Superv_Component_i Class Reference
This class implements DSC_User component. More...
#include <Superv_Component_i.hxx>
Inheritance diagram for Superv_Component_i:
struct  BadCast
struct  BadFabType
struct  BadProperty
struct  BadType
struct  NilPort
struct  PortAlreadyDefined
struct  PortNotConnected
struct  PortNotDefined
struct  superv_port_t
struct  UnexpectedState
 Superv_Component_i (CORBA::ORB_ptr orb, PortableServer::POA_ptr poa, PortableServer::ObjectId *contId, const char *instanceName, const char *interfaceName, bool notif=false)
 Superv_Component_i (CORBA::ORB_ptr orb, PortableServer::POA_ptr poa, Engines::Container_ptr container, const char *instanceName, const char *interfaceName, bool notif=false, bool regist=false)
virtual ~Superv_Component_i ()
virtual provides_port * create_provides_control_port ()
virtual provides_port * create_provides_data_and_control_port (const char *)
virtual uses_port * create_uses_control_port ()
virtual uses_port * create_uses_data_and_control_port (const char *)
virtual provides_port * create_provides_data_port (const std::string &port_fab_type)
 This method permits to create a provides port provided by the platform. More...
virtual uses_port * create_uses_data_port (const std::string &port_fab_type)
 This method permits to create a uses port provided by the platform. More...
virtual void add_port (const char *port_fab_type, const char *port_type, const char *port_name)
 Adds a port to the component. More...
template<typename SpecificPortType >
SpecificPortType * add_port (const char *port_fab_type, const char *port_type, const char *port_name)
virtual void add_port (provides_port *port, const char *provides_port_name)
 Adds a created provides port to the component. More...
virtual void add_port (uses_port *port, const char *uses_port_name)
 Adds a created uses port to the component. More...
virtual void get_port (provides_port *&port, const char *provides_port_name)
 Gets the provides port already added in the component. More...
virtual void get_port (uses_port *&port, const char *uses_port_name)
 Gets the uses port already added in the component. More...
virtual void get_uses_port_names (std::vector< std::string > &port_names, const std::string servicename="") const
 Gets the list of the ports of a service. More...
SpecificPortType * get_port (const char *port_name)
 Gets a port already added in the component. More...
virtual void provides_port_changed (const char *provides_port_name, int connection_nbr, const Engines::DSC::Message message)
virtual void uses_port_changed (const char *uses_port_name, Engines::DSC::uses_port *new_uses_port, const Engines::DSC::Message message)
virtual port_factory * get_factory (const std::string &factory_name)
 Get a factory from the component. More...
void beginService (const char *serviceName)
virtual CORBA::Boolean init_service_with_multiple (const char *, const Engines::Superv_Component::seq_multiple_param &)
virtual void add_provides_port (Ports::Port_ptr ref, const char *provides_port_name, Ports::PortProperties_ptr port_prop)
virtual void add_uses_port (const char *repository_id, const char *uses_port_name, Ports::PortProperties_ptr port_prop)
virtual Ports::Port_ptr get_provides_port (const char *provides_port_name, const CORBA::Boolean connection_error)
virtual Engines::DSC::uses_port * get_uses_port (const char *uses_port_name)
virtual void connect_provides_port (const char *provides_port_name)
virtual void connect_uses_port (const char *uses_port_name, Ports::Port_ptr provides_port_ref)
virtual CORBA::Boolean is_connected (const char *port_name)
virtual void disconnect_provides_port (const char *provides_port_name, const Engines::DSC::Message message)
virtual void disconnect_uses_port (const char *uses_port_name, Ports::Port_ptr provides_port_ref, const Engines::DSC::Message message)
virtual Ports::PortProperties_ptr get_port_properties (const char *port_name)
CORBA::Boolean isSSLMode () override
char * instanceName ()
 CORBA method: return name of the instance, unique in this Container. More...
char * interfaceName ()
 CORBA method: return name of the component class. More...
void ping ()
 CORBA method: Test if instance is alive and responds. More...
void destroy ()
 CORBA method: Deactivate this instance. More...
Engines::Container_ptr GetContainerRef ()
 CORBA method: return CORBA reference of the Container. More...
void setProperties (const Engines::FieldsDict &dico)
 CORBA method: Gives a sequence of (key=string,value=any) to the component. More...
