShrinkFilter * New ()
 VTKViewer_ShrinkFilter ()
 ~VTKViewer_ShrinkFilter ()
virtual int RequestData (vtkInformation *, vtkInformationVector **, vtkInformationVector *)
void UnstructuredGridExecute ()
Private Types
typedef std::vector< vtkIdType > TVectorId
int myStoreMapping
TVectorId myVTK2ObjIds
Shrink cells composing an arbitrary data set.
Warning
It is possible to turn cells inside out or cause self intersection in special cases.
◆ TVectorId
typedef std::vector<vtkIdType> VTKViewer_ShrinkFilter::TVectorId
◆ VTKViewer_ShrinkFilter()
VTKViewer_ShrinkFilter::VTKViewer_ShrinkFilter ( )
◆ ~VTKViewer_ShrinkFilter()
VTKViewer_ShrinkFilter::~VTKViewer_ShrinkFilter ( )
◆ GetElemObjId()
virtual vtkIdType VTKViewer_ShrinkFilter::GetElemObjId ( vtkIdType  theVtkID)
Return element id by vtk id.
◆ GetNodeObjId()
vtkIdType VTKViewer_ShrinkFilter::GetNodeObjId ( vtkIdType  theVtkID)
Return node object id by vtk node id.
-1- if no object, else return id.
References myVTK2ObjIds.
◆ GetStoreMapping()
int VTKViewer_ShrinkFilter::GetStoreMapping ( )
Gets store mapping flag.
◆ New()
static VTKViewer_ShrinkFilter * VTKViewer_ShrinkFilter::New ( )
Create new instance of VTKViewer_ShrinkFilter.
◆ RequestData()
int VTKViewer_ShrinkFilter::RequestData ( vtkInformation *  ,
vtkInformationVector **  ,
Execute method. Calculate output.
References myStoreMapping, and myVTK2ObjIds.
◆ UnstructuredGridExecute()
void VTKViewer_ShrinkFilter::UnstructuredGridExecute ( )
Not implemented.
◆ vtkTypeMacro()
VTKViewer_ShrinkFilter::vtkTypeMacro ( VTKViewer_ShrinkFilter  ,
vtkShrinkFilter
◆ myStoreMapping
int VTKViewer_ShrinkFilter::myStoreMapping
◆ myVTK2ObjIds
TVectorId VTKViewer_ShrinkFilter::myVTK2ObjIds
