Calcium.hxx
21
23{
24 public:
25 PySupervCompo(CORBA::ORB_ptr orb,
26 PortableServer::POA_ptr poa,
27 Engines::Container_ptr contain,
28 const char *instanceName,
29 const char *interfaceName,
30 bool notif = false);
31 virtual ~PySupervCompo();
32 CORBA::Boolean init_service(const char * /*service_name*/){return true;};
33 CORBA::Boolean init_service_with_multiple(const char* /*service_name*/,
35 {
36 return true;
37 }
38};
39
40
41extern "C" void create_calcium_port(Superv_Component_i* compo,char* name,char* type,char *mode,char* depend);
42
43// This method permits to help a service developer to create multiple calcium ports
44extern "C" char** create_multiple_calcium_port(Superv_Component_i* compo,char* name,char* type,char *mode,char* depend, int number);
char ** create_multiple_calcium_port(Superv_Component_i *compo, char *name, char *type, char *mode, char *depend, int number)
Definition: Calcium.cxx:152
void create_calcium_port(Superv_Component_i *compo, char *name, char *type, char *mode, char *depend)
Definition: Calcium.cxx:90
char * instanceName()
CORBA method: return name of the instance, unique in this Container.
Definition: Component_i.cxx:238
char * interfaceName()
CORBA method: return name of the component class.
Definition: Component_i.cxx:249
Definition: Calcium.hxx:23
Definition: Calcium.cxx:39
CORBA::Boolean init_service_with_multiple(const char *, const Engines::Superv_Component::seq_multiple_param &)
Definition: Calcium.hxx:33
CORBA::Boolean init_service(const char *)
Definition: Calcium.hxx:32
PySupervCompo(CORBA::ORB_ptr orb, PortableServer::POA_ptr poa, Engines::Container_ptr contain, const char *instanceName, const char *interfaceName, bool notif=false)
Definition: Calcium.cxx:29
This class implements DSC_User component.
Definition: Superv_Component_i.hxx:54
sequence< multiple_param > seq_multiple_param
Definition: DSC_Engines.idl:365
poa
Definition: SALOME_ContainerPy.py:377
string name
Definition: pythfilter.py:56
orb
Definition: salome.py:122