Engines::FieldsDict * getProperties ()
 CORBA method: returns a previously stored map (key=string,value=any) as a sequence. More...
virtual void SetOption (const char *, const char *)
 CORBA method: This method is to set an option specific to a certain EngineComponent. More...
virtual char * GetOption (const char *)
 CORBA method: This method is to get value of an option specific to a certain EngineComponent. More...
void Names (const char *graphName, const char *nodeName)
 CORBA method: used by Supervision to give names to this instance. More...
bool Kill_impl ()
 CORBA method: used in Supervision. More...
bool Stop_impl ()
bool Suspend_impl ()
bool Resume_impl ()
CORBA::Long CpuUsed_impl ()
 CORBA method: More...
 C++ method: DumpPython default implementation. More...
virtual Engines::Salome_file_ptr getInputFileToService (const char *service_name, const char *Salome_file_name)
virtual Engines::Salome_file_ptr getOutputFileToService (const char *service_name, const char *Salome_file_name)
virtual void checkInputFilesToService (const char *service_name)
virtual Engines::Salome_file_ptr setInputFileToService (const char *service_name, const char *Salome_file_name)
virtual void checkOutputFilesToService (const char *service_name)
virtual Engines::Salome_file_ptr setOutputFileToService (const char *service_name, const char *Salome_file_name)
virtual bool hasObjectInfo ()
 Return true if component can provide creation information. More...
virtual char * getObjectInfo (const char *entry)
 Get creation information for object addressed by given entry. More...
virtual char * getVersion ()
 Get version of the component. More...
PortableServer::ObjectId * getId ()
 C++ method: return CORBA instance id, the id is set in derived class constructor, when instance is activated. More...
Engines_Container_i * GetContainerPtr ()
 C++ method: return Container Servant. More...
std::string getContainerName ()
 C++ method: return the name of the container associated with this component This name does not contains the "/Containers" string and all "/" are replaced by "_". More...
void setContainerName ()
 C++ method: set the name of the container associated with this component (attribute containerName) This name does not contains the "/Containers" string and all "/" are replaced by "</em>". More...
void endService (const char *serviceName)
 C++ method: used by derived classes for supervision. More...
void sendMessage (const char *event_type, const char *message)
 C++ method: Send message to event channel. More...
char * graphName ()
 C++ method: – CHECK IF USED –. More...
char * nodeName ()
bool Killer (pthread_t ThreadId, int signum)
 C++ method: used in Supervision (see kill_impl) More...
void SetCurCpu ()
 C++ method: More...
long CpuUsed ()
 C++ method: More...
void CancelThread ()
 C++ method: More...
virtual void configureSalome_file (std::string service_name, std::string file_port_name, Salome_file_i *file)
 C++ method: used to configure the Salome_file into the runtime. More...
static void register_factory (const std::string &factory_name, port_factory *factory_ptr)
 Add a factory the component. More...
static void setTimeOut ()
static bool isMultiInstance ()
static std::string GetDynLibraryName (const char *componentName)
 C++ method: return standard library name built on component name. More...
static void writeEvent (const char *request, const std::string &containerName, const char *instance_name, const char *port_name, const char *error, const char *message)
 Write a record in the trace file. More...
Static Public Attributes
static long dscTimeOut =0
Protected Types
typedef std::map< std::string, Salome_file_i * > _t_Salome_file_map
typedef std::map< std::string, Engines_Component_i::_t_Salome_file_map * > _t_Service_file_map
enum  port_type { uses , provides , none }
typedef std::map< std::string, port_t * > ports
SALOME_NamingService_Abstract * getNS ()
std::string _instanceName
std::string _interfaceName
std::string _containerName
CORBA::ORB_var _orb
PortableServer::POA_var _poa
PortableServer::ObjectId * _id
PortableServer::ObjectId * _contId
Engines::Container_var _container
Engines_Component_i * _thisObj
RegistryConnexion * _myConnexionToRegistry
NOTIFICATION_Supplier * _notifSupplier
std::map< std::string, CORBA::Any > _fieldsDict
_t_Service_file_map _Input_Service_file_map
_t_Service_file_map _Output_Service_file_map
_t_Service_file_map::iterator _Service_file_map_it
_t_Salome_file_map::iterator _Salome_file_map_it
std::string _serviceName
std::string _graphName
std::string _nodeName
ports my_ports
ports::iterator my_ports_it
Static Protected Attributes
static bool _isMultiInstance = false
Private Types
typedef std::map< std::string, port_factory * > factory_map_t
typedef std::map< std::string, superv_port_t * > superv_ports
superv_ports my_superv_ports
superv_ports::iterator my_superv_ports_it
pthread_t _ThreadId
long _StartUsed
long _ThreadCpuUsed
bool _Executed
bool _CanceledThread
Static Private Attributes
static factory_map_t _factory_map
This class allows a higher programming level than DSC_Basic. It enables a programming level for service's developers who want to use DSC ports.
This class has two level for using and declare ports. The higher level proposes operations to add ports that are provided by default by SALOME like Calcium ports. It provides too some methods to add their own DSC_User ports.
This class doesn't implement the init_service CORBA operation.
◆ _t_Salome_file_map
typedef std::map<std::string, Salome_file_i*> Engines_Component_i::_t_Salome_file_map
◆ _t_Service_file_map
typedef std::map<std::string, Engines_Component_i::_t_Salome_file_map*> Engines_Component_i::_t_Service_file_map
◆ factory_map_t
typedef std::map<std::string, port_factory*> Superv_Component_i::factory_map_t
◆ ports
typedef std::map<std::string, port_t *> Engines_DSC_interface::ports
◆ superv_ports
typedef std::map<std::string, superv_port_t *> Superv_Component_i::superv_ports
◆ port_type
enum Engines_DSC_interface::port_type
uses
provides
none
◆ Superv_Component_i() [1/2]
Superv_Component_i::Superv_Component_i ( CORBA::ORB_ptr  orb,
const char *  instanceName,
const char *  interfaceName,
bool  notif = false
◆ Superv_Component_i() [2/2]
bool  notif = false,
bool  regist = false
◆ ~Superv_Component_i()
Superv_Component_i::~Superv_Component_i ( )
◆ add_port() [1/4]
void Superv_Component_i::add_port ( const char *  port_fab_type,
const char *  port_type,
const char *  port_name
With this method only Salomé's provided DSC ports can be added.
port_fab_typetype of the port.
port_typeuses or provides.
port_namethe name of the port in the component.
References add_port(), create_provides_data_port(), create_uses_data_port(), LOC, and salome_instance::port.
Referenced by add_port(), and create_calcium_port().
◆ add_port() [2/4]
SpecificPortType * Superv_Component_i::add_port ( const char *  port_fab_type,
the created port.
◆ add_port() [3/4]
void Superv_Component_i::add_port ( provides_port *  port,
const char *  provides_port_name
portthe provides port.
provides_port_namethe name of the port in the component.
References Engines_DSC_interface::add_provides_port(), LOC, my_superv_ports, Superv_Component_i::superv_port_t::p_ref, and salome_instance::port.
◆ add_port() [4/4]
void Superv_Component_i::add_port ( uses_port *  port,
const char *  uses_port_name
portthe uses port.
uses_port_namethe name of the port in the component.
References Engines_DSC_interface::add_uses_port(), LOC, my_superv_ports, salome_instance::port, and Superv_Component_i::superv_port_t::u_ref.
◆ add_provides_port()
virtual void Engines_DSC_i::add_provides_port ( Ports::Port_ptr  ref,
const char *  provides_port_name,
◆ add_uses_port()
virtual void Engines_DSC_i::add_uses_port ( const char *  repository_id,
const char *  uses_port_name,
◆ beginService()
void Superv_Component_i::beginService ( const char *  serviceName)
◆ CancelThread()
void Engines_Component_i::CancelThread ( )
C++ method:
References Engines_Component_i::_CanceledThread.
Referenced by CallCancelThread().
◆ checkInputFilesToService()
void Engines_Component_i::checkInputFilesToService ( const char *  service_name)
◆ checkOutputFilesToService()
void Engines_Component_i::checkOutputFilesToService ( const char *  service_name)
◆ configureSalome_file()
void Engines_Component_i::configureSalome_file ( std::string  service_name,
Salome_file_i *  file
service_namename of the service that use this Salome_file
file_port_namename of the Salome_file
fileSalome_file C++ object
Referenced by Engines_Component_i::checkInputFilesToService(), and Engines_Component_i::checkOutputFilesToService().
◆ connect_provides_port()
virtual void Engines_DSC_i::connect_provides_port ( const char *  provides_port_name)
◆ connect_uses_port()
virtual void Engines_DSC_i::connect_uses_port ( const char *  uses_port_name,
◆ CpuUsed()
◆ CpuUsed_impl()
◆ create_provides_control_port()
virtual provides_port * Superv_Component_i::create_provides_control_port ( )
Warning
currently disabled.
◆ create_provides_data_and_control_port()
virtual provides_port * Superv_Component_i::create_provides_data_and_control_port ( const char *  )
Warning
currently disabled.
◆ create_provides_data_port()
provides_port * Superv_Component_i::create_provides_data_port ( const std::string &  port_fab_type)
(See documentation of DSC for knoing these ports).
port_fab_typetype provides port.
the provides port.
It's user repsonsability to destroy the provides port.
References port_factory::create_data_servant(), get_factory(), and LOC.
◆ create_uses_control_port()
virtual uses_port * Superv_Component_i::create_uses_control_port ( )
Warning
currently disabled.
◆ create_uses_data_and_control_port()
virtual uses_port * Superv_Component_i::create_uses_data_and_control_port ( const char *  )
Warning
currently disabled.
◆ create_uses_data_port()
uses_port * Superv_Component_i::create_uses_data_port ( const std::string &  port_fab_type)
port_fab_typetype uses port.
the uses port.
It's user repsonsability to destroy the uses port.
References port_factory::create_data_proxy(), get_factory(), and LOC.
◆ destroy()
void Engines_Component_i::destroy ( )
CORBA object is deactivated (do not respond any more to CORBA calls), the connection to Regsitry is removed (Registry informed of deactivation), internal server reference counter on the derived servant class is decremented, to allow destruction of the class (delete) by POA, when there are no more references. – TO BE USED BY CONTAINER ONLY (Container housekeeping) –
References Engines_Component_i::_id, Engines_Component_i::_poa, and MESSAGE.
◆ disconnect_provides_port()
virtual void Engines_DSC_i::disconnect_provides_port ( const char *  provides_port_name,
◆ disconnect_uses_port()
virtual void Engines_DSC_i::disconnect_uses_port ( const char *  uses_port_name,
◆ DumpPython()
Engines::TMPFile * Engines_Component_i::DumpPython ( CORBA::Boolean  isPublished,
◆ endService()
void Engines_Component_i::endService ( const char *  serviceName)
◆ get_factory()
port_factory * Superv_Component_i::get_factory ( const std::string &  factory_name)
factory_namename of the factory.
factory pointer, NULL if the factory doesn't exist.
References _factory_map.
Referenced by create_provides_data_port(), and create_uses_data_port().
◆ get_port() [1/3]
SpecificPortType * Superv_Component_i::get_port ( const char *  port_name)
port_namethe name of the port.
a port's pointer.
References Engines_DSC_interface::get_provides_port(), Engines_DSC_i::get_uses_port(), LOC, my_superv_ports, my_superv_ports_it, Superv_Component_i::superv_port_t::p_ref, salome_instance::port, and Superv_Component_i::superv_port_t::u_ref.
◆ get_port() [2/3]
void Superv_Component_i::get_port ( provides_port *&  port,
portthe provides port pointer.
provides_port_namethe name of the port.
References Engines_DSC_interface::get_provides_port(), LOC, my_superv_ports, and salome_instance::port.
◆ get_port() [3/3]
void Superv_Component_i::get_port ( uses_port *&  port,
portthe uses port pointer.
uses_port_namethe name of the port.
References Engines_DSC_i::get_uses_port(), LOC, my_superv_ports, and salome_instance::port.
◆ get_port_properties()
virtual Ports::PortProperties_ptr Engines_DSC_i::get_port_properties ( const char *  port_name)
◆ get_provides_port()
virtual Ports::Port_ptr Engines_DSC_i::get_provides_port ( const char *  provides_port_name,
◆ get_uses_port()
virtual Engines::DSC::uses_port * Engines_DSC_i::get_uses_port ( const char *  uses_port_name)
◆ get_uses_port_names()
void Superv_Component_i::get_uses_port_names ( std::vector< std::string > &  port_names,
const std::string  servicename = ""
If servicename is not set, all the ports of the component are returned.
port_namesthe ports's list.
servicenameservice's name.
References my_superv_ports.
Referenced by CalciumInterface::ecp_fin().
◆ getContainerName()
std::string Engines_Component_i::getContainerName ( )
the container name (reformatted)
References Engines_Component_i::_containerName.
Referenced by create_calcium_port(), CalciumInterface::ecp_cd(), CalciumInterface::ecp_ecriture(), CalciumInterface::ecp_effi(), CalciumInterface::ecp_efft(), CalciumInterface::ecp_fin(), CalciumInterface::ecp_fini(), CalciumInterface::ecp_fint(), and CalciumInterface::ecp_lecture().
◆ GetContainerPtr()
Engines_Container_i * Engines_Component_i::GetContainerPtr ( )
References Engines_Component_i::_container, and Engines_Component_i::_poa.
◆ GetContainerRef()
Engines::Container_ptr Engines_Component_i::GetContainerRef ( )
References Engines_Component_i::_container.
Referenced by Engines_Component_i::setInputFileToService(), and Engines_Component_i::setOutputFileToService().
◆ GetDynLibraryName()
std::string Engines_Component_i::GetDynLibraryName ( const char *  componentName)
References waitContainers::cname, and TestKernelHelpers::ret.
Referenced by Abstract_Engines_Container_i::decInstanceCnt(), and Engines_Parallel_Container_i::decInstanceCnt().
◆ getId()
PortableServer::ObjectId * Engines_Component_i::getId ( )
References Engines_Component_i::_id.
Referenced by SalomeTestComponentEngine_factory(), and TestMPIComponentEngine_factory().
◆ getInputFileToService()
Engines::Salome_file_ptr Engines_Component_i::getInputFileToService ( const char *  service_name,
const char *  Salome_file_name
◆ getNS()
◆ getObjectInfo()
char * Engines_Component_i::getObjectInfo ( const char *  entry)
◆ GetOption()
char * Engines_Component_i::GetOption ( const char *  )
◆ getOutputFileToService()
Engines::Salome_file_ptr Engines_Component_i::getOutputFileToService ( const char *  service_name,
◆ getProperties()
Engines::FieldsDict * Engines_Component_i::getProperties ( )
(see setProperties)
References Engines_Component_i::_fieldsDict.
◆ getVersion()
char * Engines_Component_i::getVersion ( )
This method is supposed to be implemented in all derived classes; default implementation returns empty string that means that no version information about the component is available.
The version of the component is stored to the study, as a part of general persistence mechanism; once stored, version information in the study cannot be changed.
string containing component's version, e.g. "1.0"
Referenced by SALOME_DriverPy.SALOME_DriverPy_i::Version().
◆ graphName()
char * Engines_Component_i::graphName ( )
◆ hasObjectInfo()
bool Engines_Component_i::hasObjectInfo ( )
◆ init_service_with_multiple()
virtual CORBA::Boolean Superv_Component_i::init_service_with_multiple ( const char *  ,
Reimplemented in PySupervCompo.
◆ instanceName()
◆ interfaceName()
char * Engines_Component_i::interfaceName ( )
References Engines_Component_i::_interfaceName.
◆ is_connected()
virtual CORBA::Boolean Engines_DSC_i::is_connected ( const char *  port_name)
◆ isMultiInstance()
static bool Engines_Component_i::isMultiInstance ( )
◆ isSSLMode()
◆ Kill_impl()
bool Engines_Component_i::Kill_impl ( )
References Engines_Component_i::_ThreadId, and Engines_Component_i::Killer().
◆ Killer()
bool Engines_Component_i::Killer ( pthread_t  ThreadId,
int  signum
◆ Names()
void Engines_Component_i::Names ( const char *  graphName,
const char *  nodeName
References Engines_Component_i::_graphName, Engines_Component_i::_nodeName, Engines_Component_i::graphName(), and Engines_Component_i::nodeName().
◆ nodeName()
◆ ping()
void Engines_Component_i::ping ( )
References MESSAGE.
◆ provides_port_changed()
void Superv_Component_i::provides_port_changed ( const char *  provides_port_name,
int  connection_nbr,
◆ register_factory()
void Superv_Component_i::register_factory ( const std::string &  factory_name,
port_factory *  factory_ptr
If the factory_name is already used, the new library is not added.
factory_namename of the factory (used by Superv_Component_i::create_provides_data_port and Superv_Component_i::create_uses_data_port)
factory_ptrfactory pointer (destroyed by the component)
Referenced by basic_port_factory::basic_port_factory(), calcium_port_factory::calcium_port_factory(), and palm_port_factory::palm_port_factory().
◆ Resume_impl()
bool Engines_Component_i::Resume_impl ( )
◆ sendMessage()
void Engines_Component_i::sendMessage ( const char *  event_type,
const char *  message
◆ setContainerName()
void Engines_Component_i::setContainerName ( )
References Engines_Component_i::_container, Engines_Component_i::_containerName, SALOME_ContainerPy::containerName, and pythfilter::name.
Referenced by Engines_Component_i::Engines_Component_i().
◆ SetCurCpu()
void Engines_Component_i::SetCurCpu ( )
◆ setInputFileToService()
Engines::Salome_file_ptr Engines_Component_i::setInputFileToService ( const char *  service_name,
◆ SetOption()
void Engines_Component_i::SetOption ( const char *  ,
const char *
◆ setOutputFileToService()
Engines::Salome_file_ptr Engines_Component_i::setOutputFileToService ( const char *  service_name,
◆ setProperties()
void Engines_Component_i::setProperties ( const Engines::FieldsDict &  dico)
Base class component stores the sequence in a map. The map is cleared before. This map is for use by derived classes.
dicosequence of (key=string,value=any)
◆ setTimeOut()
void Superv_Component_i::setTimeOut ( )
References dscTimeOut.
Referenced by beginService(), and Superv_Component_i().
◆ Stop_impl()
bool Engines_Component_i::Stop_impl ( )
◆ Suspend_impl()
◆ uses_port_changed()
void Superv_Component_i::uses_port_changed ( const char *  uses_port_name,
Engines::DSC::uses_port *  new_uses_port,
◆ writeEvent()
void Engines_DSC_interface::writeEvent ( const char *  request,
const std::string &  containerName,
const char *  instance_name,
const char *  port_name,
const char *  error,
requestthe name of the request executed
containerNamethe name of the container where the request is executed
instance_namethe name of the component where the request is executed
port_namethe name of the port that is concerned
errorif an error has occured, a string that identifies the error
messageinformations about error or about the request
References SALOME_ContainerPy::containerName, IDLparser::error(), initTrace(), TestMinimalExample::msg, out, traceLevel, and traceType.
Referenced by create_calcium_port(), CalciumInterface::ecp_cd(), CalciumInterface::ecp_ecriture(), CalciumInterface::ecp_effi(), CalciumInterface::ecp_efft(), CalciumInterface::ecp_fin(), CalciumInterface::ecp_fini(), CalciumInterface::ecp_fint(), CalciumInterface::ecp_lecture(), GenericPort< DataManipulator, COUPLING_POLICY >::get(), and GenericPort< DataManipulator, COUPLING_POLICY >::next().
◆ _CanceledThread
bool Engines_Component_i::_CanceledThread
privateinherited
◆ _container
◆ _containerName
◆ _contId
◆ _Executed
◆ _factory_map
std::map< std::string, port_factory * > Superv_Component_i::_factory_map
staticprivate
Referenced by get_factory(), and register_factory().
◆ _fieldsDict
◆ _graphName
◆ _id
◆ _Input_Service_file_map
◆ _instanceName
◆ _interfaceName
◆ _isMultiInstance
bool Engines_Component_i::_isMultiInstance = false
staticprotectedinherited
◆ _myConnexionToRegistry
RegistryConnexion* Engines_Component_i::_myConnexionToRegistry
◆ _nodeName
◆ _notifSupplier
◆ _orb
◆ _Output_Service_file_map
◆ _poa
◆ _Salome_file_map_it
◆ _Service_file_map_it
◆ _serviceName
◆ _StartUsed
◆ _thisObj
◆ _ThreadCpuUsed
◆ _ThreadId
◆ dscTimeOut
◆ my_ports
◆ my_ports_it
◆ my_superv_ports
◆ my_superv_ports_it
superv_ports::iterator Superv_Component_i::my_superv_ports_it
